Question about Maytag 22 Cycles Topload washer, SAV365Z
Clips front put on - Maytag 22 Cycles Topload washer, SAV365Z
Left front tire became loose of snapper sr120 rear engine mower and i need to put it back on. tried to put on and it is a very tight fit. figured it might be easier to take off tire and wheel and then...
Should just be a clip ( usually an r or c clip ) remove the cover to expose the clip use a screw driver to pry the clip out of its groove remove the washer, the wheel should then just pull off.
Forgot to say jack the front of the tractor up before attempting to remove the wheel.
Nov 15, 2017 | Garden
How do I access drain pump
take out two screws on top control panel,either in the back or in front or you might have to pop off covers on left and right side of panel and then you'll see screws,the panel is on hindges,lift it up,now you'll see two metal clips put screw driver in the front part of clip and push screw driver back towards panel and clip will release,remove lid switch wire clip and pull the frame to you and move it out of your way,look down under the front of tub and remove the two metal clips holding pump on
Nov 02, 2009 | Kenmore 22422 Top Load Washer
CD STUCK
There is always a hole on the front of the drive. Put a pin thru it and press (not very hard) and the drive lock will unlock.
Aug 01, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
The drum will not turn when you start the dryer. The belt will need to be exchanged but how can I access the belt?
You have to open the cabinet and remove the front. Some have screws through the front, others have the screws on the inside that are accessed after raising the lid. To open the top slide a thin flat blade under the front of the lid and feel for the two clips several inches in from the corners. Push straight in on a clip while pulling up on the lid at the front edge and it will release the lid at that point. Do the other clip. Lift the lid. If you don’t see the screws on the outside, they on each side on the inside holding the front tight. With the screws removed, pry out by each of the push clips on the side. The front should be come loose. Swing it away slightly paying attention to the wires to the door switch. Slide the new belt over the drum and work it to where it ran in the past. Put the front back on and snap the lid down. When putting the front on guide the front panel and the drum together at the felt seal. Open the panel on the back near the motor. Reach in and spring the belt tightener over and put the belt around the motor pulley. Let the spring tightener tighten the belt. Put the cover back on. If there isn’t an opening on the back to access the motor pulley, you have to reach under the drum from the front to thread the belt onto the motor pulley. When putting the front panel back on you need to guide the drum and the front panel together at the felt seal around the door opening. Vacuum the cabinet well while it is open and make certain to unplug the power cord and turn the gas off if applicable.
Jun 07, 2009 | LG DLG3788W Gas Dryer
How do you open the dryer to fix the belt
First before you you raise the top, open the cover on the back by the motor and let the belt loose from the motor pulley unless the belt has broken. If it has go to the lid. Slide a thin flat blade under the front of the lid and feel for the two clips several inches in from the corners. Push straight in on a clip while pulling up on the lid at the front edge and it will release the lid at that point. Do the other clip. Lift the lid. Three are usually two screws, one on each side holding the front tight. With the screws removed, pry out by each of the push clips on the side. The front should be come loose. Swing it away slightly paying attention to the wires to the door switch. Slide the new belt over the drum and work it to where it ran in the past. Put the front back on and snap the lid down. When putting the front on guide the front panel and the drum together at the felt seal. Open the panel on the back near the motor. Reach in and spring the belt tightener over and put the belt around the motor pulley. Let the spring tightener tighten the belt. Put the cover back on.
Jun 06, 2009 | Maytag MDG6000 Dryer
Grill removal
the lower clips are pushed down with a long screw driver from the front , when the grill is removed the clips need to be removed from the vehicle and put in the grill then push the grill in
Apr 18, 2009 | Mitsubishi Pickup Cars & Trucks
How do I replace the drive coupler on a Whirlpool washing machine
he took the cabnit off???...ok now kneal or stoop straight down,,always unplug unit..now your looking at the pump ,,theres 2 clips holding pump on 1 upper and 1 lower take a small screw driver and pry them off twist just a touch ,let pump hang dont remove ,,now your looking at the motor ,,it also have to clips but there longer and they have to screws holding them through front...take your 1/4 nut drive and remove,,if you dont have nut driver pliers will do just take your time..now reach to your right side of motor and disconnect motor ,,put a little pressure with your hand and pull straight out...take the motor clips off the same way you took the pump clips off,,now you should have 2 plastic couper and 1 rubber grommet...remove broken pieces than put 1 half the plastic coupling all the way on the transmission line it up straight then knock t in with he back of your screw driver use another tool to knock with..now put the other coupling on the back of the motor the same way..take the rubber grommet and put it on the transmission side,,you must look and line teeth up with hole since the grommet is on 1 coupling you only need to line up motor have,,,now take 1 motor clip and put the bottom 1 back before you put motor back let it lay on floor,,put the top clip close ,,now left motor and push to the tranny coupler now put back top clip...reverse to put together..
any question fell free to contact me
Dec 28, 2008 | Whirlpool Washing Machines
How should the drum door be fasened is there an order of how the clips should be put on? 9537
i think you mean the tub front held on with clips.
put into position and fit first clip at top. fit clips at each side then fit a clip at bottom. after that just work your way round
Oct 02, 2008 | Hotpoint Washing Machines
I want to change my kenmore washer water pump. How/where can I get diagram and step by step instructions?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Lean the machine so that the front is up enough for you to get under and see the pump just inside the front of the washer.
Remove the 2 retaining clips from the pump. Now take off the 2 hose clamps. remove the hoses to the new pump and put the clamps on. Put the retaining clips into the motor housing, install the new pump. Now attach the retaining clips and you should be good to go. Hope that helps
Regards
Sep 08, 2008 | Washing Machines
Will not drain
If your GE Washer is like mine all you need to remove the front is a 2 inch putty knife. Insert it in the seam between the top and front panel about 6 inches from the corner. You will find a clip there. Push the clip backwards with the putty knife while pulling gently on the corner of the front panel, the clip will come loose and the front panel will come froward on that corner. Repeat the procedure on the other side and the front panel will come right off. To put the panel back on just insert the bottom of the panel in the bottom clips and snap the top right back into place. This makes access to the inside of your GE washer a breeze. Before doing this always disconnect your electrical plug.
Dave
Jan 13, 2008 | GE WBSR3140DW Top Load Washer
Maytag 22 Cycles Topload washer, SAV365Z Logo
15 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
