Question about Uniden Tru9565-2 5.8ghz Cordless Phone 1 Additional Handset/charger
Mysingleuniden 5.8ghzphone charger lights uplike the phone ischargingbut after 2 hours I pick the phone up but it is dead
I phone been dead for over 12 hours now left on the charger, for 2 hours and still no luck. i have tried pressing the power at the the top right and the button at the centre of the phone, aand still no...
Try charging from a wall charger versus plugged into a computer if you havent. Also try removing the battery and reseating it, lastly Hold down the power button for about 20 seconds, this should hard reset the phone/tablet.
Nov 18, 2013 | Apple iPhone Smartphone
Blackberry wont light up after connecting to
the battery is very low that's why. The battery cell is weak such that it cannot be power up with charger. Except you use a desktop charger to wake the battery cell, then you can continue the charging with your charger.
Also you can leave the charger in the mouth of the black berry for some hour as it might still power up the battery.
There is nothing to worry about. Its a battery issue.
Take care.
Mar 17, 2010 | RIM BlackBerry 8700c Cellular Phone
Brand new motorazr V3s. draing batteries. only 3 hours of use
HEY THOSE CHINESE CHARGER ARE NOT GOOD.. THEY SUM HOW NEVER CHARGE THE BATTERY PROPERLY ND THE BACKUP IS LESS. CHARGE USING UR MOTOROLA CHARGER ND IF U STILL EXPERIENCE PROBLEM THEN U BETTER GO TO MOTOROLA
Aug 16, 2009 | Motorola Mobility RAZR V3
2008 CHARGER MISFIRE IN #2 IGNITION COIL
the valve cover is leaking oil in to the sparkplug area and getting the coil to plug boot wet and causing the spark jump.
Jun 12, 2009 | 2008 Dodge Charger
Phone does not hold ''charge'' when removed from the charger
hi
it seems that the battery in the phone is dead. replace it with new batteries, always go for rechargeable alkaline batteries.
hope it helps
RAhUL_hunk
Mar 10, 2009 | Uniden Cordless Phone
The phone became dead, recharging led does not light up.
On following the steps as stated in my problem text. I kept the phone idle for 2 hours, then I pressed the "ON" button, the screen lighted up and then went "off" again. I again pressed the "ON" button, the screen lightened up and the windows setup completeded in 2-3 minutes. The phone started to work. I think the phone got hanged since the battry went too low. Now it is working OK. I will always keep the battry charged.
I thank you and all your team mates for all the assistance you have extended in solving my problem. I am grateful that your site gives ample knowledge to sort such problems by the user.
Once again thanks a lot,
Regards
John
Sep 06, 2008 | HTC P3300 Smartphone
Phone is not working
My phone had the same problem and it was a battery charge problem. I bought an external charger and another battery and now everything works fine but I have two batteries and an external charger, the phone doesn't charge the batties.
Aug 13, 2008 | HTC P3300 Smartphone
'Unable to Charge'?
COULD BE THE PHONE BUT MOST LIKELY ITS THE CHARGER, IF ITS AFTERMARKET GET RID OF IT AND BUY OEM, TRY AND TEST IT OUT WOULD A FREINDS MOTOROLA CHARGER SINCE THEY'RE MOSTLY THE SAME CHARGERS AND SEE IF YOU STILL GET THE MESSAGE.
Apr 06, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
Uniden Tru9565-2 5.8ghz Cordless Phone 1 Additional Handset/charger Logo
23 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
