Question about Canon PIXMA Office Equipment & Supplies
720 printer ADF FEEDER NOT PICKING UP SHEETS OF PAPER FOR SCANNING
SOURCE: HP d135 All-in-One -- Documents won't feed through ADF for scanning or copying
open up the ADF and see if there's something in the way on the side that's not pulling through
Try this link for more Printer Resources
Posted on Aug 19, 2008
SOURCE: Adf pulls 2- or more pages in feeder.
open the ADF and clean the rollers and wooden cork pad and unplug the machine and press and hold the ON button for 1 min and release the button and plug it bak and it should resolve ur issue........
Regards raj_p5983
Posted on Jan 21, 2009
Guru Guy
  • 95 Answers
SOURCE: Canon PC 1060 will not SCAN
DO NOT USE ALCOHOL ON RUBBER ROLLERS! This will dry them out and cause more problems! Use a gentle cleaner like soap and water or Simple Green to clean rubber roller parts!
Posted on Nov 24, 2009
  • 7993 Answers
SOURCE: how to print using ADF feeder?
You take the paper with face to print Up and the top of the paper towards the interior of the ADF. You can also put a stack of papers. When you press the copy/scan command from the machine console or the computer, the automatic document feeder starts.
Posted on Jan 06, 2010
Testimonial: "Thanks.. I understand now.. Is not like canon. Canon could change the feeder from ADF or bottom."
tech-agent
  • 83 Answers
SOURCE: Paper feeder takes too many sheets at once
please stack the paper first, fan it before loading the paper, if it is the same,the rollers of the printer is broken
Posted on Feb 13, 2010
When making photocopies, the automatic top paper feeder is grabbing more than one page at a time. How do we fix it?
Clean all the rollers in the ADF with a damp lint free cloth. Depending on wear, they may need to be changed, but try cleaning first. Where the paper stack rests there will be either a pad or roller, make sure it is clean too.
Dec 08, 2014 | Copystar CS-2550 All-In-One Printer
What does an adf jam mean? what do i have to do to fix that? dell photo 964
The ADF is the "automatic document feeder". It's at the top of the printer. It's where you place multiple sheets of paper on a tray to get fed into the copying part of the printer.
There is either a sheet of paper jammed in there or a piece of a paper stuck in there.
May 26, 2011 | Office Equipment & Supplies
The paper keeps jamming, I cant see anything in the way. any help is appreciated.
If paper doesn't feed correctly when printing, remove it and fan the edges of the paper to separate the sheets. Reload the paper against the right side and slide the edge guide against it. Do not load too many sheets at once.
If paper has jammed: 1. Press x Start to eject the jammed paper. 2. If paper is still jammed, gently pull it out from the output tray or sheet feeder. If paper is stuck inside, press the P On button to turn off the printer. Then lift the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the printer back on.
If documents don't feed correctly in the Automatic Document Feeder, make sure the corners of the paper are not bent, folded, or curled up. Do not load more than 10 sheets of legal-size paper at a time. If documents have jammed: 1. Open the ADF cover and pull any paper out to the left. Caution: Do not try to remove the paper without opening the ADF cover first, or you could damage the mechanism. 2. Select Yes or press OK to clear any messages on the display screen. 3. Reload the paper.
Feb 28, 2011 | Epson WorkForce 600 All-In-One InkJet...
While printing, red turned to pink on printed sheets. All cartridges have ink.
Try
Clean the Scanning Area sikaku.gif Cleaning the Platen Glass and Document Cover i_expl.gif Caution
Be sure to turn off the power and disconnect the power cord before cleaning the machine.
i_important.gif Important
bullet_s2.gif The inner side of the Document Cover (white sheet) (C) is easily damaged, so wipe it gently.
bullet_s2.gif If the glass of the ADF (A) is stained with ink, correction fluid, or the like, black streaks may appear on the printed paper when the document is loaded in the ADF. With a clean, soft, lint-free cloth, wipe the glass of the ADF.
With a clean, soft, lint-free cloth, wipe the Platen Glass (D), the inner side of the Document Cover (white sheet) (C), the glass of the ADF (A), and the inner side of the ADF (white area) (B) gently. Make sure not to leave any residue, especially on the Platen Glass.
sikaku.gif Cleaning the ADF i_expl.gif Caution
1. Open the Document Tray.
2. Open the Feeder Cover.
3. With a soft, clean, lint-free and dry cloth, wipe off any paper dust from the inside of the Feeder Cover (A).
4. After wiping, close the Feeder Cover by pushing it until it clicks into place.
5. Close the Document Tray.
6. Reconnect the power cord then turn on the machine.
Oct 27, 2010 | Canon PIXMA MX850 Multifunction Printer
It stopped faxing through the feeder and said feeder errror. its a HP j4680 all in one office jet
Hello, Brittany.
Give this a try (from HP Support):
Complete the following steps to check the condition of the paper, reload the original, and then open and close the Automatic Document Feeder cover.
The main reason for this issue is that the ADF rollers that pick up the papers might not grip the paper because dirt sticks to the rollers.
Step One: Check the paper and reload the original
The condition of the paper, or the amount of paper, might prevent the ADF from picking it up and feeding it through the product.
1. Make sure that the ADF tray contains fewer than 25 sheets of paper.
2. Make sure that the ADF tray contains no photo paper or carbon paper.
3. Make sure the paper in the ADF tray meets the following criteria:
* No curls, folds, creases, or tears
* No staples or clips attached
NOTE: Folded paper, torn paper, or paper with rough edges might not feed correctly. If your original is folded or damaged, either reprint the original or try to smooth out the damaged portions.
4. Reload your original, with the print side up, into the ADF tray. Place the pages so that the top edge of the document goes in first. Slide the paper into the ADF tray until you hear a beep or see a message on the display indicating that the loaded pages are detected.
* If still a problem, go to the next step.
Step Two: Open and close the ADF cover
NOTE: Remove all originals from the ADF tray before you open the ADF cover.
1. Open the ADF cover, and then close it again.
2. Press the OK button.
Follow these steps to turn the product off and then on again.
1. Press the Power button to turn off the product.
2. Wait 15 seconds.
3. Press the Power button to turn on the product.
Hope this helps.
Feb 26, 2010 | HP Office Equipment & Supplies
Regards raj_p5983
Jan 21, 2009 | HP OfficeJet 7410 All-In-One InkJet...
ADF (automatic document feeder) constantly jams
change paper pick-up roller & paper stop roller in ADF
Oct 30, 2008 | Brother MFC-8840D All-In-One Laser Printer
ADF Usage
Put the paper in the automatic feeder. In the software options, click on ADF (automatic document feeder) and it will scan multiple pages.
Jun 06, 2008 | HP LaserJet 3030 All-In-One Printer
13 people viewed this question
old marine
old marine
