Question about American Standard Lifetime 54 1/2 In. x 54 1/2 In. Corner Whirlpool, Linen
American standard toilet running
I have an American Standard toilet circa 1999 with a float apparatus I am unfamiliar with. It has a yellow plastic bulb shape on the stem that seem to house the shut-off. It has a horizontal seam that is no longer fitting together. The water hose coming off the top clips onto the side of the overflow tube. I cannot figure out how to get this model to shut off. I turned off the water supply to the toilet, but need advice on fixing the float. Thanks.
  • Jimmy James May 11, 2010
    Did you try to adjust the float?
    This is the small screw at the top of the arm
  • 323 Answers
There should be two screws on top of the assembly to control the level of the water. One increases, the other decreases. But if the bulb has a horizontal split it will have to be replaced. It simply screws of and on the arm. The water hose clips to the drain tube and the water should be directed inside the tube.
Buy a bulb, and if nothing else, bend the arm down to decrease the level of the arm and bulb and consequently the water level.
Posted on Jun 04, 2009
Do you turn the screw to the left or right on a american standard toilet to adjust the water level in the toilet tank
Usually to the right will drop the float, deceasring the water level, left will increase the water level.
Aug 25, 2014 | Cadet Manufacturing American Standard...
My brand new toilet american standard round front model cadet 3 tank not fill water
If you verify that the water supply to the toilet is turned on, push down the float on the flush valve. Water should start flowing. If it doesn't, something (such as debris) may be blocking the valve and preventing filling. The new valve could be defective - permanently closed.
Jan 11, 2013 | American Standard Cadet 3 Right Height...
Bought a aqua option toilet dual flush from American Standard the tube that usually goes into the overflow tube now rides on a float which rises with the level of water as it gets closer to the overflow...
i have the same issue with my aqua option toilet. if you have a water shut off installed on the supply line to the toilet, just close it enough to reduce the supply pressure. no more splashing.
Nov 17, 2010 | American Standard Home
Yellow attachment to flapper in Cadet 3 toilet tank
Some toilet flappers are designed with this some are not. It has to do with the particular flapper design, helping the flapper to stay in the open position to allow a better flush. Anyways you should be to adjust this float up or down to optimize it's usefulness. Trial and error is all you can do, keep watching and flushing until it no longer gets in the way. I hope this helps in at least knowing that for your toilet and the flapper you have, it's suppose to be there. Good luck and thanks for using FIXYA and have a great weekend. Jeff
Apr 09, 2010 | American Standard 4112.016 Cadet Toilet...
We have american standard toilet model 4260 that runs all the time. have replaced seal twice. toilet is only 2 1/2 years old. what do we need to replace?
if it doesn't fill, it's your flapper, if your tank is full then you'll need to adjust the float. take a look on amazon for those 2 parts, and read into reviews. here: Modern Shower Doors at Amazing Prices. cheers
Sep 19, 2009 | Home
American Standard Champion toilet keeps running
Readjust the float. the longer it is the more leverage the fill water will have on it. good luck. The fill valve does come apart and cleaned if there is debri in it. Turn the water off first:)
Jun 15, 2009 | American Standard Home
Water Tank Will Not Stop Running Water
the reason your water keeps running is because the float has not closed of the valve in the stem on the left side. a quick fix is i take the rod that has the float on it and bend it down a little. i also make sure that the plug that fits over the drain seats properly alot of times through age the plug tends to harden up and not seat properly. if you cant get it to seat replace it. if your model has an adjustment screw on the valve body try adjusting that as well.......good luck please rate this
Sep 01, 2008 | American Standard Colony 2388.012.222...
American Standard Lifetime 54 1/2 In. x 54 1/2 In. Corner Whirlpool, Linen Logo
431 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
