Where is th thermostat located in the fridge thx
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 26 Answers
It is usually inside the fridge section. most of the time it is part of where the light is. your looking for a dial from 1-10 it will have an arrow where you set it at. it will also tell you which direction to turn it for colder or warmer
Posted on Oct 15, 2013
Fridge did start up when turn th/stat 1/4 turn. apparently switch is sticking?? where and what to do now? can I get a repacement part?
if you have a kenmore service agent get the thermostat from them
if not call in a technician and he will source a suitable unit
Jan 31, 2018 | Kenmore Refrigerators
Thermostat user manual
Thermostat in fridge is behind the knob for setting temp
Oct 14, 2013 | Amana Heating & Cooling
Freezer stays cold but fridge has been warm. I turn the thermostat to off for a day and then everything is ok for a week. Sounds like the fan is frozen solid when fridge doesn't work( no sound) Th
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jan 11, 2013 | Refrigerators
Whirlpool 6wmv43ns/02 Fridge Too Cold & Freezing Food
I would first try replacing the control in the fridge. If that doesn't remedy the situation, I would try replacing the thermostat next.
May 14, 2012 | Whirlpool Refrigerators
Thermostat does not stop. Everything is frozen within a few hours
Sounds like the thermostat is stuck. With the fridge unplugged, locate the thermostat, and on some if them you may be able to gently prise the points apart with a small sharp instrument. This is not a guaranteed fix and there is a chance that the thermostat will repeat its tricks. It should really be replaced. (The thermostat looks a little like a relay switch and is located somewhere near the fridge compressor).
Jan 17, 2011 | LG GC-151SA Compact Refrigerator
Why does the fridge part of my zanussi freezone fridge/freezer, keep freezing the food?
Hi,the problem you are encountering is as a result of the fact that the thermostat which regulates the cooling temperature in the fridge/freezer is bad hence there is no regulation of the cooling temperature in the fridge/freezer section, hence the food in the fridge freezes up.
The solution is to replace the thermostat of the unit,here is how you go about it;
1.You have to disconnect the fridge from the power source.
2.Locate the thermostat at the bottom of the unit,at the top left corner above the condenser.
3.Now you need to locate the wire ends or wire harness and unplug them.
4.Replace the thermostat,reconnect it back,put the back cover back and you have completed the job.
Take care of yourself
Jun 24, 2010 | Hoover HCA390FFK Bottom Freezer...
My fridge is freezing up after a couple of days
you may need to look at replacing the main control board at the back of the fridge. part #WR55X10333. here is a breakdown of where it is located.
Nov 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Where do i locate the thermostat on my 94 scoupe?
Follow top radiator hose and it will lead directly to thermostat housing. Housing should have 3 bolts on it. Thermostat is under it.
Oct 29, 2009 | 1994 Hyundai Excel
My ge side by side not cooling, freezer act like fridge
Sounds as tho your compressor is bad if it is still under warrenty take it to the place of purchase.
Nov 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
