Question about Kitchen Ranges
F1 error code on jenn air jds9860aap - Kitchen Ranges
VANMAN69
  • 23 Answers
SOURCE: F1-1 error on Jenn-Air Range
if it is the stove that is in the picture the fault codes are in the door under the oven door.
Posted on Jun 02, 2007
Oceti
  • 51 Answers
SOURCE: Jenn-Air Gas Range
F1 is a bad power relay board.
F8 is a shorted meat probe alarm (probe jack or the harness to the probe jack)
Posted on Jan 18, 2008
SOURCE: jenn-air manual
i have a jenn-air, SVE47600B, when you put power to the unit, the broiler element comes on and stays on. In the past, someone pried the door open, during a clean cycle. Than the unit would shut off in the middle of baking or broiling, so they called a service guy who took the wiring diagram when he left, he also unwired the door latch used during cleaning cycles. He told customer it needed a new control panel, the guy did not do the repair, he just unplugged the broiling element and used the stove top. So now i reattacted the door latch switch and hooked up the broiler element , then turned on power to the stove and sure enough the broiler came on and stayed on. with no wiring diagram and rusty skills i am looking for advice and help and maybe a wiring diagram. Went to sears web site and they have a control panel or a relay board(down draft), relay board (bake/broil).....pricing between 200-300$ each and i dont want to just throw money at it......HELP
Posted on Feb 15, 2008
  • 412 Answers
SOURCE: jenn air range stove jsg8750 have a f1-7 error code
Hi there...
Error F1-7 means --
Replace touch pad or clock assembly (also called the ERC).
Good Luck!!
Posted on Mar 20, 2009
SOURCE: Jenn-air JES9800 error code F1-7
As indicated by others, the best solution for most people is to replace the touch pad assembly.
I went the cheap - time consuming route.
Jenn Air JES9800
Using the information from this forum and others I decided that the F1-7 error message was due to the touch pad. When I saw the price of the assembly which includes the touch pad I decided to take a look inside. With the power off :-) I disconnected the touch pad ribbon connector from the socket. Using a tool fabricated from a broken hacksaw blade hot bent 90 degrees about 4mm from the end, re-hardened and sharpened to form a knive edge, I carefully loosened the touch pad around the perimeter. The touch pad is applied to the frame with a flexible adhesive, so I was able to pull it off slowly without permanent deformation.
I softened the adhesive with odorless mineral spirits and was able to remove the adhesive from the touch pad with paper towels. upon examination of the touch pad I noticed several breaks in the the printed traces. I carefully pulled away the laminate near the breaks, which were near the flexible ribbon connector from the touch pad. I used a the copper powder paint from a Permatex rear window defogger repair kit to (tediously) paint traces to complete the gaps in the printed traces. The outer trace, which runs around the periphery of the pad kept showing a very high resistance (> 5 megohms) until I scraped away a short light colored section of the printed trace and replaced that with the repair paint. The trace then showed a resistance of just under 1meg. I temporarily re-attached the touch pad with tape and the error code did not reappear. I set the clock and successfully tested several buttons.
Next step - seal the area around the trace repairs so I can get some more years out of the stove, until the next repair.
The cause of this is an obvious design flaw. The printed traces were all compromised in the area where there is no discernable protection over the traces, allowing moisture (I assume) to react with the conductive material in the traces.
Posted on Jun 30, 2009
Jenn-air elecrtic oven JDS9860AAP is slow to heat up and will not come up to temp.
Either you have an open element a burnt terminal lead or a bad control try setting on broil only the element should glow in bake the bottom element should glow while the top cycles on/off based on your description of a humming noise I would suspect the relay on the control board
Feb 16, 2015 | Jenn-Air Kitchen Ranges
Jenn-Air Range displaying Error F1-8
Did not find an error code "F1-8"
I did find these. Seems that about everything that can go wrong with a Jenn Air is related to the clock.
https://www.repairclinic.com/RepairHelp/FaultCodes/26/Range-Stove-Oven
Sep 22, 2017 | Jenn-Air JES8850AAS Electric Kitchen Range
Jenn-air dual fuel jds9860aap intermitently display blinks like it lost power, reset and it will happen again. originally started with a f9 code that has not reoccured. If the oven is on, it will shut off...
Sounds as if you have a bad ground or nuetral wire connection. Unplug and check the connections to your control assembly and the pigtail on the range. I have also seen displays on Jenn-air go bad as well.Replace the clock assembly.
Apr 19, 2011 | Jenn-Air JDS9860A Dual Fuel (Electric and...
F1E1 error happened repeatedly, jenn air says cut
F1 - E1
EEPROM checksum error
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
called ERC or clock).
Note: Applies to all F1-E...
codes except F1-E3.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Jenn
Air Range / Stove / Oven Fault Codes#ixzz19GMNtS3r
Dec 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
What des error cde F1 mean on a Jenn-Air D156 drp-in range
JENN-AIR
'Newer Style' Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Power to element relay energized during time of day display Wiring harness shorted or change power relay board (PRB)
Note: for double ovens, change second oven board
JENN AIR
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad)
Mar 22, 2010 | Food Processors
Jenn air range stove jsg8750 have a f1-7 error code
Hi there...
Error F1-7 means --
Good Luck!!
Jan 29, 2009 | Jenn-Air JGS8750 Gas Kitchen Range
Jenn-Air Gas Range
Dec 19, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
Electronic touch pad problems
From what your telling me, you have tried all the numbers and only 1,4 and 7 beep when touched. Also, the timer display was set at 0:00 when you started. Also, you followed the manual's instructions first, and looked in the back of your manual in the trouble section, and found no answer.
Did you timer ever work? If not, you should be able to a free replacement of the control panel module from an authorized Jenn-Air repair company. It may be a good idea to contact Jenn-Air first.
The timer shows only hours and minutes when first started. For example 2:05 is two hours and five minutes. It goes into the seconds mode only during the last minute.
Dec 01, 2007 | Jenn-Air JGR8875QDS Gas Kitchen Range
Jun 01, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
Kitchen Ranges Logo
259 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
