Tried cleaning radio screen with goop off now its worse think I damaged plastic now white film can it be fixed
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 80 Answers
You may be able to use headlight cleaner/restorer on it to restore it. It works to remove yellowing and or hazing on headlights by scrubbing off the top layer with different grits of sandpaper then a polish to shine and protect
Posted on Oct 14, 2013
System error E007
problem regarding fixing unit, Either your fixing film is damaged or the white spot on the film is dirty. You can clean the white spot. If the film is broken, replace the film unit
Apr 08, 2011 | Canon iR 2022 Printer
I have Canon iR2016N machine in my office. Since the day before yesterday, it is giving SYstem Error E007. For this error, I took out Film Assembly to check the status of Film and whole assembly. I found...
E007 means that the fixing film sensor cant detect rotation of fixing film.
In most cases because the white mark on the left end of foil is damaged.But also when the fixing film does not rotate well due to "baked" fixing film grease. I would suggest you to remove fixing film from heather, clean the grease leftovers and apply new fixing film grease.
Also it can happen if the white rotation mark is dirty or if the rotation sensor is faulty.
Hope that helps
Feb 08, 2011 | Canon iR 2016i Black and White Copier
Dear sir, i have a problem on my canon ir2018 it displays on the screen: error system E007 can you describe to me how can i readjust the damage caused on the film thank you
system error e007 code means that the fusing film is out of Home Postion or the film is ripped. You will need to most likely have the fixing film replaced. You are proble going to have to get a service to repair it, but
Remove the fixing unit from your machine and have a look on it just to check the condition of the fixing film itself. If you find any defect on it, don'tworry. Just buy a new one (fixing film) and replace it. I think thereafter your machine will be okay.
To prevent this problem in future, make sure you always release jummed paper on fixing assembly by pulling the paper release lever (lightgreen).
Good luck and thanks for trying FixYa!! EJ Kudelka
Nov 09, 2010 | Canon iR 2016i Black and White Copier
Canon IR 2018 system error E007
E007 means that the fuser film inside the Fuser unit is damaged which needs to be replaced, or the white patch on the fuser film is dirty and it just needs to be cleaned. I recommend getting a canon technician to fix it,
May 24, 2010 | Canon iR 2016i Black and White Copier
Paloma tankless water heater is reading 14 - 0on the display what does that mean
There is a piece of clear plastic film wraped around the heat exchanger. Conductive material (black) is coated on that film. In case of overheating, the film melts, break the circuit and the heater stops. That's how it works, in theory. I had the same problem and had to remove the heat exchanger to inspect the film on the back side. It's a pain in the @#$%, especially found no problem with the film itself. This is what you should do: Find and disconnect connector U in the center of the board with 2 tiny white wires. Measure resistance between those 2 wires, should be 50K~100K. If it's open, either the film is damaged or, in my case, the connector on the film is bad (on the right side of the heat exchanger). Since no other tankless maker uses this protection scheme, I don't think it's doing much. My solution is to fool the controller with a 100K ohm resistor across the 2 white wires. If you're not comfortable with my micky mouse solution, replace the film.
Feb 07, 2010 | Rheem Paloma Tankless Water Heaters...
Ir2016error proplem error codes solution
IR 2016 is related to a non-detection of the Fixing Film/Upper Roller not spinning correctly.First make sure fuser plastic not damage? Or not move the proper place? if damage fuser plastic Replace by new one if the fuser plastic not damage keep proper place. Please check the condtion of your Film also check the green handle in this area for paper jam removal if it is broken or removed, may also cause this error.
Jan 20, 2010 | Canon iR 2016i Black and White Copier
White lines when printing
Open the front door
On the right side you will notice a handle that you can pull OUTWARDS
On the Outside Right half way down towards the back you will see a removable plastic plate - remove it
Behind plastic plate is a handle, pull it in and out several times. This will wipe any toner off the laser glass
Chances are the white band will now have gone.
If you need further help, please let me know so I can help you fix the machine.
May 18, 2008 | Epson Aculaser C1100 Printer
Cleaning Scratches on TV screen
there is an antiglare film on the tube. the only way to fix this is to replace the crt itself, but this cast more than the tv. i would find a strong cleaner and rub off as much as you can. it is possible i have done this myself.
Nov 04, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
26 people viewed this question
k24674
