Question about GE GDS18LBP Bottom Freezer Refrigerator
Frigidaire refigerator is not cold - GE GDS18LBP Bottom Freezer Refrigerator
Refigerator runs but does not cool
Hello, Make sure that the area around the compressor is clean. Remove all dirt dust and debris from compressor area as well and under the front of the fridge using a vacuum cleaner hose and brush attachment. If the fridge cannot "breathe", it will not blow cold air. Hope this helps.
Nov 20, 2014 | Frigidaire Refrigerators
Freezer works but refigerator won't get cold
IF YOU HAVE ALOT OF FROST ON THE BACK PANEL OF THE FREEZER IT IS A DEFROST T-STAT THAT CAN BE BAD IF THERE IS NO FROST FELL UP IN THE LEFT UPPER CORN OF THE FRIG SIDE SEE IF YOU CAN FILL THE AIR COMING OUT OF IT
Nov 01, 2012 | Frigidaire Ffhs2313Ls 23 Cu Ft Side By...
Freezer is working but refigerator has no cold air blowing
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | Frigidaire Refrigerators
Freezer is building up ice refigerator is not cold
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Aug 31, 2010 | Frigidaire FRS26R4A Side by Side...
Frigidaire top-mount refig. freezer won't get cold ,temp.stays around 26 degrees, refrig. don't keep milk cold enough
check that the evaporator fan motor ,located in freezer is working.it circulates the cold air.also check that the coils behind freezer back panel are not iced up,this would indicate a lack of defroting due to,timer,heating element,or bi-metal.lastly when the refrig is running those coils should get frost over them all,if not you may be low on refigerant
Jan 20, 2010 | Frigidaire FRT17G5CSB Top Freezer...
Comperssor kicks on but quickly cuts off intermittently every 5 minutes on my frigidaire fridge side by side
Freezer defrosted everything fan continues to run but will not freeze. Compressor is cycling enough to keep refigerator section cold. 106 Series Kenmore. Turned up thermostat to keep fridge cold and a shorter intermittent compressor cycle run
Jun 06, 2009 | Frigidaire FRS26H5AS Side by Side...
Keep garage refigerator/freezer cold in winter
is it a frigidaire model by any chance?? if so you can call the manufactue they do have a garage kit, to help the machine run at a lower ambient temp.
Dec 04, 2008 | Refrigerators
Ice maker & top fan motor is not running
If the fan is not running the freezer will not be cold enough for the ice maker to run. The fan may be stuck. Or it may need to be replaced. If you can remove the ice maker and take off the back panel of the freezer. Try to spin the fan to get it going. If not you may have to replace the fan.
Apr 20, 2008 | Frigidaire FEX831CS Top Load Stacked...
GE GDS18LBP Bottom Freezer Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
