Question about Bernina Virtuosa 150
How do I remove the light bulb? I've removed the cover but can't figure out how to detach the bulb.
  • 460 Answers
Wont it simply push in and twist out? Sometimes a special bulb holder is supplied with machines to help, have a look through your accessories.
Posted on Oct 16, 2013
How to remove light bulb cover Viking #1+
look on the left side of the machine and see if you see a little round plastic circle, very very carefully use a screw driver to pry it out , there should be a screw to unscrew and the side should come off so you can replace the bulb. if you will send me a comment with the complete name and model number, I'll see if I can find you a manual.
Jun 12, 2015 | Husqvarna Viking 1
How do I change the light bulb
remove the end cover ( screw at the back and hinge out or any other method of removing the end cover
that will reveal the bulb holder on some machines it is necessary to undo the screws holding the holder so that access to the bulb is allowed
make sure that the power is off and disconnected at the power point
the bulb will be most probably be screw it type but some are baynot type ( press in and 1/4 turn
only use the correct bulb in replacing as the wrong bulb will cause the holder to burn from the heat
May 05, 2015 | Sewing Machines
How do I remove the light cover to replace the bulb on a model 411G Singer sewing machine
Pull down the cover to the bulb. Lightly push the bulb while turning to remove the bulb.
Feb 02, 2015 | Singer Sewing Machines
Change a light bulb in Bernina 1008 sewing machinge
If you still have original Acessories there should have been a grey or brown cone shaped rubber gripper that could be slid up on bulb to assist in turning it If not remove the side cover, then back cover to access the bulb. Some 1008's have push in bulb others screw in so be careful not to break bulb as you remove it
push in bulbs must be pushe in and rotated 45 degrees counter clockwise to remove. Of course screw in bulbs just rotated counter clockwise to remove
Aug 23, 2014 | Bernina Sewing Machines
How do i replace a bulb in the imagine babylock
Unplug the machine.
Open the front cover and cutting blade cover.
Remove the light bulb and replace with same (15w/120v) screw-in type or if the machine uses the bayonet type (no screw threads) 10w/240v.
There is a bulb remover that you can purchase/order from a BabyLock dealer.
If you cannot get the bulb out, call a dealer and ask if someone there can help you and when could you come in and not have to leave the serger.
Feb 18, 2010 | Baby Lock Imagine
How to replace light bulb at Pfaff Creative 2124?
On these machines you cannot open the left side to remove the bulb. Your machine accessory kit should have come with a rubber tool that is ribbed with a cup-shaped opening on either end. This is a tool for removing the bulb. Tilt the machine with the base facing up so you can see where the bulb is and use this tool to twist the bulb gently. It sould come out with no problem! Hope this helps!
Sep 11, 2009 | PfaFF Creative 7570
I have a Pfaff 7570 and I would like to adjust the thread tension. Most of the time when embroidering it is set at 1 or 0...and never higher than 3-4. Also I can't get the light bulb end out. it broke...
Lift top cover. remove top cover (flat springs on each end of cover - move one with your finger and top will come off. Lift handle. Look to right of handle end over the head. There is a screw there. LOOSEN screw and front cover will slide away from head. Bunch up a paper towel or napkin and press into broken bulb socket and turn same counter clockwise to get bulb socket out. Good Luck!
Jul 01, 2009 | PfaFF Creative 7570
Pfaff 1222
With power off, needle out, no presser foot, remove top cover off of the machine. Left side cover (light area) has 2 flathead screws deep inside the cover. No need to remove the screws, just loosen the up and the cover can be removed by pulling it out. Now you'll see the light bulb, remove the bulb. On the bulb holder there is 1 screw that secures it, remove the holder. Now actuate the lifter lever, you'll see where it is attached to. It has a small screw that holds it, it might have come off.
Jul 07, 2008 | PfaFF Tiptronic 2030
Light bulb
It is a small bulb that once you remove the cover over it just pulls out, (slides out) and slides back in. The replacements can be gotten at any auto bulb section and are about 2.00 for 2 even Walmart has them
Feb 21, 2008 | Brother Disney ULT-2002D
Sewing Machines Logo
89 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
