Question about Westinghouse Electric LD4655VX TV
Reset parental code lock factory - Westinghouse Electric LD4655VX TV
Parental lock code
Most tv's can be reset when you unplug them. Unplug the tv and let it set for about 30 min and plug it back in. This should reset the code to factory default of 0000.
Mar 03, 2014 | JVC TV 50in ELED 1080P 120Hz
Key lock on
Hello
Your Dell tV can be unlocked by reseting it to factory reset.
To reset it to factory reset do the folloing.
Enter the TV main Menu.
Select Factory Reset to return the TV Menu settings to the factory default values
NOTE: Before you proceed with the Factory Reset, enter a four-digit access code. The Factory Reset and
Parental Control always share the same access code. The default Parental Control code is 3355
NOTE: Parental Control setting can be reset by doing factory reset
If you ar unable to do this proceedings, do the unlock method used for Philips, and your TVs kit is of Philips.
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Feb 01, 2011 | Dell W4201C 42 in. Plasma HDTV
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
Need to reset parental locks .tv is locked out
HELLO If you forget your ACCESS CODE NUMBER, use the factory code 7777 to erase your key number. This will
reset the access code number back to the factory pr eset (0000).
shaun
Nov 17, 2009 | Hitachi 65F59 65" HDTV
Someone changed the parental code how do i reset it the channels are locked out and i don't have the code
The factory code is 0000 Try using that first if not try doing a factory default reset through your TV setup options . I believe your T.V. input cannot be setup to HDMI to access the parental control submenu. If you can't reset it give Vizio a call and they will help you figure it out. That's what they get paid for.
Oct 25, 2009 | Vizio L32 32 in. LCD HDTV
Astar LTV32PRM
please call 323-7667-6030 I will try to go through with you how to clear the code.
Dec 07, 2008 | Astar Televison & Video
How to disable parental lock
Go in and reset the code.
Jul 02, 2008 | Televison & Video
Sansui dvd san4312
DVD players don't need parental locks. When a user places a DVD player in Parental Lock mode, they usually create a 4-digit access code to remove the lock. Without the manual, I can't tell you how to reset to factory settings...what you need is either the access code or to reset it.
If it came direct from the factory with a parental lock already on, try the code "0000". If you need more digits, just use 0 until all of the slots are filled. If 0 does not work, try all 1s or 9s.
May 03, 2008 | Televison & Video
MAnual/Reset Parental Control Code
According to the manual, "If you forget the password, you can erase your current password by pressing the number 8 button on the remote four times, thn press the enter button to confirm the setting. PASSWORD: 8888"
A picture of an unlocked lock indicates that Parent Lock is NOT active.
Parent Lock Levels:
1: Kid Safe 5 : PG_R
2: G 6 : R
3: PG 7 : NC _17
4: PG_13 8: Adult
It also says that it takes 3-5 seconds to reset the unit to the factory default. I hope this helps! Karen
Feb 17, 2008 | Durabrand Portable DVD
Westinghouse Electric LD4655VX TV Logo
18 people viewed this question
Top Westinghouse Electric Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Neil Frazier
Neil Frazier
Level 1 Expert
Are you a Westinghouse Electric Televison and Video Expert? Answer questions, earn points and help others
