Question about Samsung Receiver Ah63-02058n
I NEED a speaker connector wire for two of my remote speakers for model number AH6302058n. Is it possible to purchase just the wires and connectors or will I have to purchase a whole new unit as best buy geek suggested?
SOURCE: Samsung htz310 home cinema system, speaker cable problem
If it's just the speaker cable, it's an easy fix. There are two strands of wire for each cable. I would cut the cable at the break, seperate the strands carefully about two inches in each direction, either by pulling them apart, or by using a knife, being careful to preserve the insulation around each strand (sometimes pulling apart the strands will pull the insulation from one side or the other depending on how fragile it is - I usually just start the seperation with a knife, and then pull them apart slowly). Then you can strip back the insulation about an inch on either side of the break on each strand.
To strip back the insulation, take a sharp knife and cut through the insulation by cutting around the wire on each strand about an inch back in both directions being careful to not cut through the wire. A few of the strands won't make a big difference, but if you cut too much it may be best to start over.
Once you have about an inch of wire exposed on each strand, you can intertwine the wires to put them back together. Just hold the bare ends of each seperated strand side-by-side and twist them together. If you mix up which strands are which, mark one of the sides with tape or a sharpie to make sure you twist the right ends together. Usually there is a white stripe on the positive strand, or some other marking that runs the length on one side only, so that's a good guide for putting the right wires back together.
Once that is done, you need to isolate the bare wires from each other. I usually bend them parrallel to the cable in opposite directions, and then use electrical tape run between them and around each strand. Once they are isolated and not in danger of touching, use some heatshrink tubing around the whole patch to make it lasting and durable. It won't look pretty, but it will work just fine. You can find heatshring tubing at Radio Shack. Just slide a big enough piece to cover the repaired area on from the end of the cable without the connector, and then use a hairdryer to shrink the tubing around the patch. If you don't have a hairdryer, you can use a match or candle. Just be careful.
Alternatively, you can just wrap more electrical tape around the whole area in a diagonal, but tape isn't nearly as durable a patch as heatshrink.
Hope that helps.
Posted on Apr 21, 2009
PC Commando
  • 142 Answers
SOURCE: what speakers can be plugged into a 46 inch
On the back of the TV there should be a variable audio out this will control the volume level on the speakers or at least it should
Posted on Oct 15, 2009
  • 3 Answers
SOURCE: Need wiring map for RJ11 conector for Samsung SOD-14C camera
I guess this is an ongoing issue with Samsung cameras. Did anyone EVER figure this one out?
Posted on Mar 31, 2010
  • 109 Answers
SOURCE: VGA connector wiring detail
Pink - red input - pin 1 green - green input - pin 2 blue - blue input - pin 3 ground shield wire - pin 6,7,8 and 10 black - ddc 5v - pin 9 violet - screen raster - pin 11 white - data or sda - pin 12 orange - clock or scl - pin 15 yellow - vertical signal - pin 14 clear - horizontal signal - pin 13
Posted on May 17, 2010
SOURCE: Samsung home theatre system HT-TZ422 - rear speakers don't work
I bought the system samsung HT-TZ 422 but wireless receiver module is not connected spikers or not riding tx card.Sound test system is show all spikers but from wireless module is not hiring.When can i get any hepl.
Thanks.
Marek.
Posted on Aug 22, 2010
I have a 96 escort with no radio ;the wires are there,but i want to install a new radio.i don't know what wires hook up to the new radio
Hi, if the connector is still there, it is easiest to purchase a ford wiring adapter. The adapter will match the factory wires to an aftermarket stereo. If the connector is gone, see your factory wire colors below. Please let me know if you need additional help or have any questions, and thanks for using FixYa.
1996 Ford Escort Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Left Front Speaker Positive Wire (+): Violet
Left Front Speaker Negative Wire (-): Blue/Orange
Right Front Speaker Positive Wire (+): Blue/White
Right Front Speaker Negative Wire (-): White
Left Rear Speaker Positive Wire (+): White/Blue
Left Rear Speaker Negative Wire (-): Red/Blue
Right Rear Speaker Positive Wire (+): White/Green
Right Rear Speaker Negative Wire (-): Blue
Apr 18, 2011 | Ford Escort Cars & Trucks
NEED LONGER SPEAKER WIRES- IS IT POSSIBLE TO ORDER
Yes you can goto www.Bogue-Engineering.com
and they will make custom length cables with the special connectors for you.
Jan 03, 2010 | Sony DAV-DX255 System
I need help I don't know what color wires go to what wires on my sterio deck
I have a radio wire connector on a 1994 Toyota Camary and the color don' match your list, here is my list.
2 reds, one silver dot, one double silver dot.
2 blacks, same as above,
2 greens, same as above.
2 whites, same as above.
2 browns, same as above,
1 white w/green stripe, two silver dots
1 black w/red stripe, one silver dot.
1 yellow, two silver dots.
1 blue, two silver dots.
the numbers on the connector are A02 16 14 11264 9 8.
I'm clueless which wire are which.
Oct 30, 2009 | 1994 Toyota Camry
I have a 1993 chevy lumina that I want to put a Clarion radio in, the original was stolen along with the wiring harness, so I only have bare wires exposed, what parts do I need to purchase?
You can purchase a small package of crimp connectors for the electrical connections. If the wires are exposed, you can connect them using this following list of connections.
These are the CAR's wiring (not the radio unit)
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Look on the owner's instructions for the radio, the wiring diagram should be there. If not you can visit the clarion website with the radio model number to get the color codes for the radio wiring..
Simply crimp each to the correct corresponding wire. You may have a few extra.. the antenna power, or the radio mute.. just cap the ends of these..
K
Sep 17, 2009 | 1993 Chevrolet Lumina
Need connector to a sony sa-va1 right and left speakers
Are you looking for connectors on speakers or need wires that hooked in speaker and home theater system?
Please intimate model number that is written on main home theater system to provide you info about speaker wires.
Jul 11, 2009 | Sony SA-VA1 Rear Speaker
I Need the Wiring guide
1992 Saturn SL2 Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Car Stereo Illumination Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amplifier Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6 1/2′
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
May 21, 2009 | 1992 Saturn SL2
Need to know how i can set up the diffrent settings on my yamaha
The answer to this problem should be in the owners manual for your product. Check the speaker wire connections and the speaker wire for possible broken connection points. Try moving the wire around and see if you get sound. If you do then you need to replace the speaker wire. If not then you need the connectors you are using on the wire that are making contact with the speaker and receiver. They all must be making good contact with the speaker wire to keep a good connection.if you find no problem with the speaker wire and the connectors, you need to try another speaker on the the wires to make sure that the connection is working.If all the connections are good and you are getting signal from the output, you have a problem with the speaker. If you have a warranty for your speakers then have the bad one repaired or replaced under warranty. If not you can try to repair the speaker by opening the cabinet and checking the input connections from the Input wire connector to the speaker. See if it has any cold solder joints that may not be connecting the signal to the speaker. If the connections look good.You need to look at the speaker itself and the electronics that may be use in sending the signal into the speaker. Look for bad or broken connections in the speaker and the components. The drive circuit may have failed and need replacing or the speaker itself may have a broken or a burnt coil. If this is the case you may want to replace the speaker. Take all the information printed on the speaker and the information in the owners manual on the speakers and write them down on paper and try to find a speaker that matches the specification. Buy it and replace it for the bad speaker.You can find information on you receiver on the www.yamaha.com website by using the customer service section and putting in the model number of your receiver. Check out the frequently asked questions and troubleshooting sections and see if someone else has had this problem or similar one and has had a solution printed.The number for Yamaha service centers is 1-800-492-6242 and for buying parts is 1-714-522-9888. You can use these numbers to get help from the service center in your area or buy parts for repairs from the dealers. I hope this helps you with your problem.
Feb 18, 2009 | Yamaha HTR-5830 Receiver
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
Samsung Receiver Ah63-02058n Logo
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
