Question about Kocaso Sx9700
How do I restart my kocaso sx9700 tablet - Kocaso Sx9700
Why mmy kocaso tab woont turn on
you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
Support Troubleshooting Guide
Dec 28, 2014 | Kocaso Sx9700
My kocaso tab wont turn on whille charging
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
How do i do a factory reset on m752
To factory reset: 1. Turn off the tablet 2. Press and hold volume down and power simultaneouly. Hold it for 30 seconds until an Android logo will appear on screen then let go. 3. Scroll down by pressing Volume down and Volume up to select any from the selection. 4. Select Wipe Data/Reset and select wipe data again and wait till it`s done. 5. Go back to the menu and select reboot to restart the system. Once the tablet has been restarted it will all be back to default values.
Bets Wishes
check here:
http://office.manualsonline.com/support/other/tablet/where-is-the-reset-button-on-a-kocaso-m752-tablet-5408896#comments
- Don
Oct 31, 2014 | Kocaso M752 Black WiFi 7" Android Tablet...
How to factory reset Kocaso SX9701 tablet lost password and cant get through screen lock
There is nothing in the manual.
http://www.kocaso.com/manuals/SX9700/SX9700_User_Manual.pdf
If you set a pass code (or pattern) that you cannot remember, please enter the wrong password (10-20 times) until you are prompted to sign in via your google account. Please note, this will only work if you have already setup your google account on the tablet. If you have not set up a Google (or Gmail) account on the tablet, you will have to perform a firmware install, which will revert the tablet back to factory settings.
May 30, 2014 | Kocaso Tablets & eReaders
Hard reset Kocaso SX9701 password lost
Kocaso M760 stuck on android screen
Try Restarting Your phone....(removing your battery).
otherwise it is a software problem & re-installing is the only solution.
Mar 05, 2014 | Kocaso MID-M750B MID-M750B 7-Inch Tablet...
Too many pastern attempts
  • Volume Up + Home + Power
  • Volume Down + Power
  • Home + Power
reset your phone.try using these keywords after turning your device off. dont forget to remove the memory card. and remember you may lose the data
Nov 02, 2013 | Kocaso Sx9700
I have a Kocaso M1052 and I am unable to sign on to facebook, yahoo.
JUST SIMPLY RESTART YOUR COMPUTER THEN CHECK YOUR INTERNET AND WIFI SETTINGS ,RECONNECT TO YOUR WIFI THEN RESTART YOUR INTERNET OPEN SITED YOU FAILED TO LOG ON TO AND CLICK REFRESH THEN SIMPLY JUST SIGNIN AGAIN
Oct 12, 2013 | Kocaso 1016A 10" Android 4.0 1.2GHz...
Kocaso Sx9722 The operating system will not come up.. Only the word Android
Use the firmware for SX9701 at the bottom of the page http://www.kocaso.com/support.html.
There are instructions to follow and you may need to use the Phoenix Card self extractor. Links are all on the same page.
Jan 23, 2013 | Kocaso Sx9700
Kocaso Sx9700 Logo
Top Kocaso Tablets & eReaders Experts
CrisO
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
