Hi, I have freeview DSE7500 box and i cannot get
Hi, I have freeview DSE7500 box and i cannot get freeveiw tv as it asks me for a unlock code. My father gave it to me and he has forgotten the code. How can i get pass this. Any idea's. Cheers Arth
    Problem Solver:
  • 9 Answers
Call the box manufacture or go on line and look up the box xompany
Posted on Oct 14, 2013
2 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: My tv ask for pass code when I turn it on
have you checked under the misc menu and be sure parental controls are all off and no channels or rating are being blocked?
Posted on Aug 07, 2012
Freeveiw
go to the source button and then on the screen comes up EXT
TV USB and whatever else your tv has to offer well for the DVT freeview then you must select what mode you want to use .not simple but it is when you get used to it ,i still think in B/W 405 one channel BBC but iam showing my age here ,remember radio caroline ?on 199mw
Jun 06, 2012 | Toshiba Televison & Video
My Technika freeveiw hd box keeps going to standby could it be because it is turned off every night, does it need a perminant power supply?
freeview boxes generally update around 3am every night so yes you maybe correct as to the cause of it going into standby. It has to go into standby to update itself, same as when windows cant update because files are in use. try leaving it in standby at night and see if that resolves the issue
Mar 04, 2011 | Televison & Video
Connect lg m1962d for freeview
Hi, you should be able to receive it. There should be a button, either labelled TV or DTV, that will flick between normal ariel viewing mode or DTV.
Have you tuned everything in?
You should be able to get all channels.My Father in-law uses a seperate box with an indoor arial and gets everything crystal clear.
I fyou need more help - then please ask.
Tony
Jun 06, 2010 | LG Televison & Video
Problem with digital tv
The Antenna may be in a weak signal area heres a quick cheap fix
Get a Freeview Box and connect it via SCART LEAD to your tv, if the Box picks up a good signal then your tuner may be very weak..
You may want to try a BOOSTER to the TV first, and if that fails go with an external freeview. My neighbor has a 42 and the freeview box WITHOUT an antenna attached resolves all the channels..so give that a try. I have a goodmans too with a slow tuner and I have to retune it sometimes even though it gets a good signal from the antenna. I will be getting an external tuner freeveiw box.
Apr 15, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
After attaching a freeview box to my Acoustic Solutions LCD32NK750HD 32" inch LCD HD TV the picture started to scramble and **** about the screen, this would stop when I turn the TV off and back on...
How have you got freeveiw connected to your set and what input are you using?
when connecting the freeveiw unit to the tv did you have the power connected and turned on to either tv or freeveiw?
how many sets are connected to the freeveiw unit,
All these things can affect this equation,
it sounds like the set had a power surge from the plugging in of the freeview,
the f connection output from the freeveiw set has a live voltage feed that powers either the mast head amp or the balun in the center of the dish,
for these to work correctly the cable between the freeveiw and the aerial/dish needs power,
this annoying little fault can only be remedied by taking it to the repair man,
Let us know the outcome thanks ,
hope this helps,
Jul 19, 2008 | Televison & Video
Remote control codes for freeview and dvd recorder
According to the booklet you have to enter the code 119 for a Goodmans TV, however it does not work with my Goodmans portable TV and even quick search / autoscan doesn't find the TV.
Nov 25, 2007 | Jensen JER-422 Universal Remote Control
No sound
If I remember correctly, this model can only have sound from either the SCART or the standard input. The solution for this set is to have all the devices work through a common A/V switch box.
The best solution is to update the set to one with more active inputs that are adequate for your needs.
Jerry G.
Nov 19, 2006 | Sony KV-32S26 32" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
