Km 1500 kyocera
000-c-6
  • 14 Answers
SOURCE: how to reset the unit...
Reset what? The imaging unit or the toner cartridge? Replace with a new one or get a recharged one.
Posted on Feb 10, 2008
  • 126 Answers
SOURCE: KYOCERA MITA KM-1500 ERROR CODE C7980
C-7980 - Means that the waste tonerresevoir in the process unit is full with less than 100,000 copies onthe unit.
Clean/ empty the waster toner and vac.Also clean the sensor.
You may have to change the Process unit if cleaning does not work.
Posted on Mar 02, 2009
SOURCE: kyocera km-2050 scanning function
The km 2050 was on network, but moved to home and directly into tower system via usb interface connector. Printer works, but can not get scanner to work? read instructions without a clue. can someone help with correct proceedure?
Posted on Mar 12, 2009
cbtmaya
  • 84 Answers
SOURCE: error code C-6 for kyocera km 1500
c6-400 code error is poor connection (power supply)
press start and clear/stop button
the code is inizialized
Posted on Aug 31, 2009
SOURCE: KM 1500 Error c-6 000 error
kyocera km1500 problem of 000 ,c-6
Posted on Nov 14, 2010
How to reset kyocera cs-1500
Hi Nickolas,
You may want to visit this site that has a manual of your machine in order for you to check the reset process. Hope it helps.
Kyocera KM 1500 KM CS 1500 Operation Guide Rev 2 0
Apr 25, 2014 | Xerox Phaser 4500 Printer
What does the error message OP mean on my Kyocera mita KM-1500 copier?
From what I remember on this copier...... The software in the copier may be from another country.... OP or AP most likely the copier needs a new toner installed or could be a paper jam in the doc feeder. The codes were a bit messed up between different countries, I did not biuld them.... Good Luck
Dec 19, 2012 | Kyocera Mita Toner For Kyoceramita...
Kyocera Mita KM-1500 shows flashing c-6 and 020 Pls help
check the fixing unit thermoswitch,thermistor & heaterlamp one of them is the cause of error
Nov 22, 2010 | Kyocera Mita Office Equipment & Supplies
Requist for sugasion kyocera km-1500 toner
it is support cnon np 1215 toner
first time
you clean copier toner unite clean complite previous toner then put canon np 1215 toner print ok
May 28, 2009 | Kyocera KM-1505 Copier
How to reset the unit...
press and hold the following buttons in the sequence below.
(1) Stop/clear, (2) start, (3) exposure lighter, (4) exposure darker, release the 4 buttons and press the stop/clear button again. the display should now indicate 000.
below the display are 3 buttons... press the left button once, the middle button 6 times, and the button on the right 3 times. the display should now indicate 163.... press the start button 3 times.
your machine will now restart, and if the code was as a result of a power problem, should now work fine. if not the problem could be related to the fixing unit, power supply, or one of the boards.
Also do not tamper with any settings while in the service mode, this WILL have undesired effects. TAKE NOTE, this will only work if your model is the KM-1500
Jul 02, 2008 | Kyocera Copystar CS-1620 Black and White...
Error code C-6 for kyocera km 1500
Mar 02, 2008 | Kyocera KM-1505 Copier
14 people viewed this question
k24674
