Question about Microwave Ovens
Emerson microwave model mw8115ss
My microwave wave cover has a hole in it. Don't know if thats the cause of it not working but there are two red indicator lights and the count starts but won't turn or cook.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 113 Answers
Wheres the hole
Posted on Oct 14, 2013
Testimonial: "In the middle of the wave cover."
StuartB
  • 807 Answers
SOURCE: no power
Usually they do have fuses in side as well as the one in the mains plug. With microwaves I would get an engineer rather than take it apart yourself.
Posted on Mar 11, 2008
Coldcut
  • 1554 Answers
SOURCE: Emerson Microwave MW8115SS
there is a thermal fuse inside that is likely blown.
easy to replace just have to google bullet thermal fuse.
Posted on May 12, 2008
jerryg50
  • 1667 Answers
SOURCE: need help with model # mw8115ss 1450 watts microwave problem???
The fault may be on the system controler board. This may be a protection fault, or a fault with the logic control.
You can call the place where you bought the oven to find out where it can be serviced in your area. Most likely the tech will change the system controler board, or if there is factory authorized component level fix he will do that for you.
This is not something you will be able to service yourself.
Jerry G.
Posted on Sep 10, 2008
SOURCE: Microwave turns on and counts down but won't heat up/cook
Ok just figured this out! It is a problem with the alignment on the lower door switch. I took the cabinet off and lifted up on the door switch slightly and voila! It works. You could probably fix this without taking it apart, just lift up on the door ever so slightly. I hope this works for you.
Posted on Mar 06, 2009
  • 3 Answers
I bought my emerson microwave 3 years ago model# mw8115ss from walmart and have had all the problems that everyone has talked about and I thought about throwing it away until I thought about one small detail, the FUSE. China uses junky glass fuses that burst instantly with a slight power outage, door slamming to hard, moving it around, and of course constant use like myself always heating up water for bottles. I took the back of the microwave off and walla!!! a blown fuse, but wait!!! dont buy another glass fuse!!! go to your local home depot and get the ceramic fuse for microwave ovens!!! they are $2.83 at my local home depot. I replaced the junky glass fuse with the ceramic one and it has worked perfectly for six months now.
DONT let someone tell you that you cant replace a glass fuse with a ceramic one because they are full of boloney. My microwave did all kinds of things, it wouldnt turn sometimes, it would come on by itself, it would beep for no reason, turn but not heat up, you name it I had the problem. When a fuse starts to go out it can make your appliances do some strange things, check the fuse and replace it with a CERAMIC one and I promise it should eliminate your problem.
Posted on Apr 29, 2009
Emerson model mw8115 ss
The problem is caused by one or two bad door switches that will need to be replaced.
Mar 14, 2012 | Emerson Fans Emerson MW8115SS Microwave...
I just purchased an Emerson 1000W Microwave, Model #MW8115SS. I took out of box, removed the blue covering that protects the finish and when I plugged in and turned it on to heat something up, it was very,...
The unit may be more powerful than your last one. if its probably is normal 1100 w is a lot of power. if it works well and you in joy it, then you will soon be used to the new sound of power Good luck DFD
Apr 13, 2009 | Emerson MW8108P Microwave Oven
I need a microwave guide cover for model mw8115ss
Buy a sheet of mica. It's cheap and easy to work with. Draw and cut a new cover from a sheet and replace the damaged one. There's a example of how cheap mica is (I just used a sheet like that today on my Miele microwave).
http://www.leiritronica.com/linhabranca/product_info.php?products_id=2587
Don't try punching holes in mica, always drill them gently. It will easily flake.
Mar 10, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave only works sometimes.
I coudl only find a Canadian support website.
http://www.emersonelectronics.ca/emerson/en/support/
Toll Free Customer Support: 1-800-663-5954
In U.S.A.
For all product purchased in the U.S., please contact:
Emerson Radio Corporation
9 Entin Road
P.O. Box 430
Parsippany, New Jersey 07054-0430
Jan 06, 2009 | Emerson Black Microwave Oven
How to change a light bulb in a emerson mircowave model mw8115ss
If this is freestanding m/w:
1. disconnect from outlet
2. take the cover off.
3. light bulb located on right upper corner.
Nov 30, 2008 | Emerson Black Microwave Oven
Model mw8115ss suffix a Emerson Microwave not working
This is usually caused by either a bad door switch, a loose door switch mount, or a misaligned door.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
Aug 03, 2008 | Emerson Fans Emerson MW8115SS Microwave...
Emerson microwave oven model number MW8115SS
You don't state how old your oven is, or if you tried other food items afterwords. I also assume you inspected for foreign metal objects in the oven? If it does this whenever you attempt to cook in it, then it sounds as if your oven may have a wave guide cover malfunction or burned area.This part can be replaced by the consumer in most cases, but only after consulting with a trained technician or your parts supplier.
May 23, 2008 | Emerson MW8108P Microwave Oven
Microwave Ovens Logo
77 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
