Question about Denon Avr-5800 Home Theater 7.1 Channel Surround Receiver Processor 200 Watts
I Have a Denon AVR-5800 and one of the circuit boards is broken in 3 pieces and prevents the receiver from turning on. Does anyone know where I could find a replacement circuit board for this beast reciever?
  • 163 Answers
New board is not available. you need to find a parts unit in ebay.
Posted on Oct 14, 2013
3 Suggested Answers
  • 6 Answers
SOURCE: denon avr 5800
I can help you solve this problem. However you must describe to me which fuse you have replaced. Is it the fuse on the power line or is it a fuse in the speaker line (which I highly doubt). usually this type of amplifier uses two technologies. One is transistors the second is integrated chips. This is in regard to the output stages. I assumed you speaker cables shorted each other while the volume was set at a high level with music playing. Anyway if you are willing I am able to help.
Posted on Sep 01, 2007
  • 5 Answers
SOURCE: Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
Posted on Mar 09, 2010
DENON AVC-A1SE owner's manual to download
i do not know about the supply transistor for denon avc-a1se
Aug 01, 2010 | Denon AVR-5800 Receiver
AVR-1508 7.1 Channels Receiver: My Denon AVR-1508 won't stay on. Once I try to tak...
Not familiar with this model but seems like the protection circuit is kicking in, this could be caused by an imbalance of Ohms between channels or a short. remove & check all speakers and cables for continuity or shorts, does the unit power on without speakers or in a different mode (surround off).
always add speakers in pairs (L&R) before testing to prevent possible protection circuit, test main speaker pair first then add surrounds (all according to the allowable Ohms range for the amp of course)
Nov 18, 2017 | Denon AVR-1508 Receiver
My Denon AVR 3806 keeps turning itself off, why?
Your receiver has short circuit somewhere. The protection circuit shut off the unit to prevent more damage. You can try to disconnect all speakers. If there is not improvement, you need to send your receiver to repair.
Jul 06, 2009 | Denon AVR-3806 Receiver
Protection circuit momentary activation. Not heat/speaker problem
Is it possible for you to lower the source level? if yes go ahead...
There is an automatic Dialogue normalisation function in Denon which is activated to reduce overly bright input signals. ( most movies have wide variation in sound levels and therefore this function is avaialble). (see page45 of your user manual).
When your system worked fine with the AVR 2808CI, then why is it giving problem with AVR 3808CI....???? You must ask Denon.
Protection circuits are activated when:
1). There is rise of internal temperature.
2).Core wires of the speakers are touching each other or a core wire is sticking out of the terminal and touching the set's rear panel or the speaker itself has a problem.
3). Speakers with an impedance other than specified are being used.
or
4). the set is damamged or has bad solder / dry solder connection .
If your AVR is new, please do not accept, the set could be faulty. The protection circuits should not be activated unless any of the above happen.
You must know, at times the protection circuits are not fast enough and it could burn some of the transistors on the power output circuit. With time, the solders on the circuit board could give way and give you problems later on.
You must sort out with Denon if the AVR is under warranty.
Best of Luck.
Mar 11, 2009 | Denon AVR 3808Ci Receiver
My Denon AVR5800 Receiver Shut itself off after I turned it on?
This amp is going into protect mode as it is sensing an internal overload,needs to be repaired...
Jan 08, 2009 | Denon AVR-5800 Receiver
Remote control problems with Denon AVR-5800
its one of the advance model once open the remote and clean it other wise u can check with the remote receiver showing any blinking while use
once crosscheck it
Nov 09, 2017 | Denon AVR-5800 Receiver
Denon AVR-681 receiver
this manual is the same as the 681 the only difference is the front input and power difference. this web sight http://www.usa.denon.com/AVR1602_682_ownersmanual.pdf
Jan 13, 2008 | Denon AVR-681 Receiver
Denon Avr-5800 Home Theater 7.1 Channel Surround Receiver Processor 200 Watts Logo
159 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
