Question about Refrigerators
How to change door gasket seal from kitchenAid kbrc36fks01
    Champion:
  • 210 Answers
Repairclinic.com has an excellent video . enter part number 2188532. click on the video.
Posted on Oct 15, 2013
Kitchenaid dishwasher door leaks out bottom middle of door when it goes into drain mode?
You probably need to check the door gasket for proper sealing and maybe replace it if the dishwasher has been in use for awhile
Oct 13, 2012 | KitchenAid KUDI24SE Built-in Dishwasher
When I close the refrigerator door, the door will pop ajar unless I contine to push it for a second. The seal is in good condition. It feels like there is air pushing the door open. I have washed the...
raise the front legs and get some heavy stuff on the door shelves,also wah around the area where the gasket closes onto the frame,there are magnets in the gasket,also check to make sure nothing is hitting the door from the inside,when food is jammed in or the draw is sticking out to far and the door hits it it doesn't seal good and pops open.hope this helps
Feb 24, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Can I replace the freezer door seal on a kitchen aid myself?
some door gaskets snap into a track and others are held on to by screws in a metal frame. you can pull the back of the gasket apart to see which you have.
are you sure that the gasket is bad? you can do the dollar bill test by placing a dollar bill between the gasket and door frame and shutting the door. if the dollar bill fits snugly and is not loose the gasket is good. However you may be able to look at your gasket and see that it is torn or warped and not sealing good.
replacing the door gasket can be a little tricky but with a little patience and some very hot water to soak the new gasket in to make it easier to work with, you should be ok.
keep the bottom of your refrigerator and freezer frames clean (this is where everything spills and gets sticky) to keep the gasket from sticking to the frame and tearing up over time.
Jul 24, 2010 | KitchenAid Superba Architect KSCS25INSS...
Refrigerator side door will not seal
I got my hands on a repair manual, ordered a new gasket and hope to have it repaired when the part arrives. Rylee's solution dealt with an older, simpler fix. On my Kitchenaid you have to separate the inner and outer door shells to install the gasket. I would appreciate a refund.
Mar 13, 2010 | KitchenAid KSRB25FKSS Side by Side...
The seal in the doors are ripped causing not to seal tight causing condensation inside frig
new gaskets are expensive to replace (usually $80-150 each door) if this sounds reasonable to you call for service, however if this happens to be a spare fridge or in a location where it is not seen you can repair the gaskets with duct tape. it doesn't look the greatest but it works and its cheap! run the tape longways with the gasket and make sure its smooth and the same shape as the gasket originally.
Feb 08, 2010 | KitchenAid Refrigerators
BMW door seal?
make sure you have the new one on hand also the glue you can pick up the glue at a local autoparts store. Now lay the new door seal out in the sun while you are taking the out one off so that its warm and stretches easy, once the old one is off clean the railing that holds the gasket with rubbing alcohol on a rag, then apply the glue as you put on the gasket
May 30, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
KitchenAid Dishwasher Leaking from under Door
I had a similar problem with a KUDM25SHWH1 dishwasher. Rubber seal looked fine. I found an incredible tip on another fixi it site. One possible problem iss the pump cover screws may have worked loose and is squirting water directly on the door seal. Man that was it! I saw a couple of looses screws and a small portion of the pump cover gasket showing. I loosened the pump top, reset the gasket tightened it all down...no leaks! The pump I refer to is located directly below the spray arm inside the washer. Easy to get to. Another tip was to look for a split sspray arrm that may spray water directly into the door seal.
Nov 04, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Oven Doors will not stay closed all the way
I think this is a cheapest and eat way to fix your oven doors... Otherwise there are 2 spring type locks of the door that starts getting old day by day ... You have to change the pair of lock only
Apr 05, 2008 | KitchenAid Architect® KEBS277S Electric...
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
