Question about GE GSL25JFPBS Side by Side Refrigerator
I have a GE gsh25jstfss side by side and a couple months ago the water to the ice maker started freezing up. Now the water dispenser is not working either. What to do???
  • 108 Answers
Turn your thermostat down about 10 dagress.
Posted on Oct 14, 2013
Testimonial: "thanks for the info :("
dididsaythat
  • 291 Answers
SOURCE: GE SIDE X SIDE Dispenser problem
Sound like maybe a dispenser board short... you could try taking of the top hidge cap on the freezer side unplug the power to the board there for 30 minustes or so plug back in and see if it can reset to default and try that before u have to change board
Posted on Aug 21, 2007
  • 23 Answers
SOURCE: ice maker not working
check your owners manual for a water filter, make sure trip arm isn't stuck closed and not letting water in to freeze.
Posted on Dec 08, 2007
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Posted on Dec 19, 2008
SOURCE: I have a GE side
Well, the solution to this problem was posted in this thread
http://www.fixya.com/support/t1295372-ge_profile_ref_ice_despenser_motor_not
It seems that the bulb in the front panel is pulling to much current as it ages and it makes the control panel in not work properly. Removing the bulb will fix the problem - just fixed mine.
Also seems to match your symptoms (works sometimes and then not others - bulb current is inconstent, light dims when dispense lever pressed - again wrong current draw).
Good luck
Posted on Apr 19, 2009
SOURCE: water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Posted on May 22, 2009
GE Fridge water dispenser working but not the ice
Yes you most likely have a defective dual water control valve. Look around the inside of the refrigerator for a model number.
Click here=> For most locationsSide-By-Side
  • Top Freezer
  • Bottom Freezer
    Once you find the model number I will be able to tell you what part number the dual dual water control valve is or if your ice maker assist you in testing ice maker. If ice Maker is empty try filling with tap water to top edges of ice maker, allow water to freeze and if the ice drops into the ice bin but does not refill with water automatically I would say that the dual water control valve will need replaced. If your ice maker has old shrinking ice from a few days ago it will point to an ice maker problem.
    Thanks, Sea Breeze
  • Feb 10, 2012 | GE Refrigerators
    The water dispenser and ice cube maker stopped working
    Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
    disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
    Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
    The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
    A strainer before the inlet valve can also get stopped up restricting flow.
    Apr 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
    Water not working, ice is. fridge is set at 2.stuff freezing
    i have this exact same problem. Started about 3 months ago with the crisper and now the water. when I turn the fridge off after a few hours the water works again. I'm calling the repair person tomorrow
    Jan 30, 2010 | GE Profile Arctica 25.4 Cubic Feet...
    GE Profile side by side with water/ice dispenser. The water is working but the water to make ice is not working, hence no ice. I had ice, used it all and then nothing.
    I would try putting water in ice maker if it freezes ice maker is ok if so feplace water valve. careful only 4oz. of water in ice maker
    Oct 16, 2009 | GE Profile PSW26P Stainless Steel Side by...
    I have a Ge PSW26LSRDSS side by side the water line freezes
    The water line keeps freezing going to the ice maker? The line in the freezer? Is there alot of ice build up around the fan because of this? If so, it sounds like an ice maker malfunction is the root of the problem, and that can cause evap fans to go bad.
    Mar 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    Water dispenser and Ice Maker
    it might be your selenoid that closes the ice door in the chute but the water thing is says another thing might be wrong if you need service call 562-688-3627
    Oct 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    Refrigerator Ice maker not working
    my ge refrigerator stop making ice a week ago, water dispenser still works.
    May 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
    Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
    Water dispenser not working but ice maker does
    Mar 01, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
    Dec 08, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
    GE GSL25JFPBS Side by Side Refrigerator Logo
    41 people viewed this question
    Top Refrigerators Experts
    Sal DeAngelo
    Charles T Nevin
    Charles T Nevin
    Andrew Taylor
    Andrew Taylor
