Question about Goodman CLQ36AR49 Air Conditioner
Chevy 2002 silveraldo 1500 keeps burning coil packs as burnt 3 new coil packs in 1000 miles
    New Friend:
Voltage regulater in the altanator
Posted on Oct 14, 2013
2002 v6 chevy silveraldo keeps burning coil packs quickly please help
coil packs and coils burn out from over voltage supplied to them --Ie 12 volts to a 7.5 volt coil. I would check the voltage in the supply wire connections and check the required voltage from the cpu /ECM. Run fault codes and look for a short to ground situation
Sep 28, 2013 | Chevrolet Chevy Cars & Trucks
Number three coil pack keep burning up
is there oil leaking into that plug area?
Jun 15, 2012 | Cars & Trucks
Coil burning on 2001 Dodge durango
Maybe some bad wiring in the coil pack receptacle going to that coil?
Strange problem you have there. Let us know what you find.
May 23, 2012 | Dodge Cars & Trucks
My 1999 chevy silverados 1500 transmission changes from first to second but wont change from second to third. Tried shifting manually and no results. My transmission fluid level was fine and put a quart in...
Hi :) Sound like a rebuild is coming. The transmission in that truck is 4L60-E and they have a habit of doing this from ware. What happen's is that the pressure regulator and boost valves get sloppy in the pump and the pressure drops and burns out the 3-4 clutch pack and another thing that can happen if there is not any burnt smell to the fluid is a steel 1/4 inche ball could have got stuck in the valve body seperator plate and is not allowing fluid pressure against the 3-4 clutch pack piston.Take it in to transmission specialist he might be able to save it.
Mar 21, 2011 | 1999 Chevrolet Silverado 1500
2002 chevy truck headlight problem (no lights) replaced turn signal cluster. Found burnt wire here. check relay it is ok? Where do I go from here.
If burnt wire is present then there is most likely more undescoverd burns. Make sure your fuse is ok and trace the burnt wire there may be some still needing to be changed out.
Mar 02, 2010 | 2002 Chevrolet Silverado 1500
Having problems with 2002 chevy silverado 1500 won't stay running. cut out going down hiway then died will run a while then die is this the fuel pump
Start with the simple and replace the fuel filter first. If it was the fuel pump, and being electric. It would have not restarted again if the pump has gone bad. The fuel filter should be replaced every 1,500 miles or once a year to ensure that your fuel system is running 100% and will not burn out your fuel pump early due to extra heat generated from working harder then is should. Good luck and keep me posted.
Feb 22, 2010 | 2002 Chevrolet Silverado 1500
Blower motor or resistor?
I had a truck about the same year with the same problem, it was the wiring harness, but id check the resistor and the fan first before replacing anythings,
May 20, 2009 | 2002 Chevrolet Silverado 1500
Goodman CLQ36AR49 Air Conditioner Logo
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
