Question about Viore 42" 1080p Led42vf80 Lcd Led Hdtv
Cable box on but no signal from hdmi - Viore 42" 1080p Led42vf80 Lcd Led Hdtv
    New Friend:
    Problem Solver:
  • 9 Answers
Check hdmi cables first then its the box going bad.
Posted on Oct 14, 2013
My digital tv is saying no singal whats the problem and how do I fix it? we have a huge antenna on our roof
1 – Is the NO SIGNAL issue happening on just one TV?
CORRECT INPUT or SOURCE
If it is just one TV that is showing the NO SIGNAL…
-Be sure your TV is on the correct source or input as your CABLE or SAT BOX.
-Press the TV button on TV remote control to turn your TV ON.
-Press the INPUT button on your TV remote control.
-Cycle through all the inputs on your TV.
-Do this until you are on the INPUT your CABLE or SAT BOX is plugged into.
-You should then see the CABLE or SAT programming show on your TV.
HINT: Your TV will most likely list the TV INPUTS as: HDMI 1, HDMI 2, HDMI 3, VGA, Component 1, Component 2, and so on.
If you still see NO SIGNAL on your TV screen, see the next step below…
2 – If you have your TV on the correct INPUT or SOURCE and you still see NO SIGNAL…
CABLE OR SAT BOX NEEDS RESET
-Remove or unplug the power cable from the Cable TV or SAT set top box.
-Keep it unplugged for 2 to 3 minutes.
-Plug the power cable back into your Cable or SAT set top box.
-Give it some time for the Cable or SAT box to power up, get the signal, and initialize.
3 – If you have reset the Cable or SAT box and still have the NO SIGNAL…
UNPLUG THE CABLE GOING FROM THE TV TO YOUR CABLE OR SAT BOX
-Remove the HDMI cable or other cables from your Cable TV or SAT set top box.
-Keep the cable unplugged for 2 to 3 minutes.
-Plug the HDMI cable or other cables back in.
-Give it some time for the Cable or SAT box to get the signal and initialize.
HINT: Make sure all the cables that are connected to your Cable or SAT box and your TV are tight, undamaged, and secured.
4 – If all of your TVs are affected with the NO SIGNAL screen…
BE SURE THE COAX CABLES OR ETHERNET CABLES ARE SECURE or CABLE OR SAT IS DOWN TEMPORARILY
-Be sure to check the ones where the CABLE or SAT come into your home.
-Be sure ALL Ethernet and Coax cables are secure.
-Call your CABLE or SAT provider to see if there is an outage.
-Realign your Dish if you have SATELLITE.
May 10, 2017 | Televison & Video
On my LT42HVi with HDMI input source, the image comes through with a lot of green then will change back to normal color. Switching cables or HDMI input port makes no difference. Using normal TV inpu
is the normal tv input for high definition? Don't understand that term. I have a dish receiver, when I use an hdmi cable I get a really nice picture even with Roku
Jan 02, 2015 | Olevia LT42HVi 42 in. LCD Television
Can record Sky programmes but not view live.
You must connect up the TV to the SKY box, via Audio Visual cables too, in order to watch, recorded programs. You need to hook, up, Component, HDMI, or Composite, You select it by an EXTERNAL channel.
Connect the cable running from the wall into the "In" port on the Sky Box HD receiver. This cable brings in the signal to your receiver. Make sure the cable is securely fastened to the receiver, otherwise you might experience image and audio issues.
Attach an HDMI cable into the HDMI port on the Sky Box HDTV receiver. The HDMI is a single cable that provides both HD audio and video signals.
Plug the other end of the HDMI cable into an available HDMI port on the HDTV.
Power on the HDTV and the Sky Box HDTV receiver. Press the "HDMI" button on the TV's remote control. This will display the cable contents of the HD receiver onto the television.
May 08, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
What is the correct wiring connection using hdmi and optical cables from a lcd tv to yamaha yht292
If you tv has a hdmi input, connect it to the Yahama receiver hdmi output (out). If you are using a satellite receiver, digital converter, or a cable box with hdmi output(s), connect them to the Yahama hdmi input (in) for video and audio signals. If the above box(es) do not have hdmi capabilities, then connect the box(es) to the Yahama with either component (preferred), svideo, or yellow RCA compsite video jack (least preferred) for the video signal. For audio, connect the box(es) with optical or coax (preferred) or left-right-center-front-rear patch cords.
It really all depends on what outputs are available on the boxes and/or signal source(s).
Hope this helps,
Rhais
Sep 19, 2009 | Yamaha YHT-390 Theater System
Bad picture
  1. Hello boss, here is d way to make best use of it.
    step 1.Make sure ur LCD or Plasma HDTV has an HDMI port. Hopfuly u bought 1 with it, if not, you may be stuck using component cables. Not bad, but not he best. Component cables change d digital signal frm the cable box into an analog signal. This conversion allows for signal degradation. U want to keep the digital signal transmitted frm the cable company 2 go directly into ur HDTV. An HDMI cable will provide u wid this capability n with d clearest picture.
    2. Make sure ur cable box has an HDMI port. Most cable companies do not offer a cable box with an HDMI port on the initial install. You may need to upgrade by calling your cable company and asking if they have a cable box wid HDMI capability. Ask them 2 send u 1.
    3.Purchase an HDMI cable. TIP - The longer d distance between the cable box n d HDTV, the better d quality HDMI cable. This is due to degradation of d digital signal over long distances, wiz could result in a poor quality picture. ne distance over sixteen feet should be compensated 4 by using a heavier gauge HDMI cable. Oh yea, don't get taken by buying the most expensive cables. From what I have read, companies are cashing in on this relatively new technologymag-glass_10x10.gif. I bought my "gold-plated" HDMI cables from an Ebay Store, "eforcity" for about a quarter of the price found at the local electronic store. Connect one end of your HDMI cable into the HDMI (out) port on the back of your cable box and connect the other end to the HDMI (in) port on the back of your HDTV.55
    Read the instructions that came with ur new HDMI compatible cable box. These instructions will explain the download process the cable box needs to go through before use and the Setup Wizard that will program the cable box to send the correct picture format to your HDTV. If u did not get instructions, u can get them at the cable box manufacturers website. Scientific Atlanta's website: http://www.scientificatlanta.com/products/consumers/new_cableboxes.ht64. Adjust video, audio, and screen settings to ur liking. The explanation for these settings can be found in ur HDTV's user's manual.75.Push ur "source" button on ur remote control or HDTV n select HDMI. Tune to a Hi-Def channel. Most Hi-Def channels r in the 700 channel range. Check cable company listings 4 d specific channels.
  2. Have a nice time!!
Aug 19, 2009 | Sharp LC46SB54U 46 in. LCD TV
Picture sound blackout (blink) when cable box/receiver HDMI used
Onkyo service told me, the second timethat I called them, that there is a known HDMI handshake issue with Motorola and Atlanta Scientific cable boxes. The only solution, and it was a solution, is to connect the box through the HDMI 1 port ONLY. All the other (2,3,4) result in blinking/dropping of signal. I did this, changed the cable/satelilte setting to HDMI 1 and all is well.
Apr 12, 2009 | Onkyo TX-SR705 Receiver
Cannot get a connection with HDMI input
When the tv won't scroll to the HDMI inputs, it means that the tv does not detect a signal on those inputs. This either means the tv has an issue and can't receive an HDMI signal(very unlikely) or there is no signal being sent from the source(converter box) The first thing I would do is unplug all output connections from the box except for the HDMI output and see if this gets rid of your problem. If not, I would be more inclined to think you have a problem with your converter box than with your TV. You could also try using the HDMI ouput of a DVD player if you have one.
Jan 14, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Says no signal when switched to hdmi when there is one.
Have the same problem with a 532H - but here is what I did to resolve the issue:
1) Click your Menu button on the TV remote.
2) Go to Screen (click the right button)
3) Go to Main Picture Source (click the right button)
4) Select HDMI (click the Menu button when done)
Aug 20, 2008 | Olevia LT27HVX 27 in. LCD Television
My best guess would be that the resolution settings on your reciever are set too high(It's putting out an HD signal the TV can't display) Plug in through Composite or component the the box and resolve this through you Cable box's menu, then reconnect the HDMI cable.
Dec 23, 2006 | Olevia LT27HVX 27 in. LCD Television
Viore 42" 1080p Led42vf80 Lcd Led Hdtv Logo
55 people viewed this question
Top Viore Televison & Video Experts
Tom Chichester
Brandon Murphy
George Scott
George Scott
Are you a Viore Televison and Video Expert? Answer questions, earn points and help others
