Question about Serena Runbo X5 Ip67 Waterproof Dustproof Android 4.0 Os 4.3&ips Scree
Dropped my runbox5 will not start - Serena Runbo X5 Ip67 Waterproof Dustproof Android 4.0 Os 4.3&ips Scree
I replaced my starter and now the car doesn't even make a clicking sound and still won't start
What make , model an year vehicle ? Didn't start before you replaced the starter an still won't start ? Did you test it before replacing it ? Voltage drop testing the starter electrical circuit is how to find the problem !
Starter Voltage Drop
How to voltage drop test starter motor circuit
Apr 20, 2017 | Cars & Trucks
Kia Sedona does not start
Battery cables could cause this problem . To test the starter circuit we do voltage drop testing with DVOM - digital volt ohm meter . Corrosion can get down inside the battery cables an cause a drop of voltage in the circuit . Starter Voltage Drop
Sep 30, 2016 | 2004 Kia Sedona EX
I put a new starter on a year ago. today put on anew alternator and my truck will only turn over a few times quit
Battery ? battery cables ? Test the starting system , voltage drop starting system ! go on you tube a check out voltage drop testing starting system .
Jan 09, 2016 | Cars & Trucks
Ref. Innovage model hl 168J Blood Pressure Monitor. Problem: after the pressure build up and the meter starts dropping it goes to the Diastolic reading then records error. I notice the drop is very rapid....
Innovage model hl 168J Blood Pressure Monitor. Problem: after the pressure build up and the meter starts dropping it goes to the Diastolic reading then records error. I notice the drop is very rapid. On other monitors I have used the drop is much slowe
Jun 24, 2010 | Health & Beauty
When Running Current of the car goes down,and it Idles down...
this is normal to an extent. normal wear and tear will cause the altenator to drop voltage. at some point it will start showing on the gauge that drops as the engine speed drops. just watch and see when it starts to drop below 12 volts. time to change the altenator
Jun 14, 2010 | 2005 Suzuki Verona EX
Checked oil pressure with guage
Drop the oil pan and clean out the oil pick-up screen.
May 20, 2009 | 1997 Infiniti.5 Q45
My 98 S10, stop and don't start anymore. the compression test is ok,but no spark....and the fuel pump have no power...that means 12 volts is interrupted in some place....but where????
first check the condition of all circuit wiring for damage. Inspect all connection to the starter motor, solenoid, ignition switch, and battery, including all ground connections. Clean and tighten all connections as required
next
Check the voltage drop between the negative battery terminal and the vehicle frame by placing one lead of a voltmeter on the grounded battery post (not the cable clamp) and the other lead on the frame. Turn the ignition key to the START position and note the voltage drop.
Check the voltage drop between the positive battery terminal (not the cable clamp) and the starter terminal stud. Turn the ignition key to the START position and note the voltage drop.
Check the voltage drop between the starter housing and the frame. Turn the ignition key to the START position and note the voltage drop.
If the voltage drop in any of the above is more than 1 volt, there is excessive resistance in the circuit. Clean and retest all cables not within specification. Replace as necessary.
let me know what happens
Mar 06, 2009 | 1984 Chevrolet S-10
Oil Pressure Drops While Driving
your oil pump is either weak or there is sludge i9n the oil pan. my adives is to have the oil pan dropped . chances are sludge is the culprit. as the oil get's warm the pressure should only drop slightly but pressure is generally dictated by engine rpm. pumps are gear driven so if it was a bad pump your oil pressure would start out very low at start up.
Aug 28, 2008 | 1995 Jeep Grand Cherokee
Serena Runbo X5 Ip67 Waterproof Dustproof Android 4.0 Os 4.3&ips Scree Logo
78 people viewed this question
Top Serena Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Serena Measuring Tool and Sensor Expert? Answer questions, earn points and help others
