I have a g31dm7 motherboard all fans are running but no video and no beeps
  • 212 Answers
You can try resetting the BIOS settings by following the procedure in annex. If this doesn't work, you will probably have to replace the system board.
i have a g31dm7 motherboard all fans are running - 4bed7247-2f24-46da-a39c-9cc773a41e7d.jpg
Posted on Oct 14, 2013
3 Suggested Answers
yalmer
  • 549 Answers
SOURCE: motherboard problem
If your cpu fan is faster,it may be due to a higher frequency setting.
The frequency that it runs best at is 60 hz, but it can be running at 70 hz or higher.
Posted on Jun 14, 2008
c-tekk
  • 177 Answers
SOURCE: no post to bios on new pc build
FIRST....... Make sure you remove the stock thermal compund (pasty/sticky stuff) from the bottom of the heat sink as well as from the top of the cpu.........
Second APPLY some ARCTIC SILVER 5 compound-ust a thin coat of it over the top of the cpu......use an old credit card.....keep it ff the sides and bottom though......it's important not to use too much........one little tube will do anywhere from 3 to 5 CPUs...!!!
(stock thermal paste/thermal compunds......**** BADLY and can cause a cpu to burn up)
reseat (properly) the cpu and carefull
Now make sure you're 24 pin or 20+4Pin Power connectors are connected, as well as your fans..........disconnect all your SATA Devices, and remove everything but the video card , CPU, and fans.......Now it should post (if all your jumpers are set correctly...........
IF it still doesn't post, remove the video card and reboot.
If it doesn't beep at all......... You have one of 2 things.........A DEAD CPU, or a DEAD MOBO
Posted on Mar 19, 2009
I have a gigabyte p4 pc, when i power it on the fan runs but it gives out a continuous beep. checked ram, processor on another motherboard, cleaned the motherboard, checked for loose cards and cables
The continous beep usually means a memory failure (RAM) or video memory if a plugin card is used.
Check to be sure the unit sees all of the memory, a weak power source( without AC adapter) could cause a partial failure of one memory card.
Another fault would be that the battery is very low on charge and won't accept any charge.
BAD Battery.
hope it helps
May 31, 2012 | Gigabyte GA-8LD533 Motherboard
Fans run at high speed , blue light comes on, i get no video.
Hello
OK, firstly., if the fan runs at hight speeds, it is an indication of the CPU overheating.
If you do not get any beep codes, Your motherboard might also be damaged.
Let me know if you are getting any beep codes.
Also, if the CPU is blown, you will not get any video, because the CPU is not processing anything.
please let me know if you are receiving any beep codes, so we can start troubleshooting.
Kind regards
Andrea
Sep 10, 2010 | Dell (E210882) Motherboard
No video after replacing chip fan
Try a different video-card -- a "no-spin" fan and "no-video" implies a dead video-card (or at least a video-card that is not "seated' properly).
Check that the PC-speaker leads are connected to the motherboard, so that you could hear any "beep" codes. There should be one "beep" to indicate 'OK', or multiple "beeps" (bad RAM, no video-card detected).
Apr 09, 2010 | ASUS A8N-SLI Deluxe Motherboard
No post to bios on new pc build
Mar 19, 2009 | MSI P4M900M-L Motherboard
Power to everything but CPU fan and case fan - won't boot
Hi this is tech crazy
The solution to the problem is as follows
The main reason for CPU fan overworking or not working is due to the load we put on the syatem while operating.So,the first reason for fan not working may be due to the SMPS malfunctionality.Better check out for it.The reason if fan is working but Overworking is due to viruses is system.So go in for format
Hope this solution helps you
Please do rate me on the above said solution
Feb 04, 2009 | Intel Motherboard
Motherboard problem
These more up to date cards have a special PCI-E connector actually on the card which you have to connect to your psu too.
It shouldnt beep if theres no problems
If you cant get video or anything , make sure that the cardrs power conenctor is plugged into the psu
Jan 07, 2009 | Computers & Internet
Powers on-indicator lights light up, motherboard fan runs, but do
try reseating the dimm ..
I don't see a listing in the manual for 5 beeps as you describe
Jan 04, 2009 | Lenovo ThinkPad X60 Tablet PC
661FX-M7 Problems
The fan running at 100% may be fine, depending on how you hooked it up. However, you seem to have a conflict with the video. The short beep you hear is usually the motherboard recognizing the boot drive. The long beep means something isn't configured correctly possibly the video card...?
Look in the owners manual for the keystroke to get into the bios settings. Then right when you turn it on, before the long beep, hit that keystroke and get into the bios and check settings.
NOTE: if you don't get any video when you enter the bios, there is clearly a compatibility issue with your video. All video cards should put out signal for the bios - even if the proper drivers aren't loaded for Windows.
Nov 03, 2008 | EliteGroup 661FX-M7 (661FXM7V11)...
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
