Sharp TV 32j-s400 I have no remote for the TV's
Sharp TV 32j-s400 I have no remote for the TV's menu and was wondering if I can get to it without buying another Universal Remote.
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
If your present universal remote control have no setup codes, there is no other way, must buy a new remote control. But, you can get a try as last chance, by doing a code search method to your present remote control. If the remote control's memory has been programmed with any to synchronized with your TV, you can win. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Posted on Oct 14, 2013
MikeMaierTV
  • 206 Answers
SOURCE: Magnavox TV accessing menu without remote
There may be away but need the model number to narrow it down, most remotes can be found at www.vancebaldwin.com and for usaly under $20.00
Posted on Feb 13, 2008
SOURCE: Accessing Menu Sharp TV
I have a Sharp TV model 27F-S40 and also do not have the remote. I need to access the menu to change color, sound, etc.
Can I access the menu thru the channel or volume buttons on the face of the tv?
Bob
Posted on Nov 08, 2008
SOURCE: Phillips PC7225 Menu
Found it!
I have a Philips universal remote. After trying half of the codes for Philips TVs, I came up with one which allowed access to the SETUP menu. It was 0621. This allowed me to run the auto channel setup, as well as fix some of the other functions. I don't know if this works with all remotes, but if you try different codes, you should get lucky. I'm sure it helps if you have a SETUP button on your remote.
Posted on Mar 22, 2009
  • 3 Answers
SOURCE: how do I access the menu without a remote?
You don't. A good "universal remote" available from Radio Shack (Phillips) for about $15 will provide access to all TV adjustments. Easy to program for all TV models, VCR's, DVD players, etc. About $35 + S&H for the Sharp remote replacement.
Posted on Nov 17, 2009
SOURCE: what universal remote works with model number p1300nTV
I too own the Disney Pirates of the Carribean television. We have it setup in my boys' room so they can only watch DVD's, there is no cable connected to it. However, everytime we turn it on, we have to use the remote to change the input to dvd. The large Mickey button on the remote fell out and my daughter lost it. Without that button, you can't change the input at all. Therefore we have a perfectly functioning television that we can't use.
I emailed Disney and they redirected me to the actual manufacturer of the TV, Starlight Griffin. The phone number is 866-387-1902. I called and within 5 minutes, I was told that I would recieve my new remote within 10 days at NO COST TO ME!!
I went crazy for days trying to figure this out so I had to share that info with all of you immidiately! Good Luck!!
Posted on Mar 02, 2010
How can i go to the set-up menu without the factory remote? Sharp TV lc32dv24u
You can't without the factory remote. You can probably pick one up on ebay though on the cheap.
Apr 16, 2014 | Sharp LC32DV24U 32 in. LCD TV/DVD Combo
Change the picture size without the original remote
To select the aspect ratio of picture, you should have its remote cotrol.
Dec 22, 2013 | Sharp 32L-S400 32" TV
I cannot program my remote control to my tv
what is the remote code for a 1998 Sharp 32 in Tv model nol 32KS400
Jun 23, 2010 | Sharp 32K-S400 32" TV
Horizontal retrace lines at top of screen
Change 100uf 50-63volts capacitor next to the vertical output ic,if not solved check the vertical b+ filter on the 24volt line.If nothing else work try damping the vertical yoke with 2 300ohms resistors if in series or just one 220-330 ohm resistor if its parallel vertical yoke windings.
Nov 22, 2009 | Sharp 32J-S400 32" TV
How do I access the menu without a remote?
Nov 14, 2009 | Sharp 27J-S100 TV
Acessing menu without remote
A) Look for a menu button somewhere on the tv itself .. Usually volume or channel buttons serve as up and down, etc..
OR
B) Go to electronics store and buy a universal remote $10-$20 and program it for your tv.
Aug 15, 2009 | Sharp 32L-S500 TV
How to switch to antenna usage without a remote for a sharp model 27K S100
several answers:
1get the original remote control
2get a universal remote control and maybe you can get menu from there.
3get menu on front panel of the tv and search for the option.
4send the tv to autoprogram. Good luck!
Mar 22, 2009 | Sharp 27K-S100 TV
How to acess set-up menu without factory remote
The manual can be found near the bottom of the Product page for this TV.
From the manual, pg 11 -
If you misplaced your Remote Control you can still access most settings via the MAIN MENU screen when you press both CH UP (8) and DOWN (9) on the TV set. Some features of your TV Set will not be accessible without the Remote Control. If you lost your Remote Control, contact a Sharp Authorized Servicer by calling 1-800-BE-SHARP for a replacement.
Let us know if this fixes it for you.
Feb 11, 2009 | Sharp 25N-M100 25" TV
(no volume}
Good day.
Have you checked on the settings? Maybe the speaker function was turned off?
Also, the speaker migth got busted or the audio IC may be the root of this.
Please check.
chris
Mar 23, 2008 | Sharp 32J-S400 32" TV
its very easy on the t.v and press on channel up or down on your tv. u will get the screen
Aug 25, 2007 | Sharp 25L-S100 25" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
