Question about Korg SP-250
Korg sp250 changing voicings - Korg SP-250
GM VOICE NOT PLAYING
Your best bet is to contact Korg. Here is their link-
http://www.korg.com/us/support/contact
Jan 01, 2016 | Korg X50 X-50 Keyboard
How to change a fuse on a korg Sp-250
There is no fuse inside SP250. If the unit can't power ON,there maybe damage to the adapter,adapter cord/connector,or broken fuse inside the adapter.
If adapter is in good condition, then the damage is inside SP250.
The possibilities are on regulator section.
Check all parts in this section (figure 1).
Also maybe there is a broken soldering joints at DC input socket.
change-fuse-korg-sp-250-fuxmm42irvf2p03kxwfdv02c-3-0.jpg change-fuse-korg-sp-250-fuxmm42irvf2p03kxwfdv02c-3-1.jpgchange-fuse-korg-sp-250-fuxmm42irvf2p03kxwfdv02c-3-3.jpg
Jun 01, 2014 | Korg SP-250
I have a korg pa 80 it have not sound
Initialization: N/A
Preload: Disk Load (6 Disk set available from korgpa.com)
ROM Check: Given on power up.
http://www.sweetwater.com/sweetcare/articles/initialize-reset-preload-korg-pa80-60
Apr 10, 2014 | Korg 37 MINI-KEY 8-VOICE...
How can i have dual voice on x5d korg? I lke piano and strings
Just go to COMBI mode.
Press PAGE+. The display may look like this :dual-voice-x5d-korg-lke-piano-strings-v3bkdlfzxxldunukh1pdnvp1-3-1.jpg
In the example above, A03 and A49 is a sound PROGRAM number.
OFF and OFF is a Layer 3 and 4, were not activated.
So in our example, we only activate two voices (two layers).
X5D can combine up to 8 voice. To view the Layer 5-8, press PAGE +.
To change the sound of your choice, move the cursor to the corresponding layer, use this button:
then change the value with the slider / value key (YES and NO):
You can also set the level of each layer.
Press PAGE + until a menu appears LEVEL.
Move the cursor and sets its value
May 30, 2013 | Music
Korg sp-250 randomly changes the voicing
When was the last time you changed the batteries? You may have gotten a pack of expired batteries the last time you replaced them. I suggest changing batteries.Jimmy
Apr 08, 2012 | Korg SP-250
Sp250 right outout seems to have broken and as a result there is no sound coming from the speakers on the keyboard or through the PA. If we use the left output through the PA - it works, Could you advise...
Check if headphone jack also has right channel dead... If headphones work on both channels, switch contacts on headphone jack MIGHT be the problem.
Jan 17, 2011 | Korg SP-250
Korg Pa800 Pitch break
This makes no sense as a problem... If you mean there is a point on the keyboard where the pitch changes, refer to your manual about "splitting" the keyboard. This is usually done at F# and allows either a different voice or pitch for the lower section of the keyboard.
Jul 25, 2010 | Korg Pa800 Synthesizer
Korg SP-250 Logo
88 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Korg Music Expert? Answer questions, earn points and help others
