Question about Clarion Car Audio & Video
Usb cable for vitara suzuki - Clarion Car Audio & Video
2 Suggested Answers
  • 102 Answers
SOURCE: suzuki vitara kick down cable
From memory, the tranmission pan will have to be removed. This is messy, and care has to be taken to avoid contamination entering the trans. The cable has probably rusted from off-road use in water and now gear changes are very harsh and sudden.
Posted on Jan 01, 2010
Where can we find diagnostic socket?
OBD2 connector location in Suzuki Grand Vitara (1997 - 2005)
www.outilsobdfacile.com/...plug-connector-obd/Suzuki-grand-vitara-2
Easily find where your OBD2 port / connector is located in Suzuki Grand Vitara (1997 - 2005) ... OBD connector location for Suzuki Grand Vitara (1997 - 2005).
Suzuki Engines Diagnostic Connectors
codes.rennacs.com/Petrol-Engine/Japanese-Korean/Suzuki-Engines.php
Suzuki Engines - diagnostic connector locations, with detailed diagrams, text, and pictures of where to find the diagnostic connector in the vehicle.
Oct 14, 2015 | 1999 Suzuki Vitara
2006 Suzuki Grand Vitara Sunroof wont close & keeps blowing the fuse to get closed. Does it have a crank to close? Is there easy answer to fixing this without ripping taking the inside of the car out?
Suzuki Grand Vitara sunroof window Questions & Answers ...
www.fixya.com > ... > Tags > sunroof window > Cars & Trucks > Suzuki
Suzuki Grand Vitara cars & trucks sunroof window questions and answers. ... i have2006 vitara and my to eletric windows on both left and right doors are starting ... WILL NOT CLOSE THE BUTTON DOS NOT WORK HOW CAN I CLOSE THE ...
Search Results
    Sunroof won't close (1999 Grand Vitara) - Suzuki Forums: Suzuki ...
    www.suzuki-forums.com/...vitara-grand-vitara/44708-sunroof-wont-clos...
    Mar 31, 2011 - 8 posts - ‎2 authors Hi, Lately I've been having trouble closing the sunroof in my GV. Most of the time, it needs some fiddling to get it closed. It gets stuck at certain. Sunroof Not Working Properly
    Mar 27, 2015
    Forenza Sunroof won't open
    Feb 23, 2011
    New battery = new problems (sunroof, ac/heat)
    Oct 6, 2010
    More results from www.suzuki-forums.com
Oct 13, 2015 | Suzuki Cars & Trucks
Suzuki vitara blower
posted 5 times, a near record here, top record was 25.
alldata.com
log in, read the HVAC section
for testing the modes. on the dampers.
my guess, is you dislodged a cable.
May 07, 2014 | 2006 Suzuki Vitara
How to reset airbag light in a 1999 suzuki vitara
sorry dealer only ,try unplugging the cables under the seat and reconnecting them again
Aug 09, 2010 | 2001 Suzuki Grand Vitara
Suzuki vitara kick down cable
Dec 28, 2009 | 1999 Suzuki Vitara
I have an old suzuki sj 413 , i want to install power steering
The only way you may get this problem solved is to find a late SJ413 which may have had it, and graft it on. Yours will have leaf springs and you'll have find one of the last leaf-spring models at the wreckers. They may not have even come into your country with power steering - they didn't get released in Australia with P/S and the only way to find it was at a wreckers that brings in cars from Japan or the like. The cheapest way to have the lightest possible steering is to stick with the original width and offset rims, and to keep the tyre pressure up to 35-40 psi. The recommended is only 22 psi!
Oct 01, 2009 | 1986 Suzuki Samurai
2000 Suzuki Vitara 2 liter stalls when engine warm
The accelerator cable had slack in it a was right against the idle stop.
I adjusted so it was tight and was about the thickness of a sheet of paper off of the stop. Now it does not stall at idle when warm.
Sep 01, 2009 | 2000 Suzuki Vitara
2002 Grand Vitara engine light
Try these easy things...take off clean and reconnect the battery cables, take to Auto Zone for a FREE computer hook up. More than likely if the battery hook up doesn't work it's the oxygen sensor.
Jun 29, 2009 | 2001 Suzuki Grand Vitara
My suzuki vitara has check engine light on and is ok for water and i put oil into it as seemed bit low, but it wont start at all. pls help
Check if there's a spark in the cable going to the distributor. If there's none then you may have a problem in the ignition system components. A defective air flow sensor can also cause a no start. If spark is present, you may want to visit the fuel system of your car.
May 04, 2009 | 1999 Suzuki Vitara
1997 suzuki vitara. new battery now car wont start.
Assuming the terminals are hooked up correctly, are your cable ends corroded? Are you sure the fittings are clean and tight? If it was hooked up backward check your fuse box and hope it only fried some fuses.
Mar 14, 2009 | 1999 Suzuki Vitara
Car Audio & Video Logo
21 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
