Question about Cameras
Tasco trail camera
Will not turn on, power up. New Eneregizer Batteries, all with correct polarity, when I hold the power button it makes a buzzing sound and that is all.
  • 356 Answers
Check the battery contacts for corrosion. If corroded, clean them with an emery board or sand paper and try the batteries again.
Posted on Oct 19, 2013
advance
  • 107 Answers
SOURCE: camera wont turn on...gives beep sounds and green light glows when pressing power button
Does the lens extend in either of these cases? If there has been some malfunction in the lens and it fails to extend the situation can cause the camera to power-off in order to protect itself. Some cameras show error messages before powering off, others do not. Hold the camera up to your ear and turn the power on. Is there a series of mechanical sounds before the beeps? Hearing sounds but not seeing the lens extend indicates some sort of failure in the lens assembly. If you hear nothing then the problem most likely lies elsewhere, possibly a failed electronic component or something as simple as a loose connection. Check with your manufacturer for any recalls or technical bulletins, and see if they will service your camera under warranty. If not there are a number of repair facilitys available on the internet who generally have better rates than out-of-warranty service at the factory. David Millier Advance Camera Repair
Posted on Feb 27, 2007
SOURCE: won't turn on
Plug your camera into the USB port and conenct it to the computer. If your camera turns on, the problem is the Power On switch. The Power On button is very finicky (poor design). I found it best to use your thumbnail and fully depress the tiny black button and turn to to the left or right and hold for 1 second. Best if you do this with your hand over (above) the camera.
Posted on Dec 28, 2008
t00nz
  • 4738 Answers
SOURCE: Canon IXUS 100IS - 'Lens error, restart camera' message
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
Posted on Mar 20, 2010
  • 11967 Answers
SOURCE: My camera wont turn on (its not the batteries).
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 25, 2010
  • 3 Answers
SOURCE: i cannot reset the password on my tasco trail
To reset the password:
Turn unit on and wait for password prompt
Depress the and hold the enter button until camera switches into 5-digit password mode _ _ _ _ _.
Trail sentry systems will not indicate 5-digit mode on the screen, but will indicate _ _ _ _ instead of HHHH .
Press enter to confirm 5 digit mode
Enter 5-digit code 66214 and press enter button( trail sentry cameras will accept a 5th Digit after the 4th digit is entered in the _ _ _ _ screen.
Camera will now go into operating mode, and user can now program a new password from the setup mode.
Follow this link to see the user manual PDF:
http://www.bushnell.com/manuals/trail-scout/119000TrailSentry_manual.pdf
Posted on Aug 28, 2011
Finding model number on tasco trail camera
Hi!...
You can get the manual for this type of Tasco Trail Camera here:
Instruction Manuals Tasco Believe it
I hope this helps you!
Feb 22, 2016 | Tasco Optics
When is tasco trail cam model #119256cw actually turned on
I can't see why you'd need to, but it can't hurt. The settings on the camera will be preserved as long as the battery's are left in.
Jul 22, 2014 | Tasco 3 MP Trail Cam Game Camera 119213C
Turn my taco trail camera on and says wait nothing else how to fix this
I replaced batteries with 4 new duracells and it went into setup mode. Works fine now.
May 29, 2014 | Tasco 3mp Trail Cam Black-cameras
My tasco trail cam boots up with 4 dashes on display. Nothing else.
When you hit enter does it change the dashes to zeros? Default code is 0000
Apr 27, 2014 | Bushnell Trail Sentry 11-9200 Digital...
I have a tasco 3mp trailcam that i have not used in atleast 2 years can not remember the password please help
Aug 23, 2011 | Tasco 3mp Trail Cam Black-cameras
Moultrie cdc - 5.0 Trail camera appears dead. New batteries, but will not turn on?
According to Moultrie you can try a hard reset.
Take out batteries, and SD card, hold on button for 2 min.
Replace batteries and try, haven't tried it yet, but will
Aug 07, 2011 | Moultrie Cameras
I just bought a Tasco Digital Trail Camera - 119223C . During the setup my camera display also shows Loc and the SD Card flashes. The instruction manual does not reference this setup code. Does...
I just bought,last August, a Tasco Digital Trail Camera - 119223C . Took pictures until Jaunary 2011, my camera display shows Loc and the SD Card flashes. The instruction manual does not reference this setup code. Does anyone know what 'Loc' means? I tried to reformat card, I also so not get a Y/N option for formatting. I bought a new card and changed batteries. no change!
Nov 14, 2010 | Bushnell Trail Sentry 11-9200 Digital...
I have a tasco trail camera, and i need to know what driver i need to install so i can upload the pictures from my trail camera to my laptop
Okay, I spent a lot of time refusing to accept that I couldn't get my tasco trail cam to work with my computer. I did figure it out though, to my relief. Tasco's directions are a little vague, but here it is: turn camera on, don't connect it to usb port, yet. After it turns on, push menu button, now connect it to your usb port. Disregard when it asks about installing driver software. If you follow these steps your computer will recognize it as another drive and ask open folder to view files,etc.
Sep 06, 2010 | Tasco Snapshot 1025S Monocular
I have a tasco digitail trail camera. i inadvertantly changed passwordf i guess. it keeps giving me error. i cannot do anything to it on now. is there anything i can do
Aug 01, 2010 | Cameras
I cannot reset the password on my tasco trail camera
Nov 06, 2009 | Bushnell 11-9000 Digital Camera
Cameras Logo
182 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
