Cpu on but no video no beeps - Computers & Internet
    Novelist:
    Scholar:
  • 100 Answers
There is likely a hardware-error.
1) Did you connect all powerconnectors correctly to the motherboard ?
2) Same question for attached internal hardware ?
3) Memory modules inserted correctly ?
If all OK, it's seems you PC is correctly booting and running succesfully an operting system like Windows.
Now, the error might occur something between monitor and PC.
4) Did you recently change the screensettings under Windows ?
If your monitor can run max. 1024x768-mode, but you accidentally fiddled with Windows-settings, to set it into 1200x900-mode, your monitor will turn black, not showing anything of Windows. In panic you might have turned of your computer. To solve this, it's best to push the F5-key when booting in Windows safe-mode. Here you can restore the older screen-setting.
5) No damage at pins of connectors between monitor and PC ?
6) Cable between monitor and PC connected correctly ?
If all OK :
7) Does monitor power on ?
Yes. Shortly but turns off within seconds (for TFT-monitors)
- Something at inverter-level is damaged. This is inside the monitor.
No. monitorLED is not even turning on
- Monitor has an internal defect
Posted on Oct 14, 2013
I'm the one with the emachine that won't boot just beeps resat RAM and repluged video.
check FAN on CPU. Check also the radiator on the CPU. If you can - remove CPU and check the paste between the CPU and radiator - apply new paste, assemble back the CPU and try again.
Feb 28, 2012 | Computers & Internet
Tip
Computer error beep codes
No Beeps
Short, No power, Bad CPU/MB, Loose Peripherals
One Beep
Everything is normal and Computer POSTed fine
Two Beeps
POST/CMOS Error
One Long Beep, One Short Beep
Motherboard Problem
One Long Beep, Two Short Beeps
Video Problem
One Long Beep, Three Short Beeps
Video Problem
Three Long Beeps
Keyboard Error
Repeated Long Beeps
Memory Error
Continuous Hi-Lo Beeps
CPU Overheating
you can now simply analyze if what is the problem of your computer...
on Feb 13, 2010 | Computers & Internet
NO SOUND HEAR
Hi, Do this beeping code for motherboard troubleshooting. First disconnect all memory,external video card, etc only motherboard and power supply. Then power on if you hear continuous beeping means the motherboard working good. Please do this beeping code troubleshooting.
No beeping means Short, No power, Bad CPU/MB, Loose Peripherals. One beeping means Everything is normal and Computer posted fine. Two beeping means POST/CMOS Error. One Long Beep, One Short Beep means Motherboard Problem.
One Long Beep, Two Short Beeps means Video Problem.
One Long Beep, Three Short Beeps means Video problem.
Repeated Long Beeps means memory error.
Continuous Hi-Lo Beeps means CPU Overheating.
Jul 14, 2011 | Computers & Internet
What are the elitegroup Computer system Beep error codes
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Jul 05, 2011 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
Why does my computer beep when I turn it on?
Here is a list of what beeps may mean:
1 long, 2 short Video adapter error: Bad or improperly seated video card Repeating beeps Memory error: Bad or improperly seated RAM 1 long, 3 short Bad video RAM or video card not present High-frequency beeps Overheated CPU: Check fans Repeating high/low beeps CPU: Improperly seated or defective CPU 1 short DRAM refresh failure 2 short Parity circuit failure in the first 64KB of RAM: Likely a bad RAM IC, or possibly one of the hardware tests has failed
Once you have identified what the beeping means you should contact the type of pc you have and ask what to do.
PCHELPSTER007 from youtube
Jun 25, 2011 | Computers & Internet
My computer is beeping every so often it beeps about 3 times and it does it fast please tell me why
It only mens that there's an error on your computer.
Beep codes are use to check or identify which computer part/s causing the problem.
Beeps
Error Message
Description
1long, 2 short Video adapter error Either video adapter is bad or is not seated properly. Also, check to ensure the monitor cable is connected properly. Repeating (endless loop) Memory error Check for improperly seated or missing memory. 1long, 3short No video card or bad video RAM Reseat or replace the video card. High frequency beeeps while running Overheated CPU Check the CPU fan for proper operation. Check the case for proper air flow. Repeating High/Low CPU Either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat. Check the CPU fan or BIOS settings for proper fan speed.
May 11, 2011 | Toshiba Computers & Internet
No start up and continuous repeated long beeps?
Hello
Here are the bios beep codes:
1 long, 2 short
Video adapter error
Memory error
1long, 3short
Overheated CPU
Repeating High/Low
CPU
Check computer beeps and act according to suggestion
Hope it helps if so do rate the solution
Dec 20, 2010 | Compaq Presario Notebook
WHEN I TURN IT ON, THE COPUTER STARTS BEEPING
that sounds. are memory problem related :
Beeps Meaning 1 long, 2 short Video adapter error: Bad or improperly seated video card Repeating beeps Memory error: Bad or improperly seated RAM 1 long, 3 short Bad video RAM or video card not present High-frequency beeps Overheated CPU: Check fans Repeating high/low beeps CPU: Improperly seated or defective CPU
May 10, 2010 | Computers & Internet
What is the beep code asus p5ntws
AMI (American Megatrends International) BIOS Beep Codes.
AMI BIOS uses beeps of the same length and pitch. The error is displayed as a number of beeps. For example, 4 beeps indicated a timer failure.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Award BIOS Beep Codes
Award BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running.
1 Long, 2 Short Video adapter failure Bad video adapter
Repeating (Endless loop) Memory error Bad memory or bad connection
1 Long, 3 Short Video adapter failure Bad video adapter or memory
High freq. beeps (while running) CPU is overheating CPU fan failure
Repeating High, Low beeps CPU failure Bad processor
Phoenix BIOS Beep Codes
Phoenix BIOS uses beep code patterns to indicate problems. In the table below the '-' indicates a brief pause between beeps.
Example: 1 - 1 - 2 would sound like BEEP <pause> BEEP <pause> BEEP BEEP
1 - 1 - 2 CPU / motherboard failure Bad CPU / motherboard
1 - 1 - 3 CMOS read/write failure Bad motherboard
1 - 1 - 4 BIOS ROM failure Bad BIOS chip
1 - 2 - 1 Timer failure Bad motherboard
1 - 2 - 2 DMA failure Bad motherboard
1 - 2 - 3 DMA failure Bad motherboard
1 - 3 - 1 Memory refresh failure Bad memory
1 - 3 - 2 64K memory failure Bad memory
1 - 3 - 3 64K memory failure Bad memory
1 - 3 - 4 64K memory failure Bad memory
1 - 4 - 1 Address line failure Bad memory
1 - 4 - 2 Parity error Bad memory
1 - 4 - 3 Timer failure Bad motherboard
1 - 4 - 4 NMI port failure Bad motherboard
2 - 1 - 1 64K memory failure Bad memory
2 - 1 - 2 64K memory failure Bad memory
2 - 1 - 3 64K memory failure Bad memory
2 - 1 - 4 64K memory failure Bad memory
2 - 2 - 1 64K memory failure Bad memory
2 - 2 - 2 64K memory failure Bad memory
2 - 2 - 3 64K memory failure Bad memory
2 - 2 - 4 64K memory failure Bad memory
2 - 3 - 1 64K memory failure Bad memory
2 - 3 - 2 64K memory failure Bad memory
2 - 3 - 3 64K memory failure Bad memory
2 - 3 - 4 64K memory failure Bad memory
2 - 4 - 1 64K memory failure Bad memory
2 - 4 - 2 64K memory failure Bad memory
2 - 4 - 4 64K memory failure Bad memory
3 - 1 - 1 Slave DMA failure Bad motherboard
3 - 1 - 2 Master DMA failure Bad motherboard
3 - 1 - 3 Interrupt controller failure Bad motherboard
3 - 1 -4 Slave IC failure Bad motherboard
3 - 2 -2 Interrupt Controller failure Bad motherboard
3 - 2 - 3 <RESERVED>
3 - 2 - 4 Keyboard control failure Bad motherboard
3 - 3 - 1 CMOS batter failure Bad CMOS battery
3 - 3 - 2 CMOS configuration error Incorrect setting
3 - 3 - 3 <RESERVED>
3 - 3 - 4 Video memory failure Bad video card or memory
3 - 4 - 1 Video init failure Bad video card or memory
4 - 2 - 1 Timer failure Bad motherboard
4 - 2 - 2 CMOS shutdown failure Bad motherboard
4 - 2 - 3 Gate A20 failure Bad motherboard
4 - 2 - 4 Unexpected interrupt Bad processor
4 - 3 - 1 RAM test failure Bad memory
4 - 3 - 3 Timer failure Bad motherboard
4 - 3 - 4 RTC failure Bad motherboard
4 - 4 - 1 Serial port failure Bad motherboard
4 - 4 - 2 Parallel port failure Bad motherboard
4 - 4 - 3 Coprocessor failure Bad motherboard or CPU.
9 - 2 - 1 Video adapter incompatibility Use a different brand of video card
Apr 20, 2010 | ASUS P5NT WS (P5NT WS GREEN) Motherboard
I hear beeping tone in my cpu when i plug it
When the computer makes those funny sound via the system speaker, it's not doing it because it wants to be heard. The computer is trying to talk to the operator/technician and tell them what's wrong.
So here are some codes to give you an idea of what might be wrong with your PC.
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Nov 30, 2009 | Computers & Internet
Computers & Internet Logo
152 people viewed this question
David Payne
David Payne
