I need to reset my toshiba satelite A215-S4817 to factory default
  • Computers & ... Master
  • 27,725 Answers
Toshiba satelite A215-S4817
This is a laptop not a desktop !!
Restoring factory default settings on your computer can be done within a couple of hours, without any need for the recovery discs.
First, you need to back up any data and information that you want to keep, such as documents, pictures, and downloaded email, since everything will be erased from your hard drive after restoring the factory settings on your computer.
If you haven't restored factory settings on your machine before, do not worry.
With proper instruction, you can have your computer back to its original state within a few hours at most.
Restart your computer and proceed to Step 2 before Windows begins to load after reboot.
If you are restoring a Toshiba model, hold down the "0" (zero) key as you turn off the machine, then skip to step three.
Access your computer's "PC Recovery" feature by entering the correct button(s) for your machine.
This button varies, depending on the make of your machine.
HP and Dell users will hit the "F11" key, whereas Acer and Sony users will enter "F10."
If you own a Samsung model, use "F4."
Select "Destructive Recovery," or "Restore Original Factory Image," from the list of options that appear on the next screen, then click "Continue."
A destructive recovery will erase everything on your machine and reinstall the operating system.
Wait as the factory settings are restored on your computer.
Windows will require you to make date, time, and language settings on the next set of screens to follow after your machine restarts.
This process can take anywhere from a half-hour up to 2 hours to complete.
Posted on Oct 14, 2013
Whydvd player does not work and has no sound
Check your device manager for flags under the device.
May have to reload correct driver for the unit.
May also find a driver problem with audio devices under same.
May 22, 2014 | Toshiba A215-s4817-Satellite A215-s4817...
How to reset Toshiba A215 to factory defaults
You may follow the below steps to restore your Toshiba A215 laptop to its factory defaults:
Turn the Toshiba Satellite A215 computer off.
  • Press and hold the "0" key. Turn the computer on.
  • Release the "0" key when the Toshiba Recovery Wizard screen appears.
  • Click to select "Recovery of Factory Default Software" and then click "Next."
  • Click to select "Recover to out-of-box-state" and then click "Next."
  • Click "Next" on the confirmation screen to begin the recovery process.
  • Press any key on the keyboard to restart the computer when prompted. The computer boots up to the Windows setup screen.
  • Hope this helps..
  • May 20, 2014 | Dell Inspiron Mini 10 Notebook
    Toshiba safelite A215-S4817
    Disconnect the power. Remove the battery. Reconnect the power and see if the laptop turns on. If it works without the battery, replace the battery with a new one.
    If it still does not work your laptop needs factory service.
    Mar 03, 2014 | Computers & Internet
    Cant find cmos battery on toshiba satellite A215-S4757
    Zoom in on the first picture from the link below:
    http://www.ebay.com/itm/Toshiba-Satellite-A215-AMD-Motherboard-K000053710-CPU-A215-S4757-A215-S4817-/170847961281#vi-content
    This is a picture of your motherboard. The RTC (CMOS) battery is the little light blue and silver circle in the lower left part of the motherboard(about 1cm from the left edge of the board and 4 cm from the bottom edge of the board). It's much smaller than a standard desktop's cmos battery (2032). You should be able to pop the tiny 2 pin connection out of the tiny slot there to reset it.
    Jun 12, 2012 | Toshiba Satellite A215-S4747 Notebook
    Toshiba Satelite M35X-S111 Beep codes on boot
    You need to go into the BIOS (setup) and reset to factory defaults first. This should clear up the issue.
    May 28, 2012 | Toshiba Satellite M35X-S161 Notebook
    I want to know how to restore my friends toshiba satellite a215 computer.
    Hi
    I have read somewhere :-
    If you wanna reset to factory defaults using the hidden recovery partition, press & hold the zero (0) key immediately at bootup & the Toshiba Recovery Wizard will pop up
    Nov 13, 2010 | Toshiba Satellite A215-S4747 Notebook
    Hello sir! i have a problem that i lost my toshiba "sattelite A215-S4817" laptop drivers.i want to get back my laptop's genuine drivers. can you help me to solve this problem??? thank you!!!!
    You can download all the drivers from Toshiba official website (click here), open the link, select the operating system from "Refine Search By" and download whatever you want/need.
    If you need further help, let me know with the name of the operating system installed on your computer.
    Good luck.
    Thanks for using FixYa.
    Sep 25, 2010 | Computers & Internet
    Toshiba satellite a215-s7437 bios pw
    For that you need to reset factory defaults settings for bios.
    For reset bios u have to open back side of your laptop then u find motherbord circuit there.
    pull cmos cell on motherbord for 15 minute then it reset to defaults.
    Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
    It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
    then again set it in 1-2 its original position.
    Then it not want password.
    Jun 21, 2009 | Toshiba Satellite A215-S4747 Notebook
    Finger print sensor not working with vista in toshiba M200
    here is the link :
    http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2211892&rpn=PSMC4U&modelFilter=M205-SP3018&selCategory=3&selFamily=1073768667&selModel=2211892|PSMC4U
    Satellite A200-ST2041, A200-ST2043, A200-ST2042, A205-S4617, A205-S4618, A205-S4639, A205-S4638, A205-S4537, A205-S4557, A205-S5816, A205-S5814, A205-S5813, A205-S5812, A205-S5811, A205-S5810, A205-S5809, A205-S5806, A205-S5805, A205-S5851, A205-S5847, A205-S5843, A205-S5841, A205-S5835, A205-S5831, A205-S5825, A205-S6810, A205-S5823, A205-S5804, A205-S5803, A205-S5801, A205-S5800, A205-S7468, A205-S7466, A205-S7464, A205-S7459, A205-S7458, A205-S7456, A205-S7443, A205-S7442, A205-S4797, A205-S4787, A205-S4777, A205-S4707, A205-S5863, A205-S5859, A205-S5855, A205-S5853, A205-S5852, A205-S6812, A205-S6808, A205-S5821, A205-S5819, A205-SP5822, A205-SP5821, A205-SP5820, A205-SP5818, A205-SP5817, A205-SP5816, A205-S5000, A205-S5866, A205-S5879, A205-S5878, A205-S5872, A205-S5871, A205-S5867, A205-S5880, A205-S5861, A205-S5833, A205-S5864, A205-S4629, A205-S4607, A205-S4597, A205-S4578, A205-S4587, A205-S4577, A205-S4567, A215-S4697, A215-SP5811, A215-SP5810, A215-S48171, A215-S4817, A215-S4807, A215-S4767, A215-S4757, A215-S4747, A215-S4717, A215-S4737, A215-S5839, A215-S5848, A215-S5837, A215-S5829, A215-S5828, A215-S5827, A215-S6820, A215-S6816, A215-S7472, M110-ST1161, M115-S3094, M115-S3104, M115-S3154, M115-S3144, M200-ST2001, M200-ST2002, M205-S3207, M205-S4804, M205-S4805, M205-S4806, M205-S7453, M205-S3217,
    Apr 02, 2009 | Toshiba Satellite Pro L300 Notebook
    Computers & Internet Logo
    281 people viewed this question
    David Payne
    David Payne
