Question about Lasko 3520 20-Inch Cyclone Fan
How do you clean a cyclone fan - Lasko 3520 20-Inch Cyclone Fan
How do i take apart my lasko cyclone fan to clean the inside of it
You may need to UNSCREW the front half of you fan guard plastic casing or depress it in a few place if you see notches on the cage itself. Remember the knobs you will be removing to take the blades off to clean will be threaded opposite, one will screw off and on clockwise then other counter clockwise. Be sure FAN is UNPLUGGED BEFORE YOU open it up. Lay all parts in bathtub, Spray with Cleaning foam, pour lots of water over to clean all sides, then let drain and dry in bathtub. Less muss and fess this way!
Aug 09, 2014 | Lasko 3510 cyclon Floor / Box Fan
How to dismantle the Dyson DC08 fan unit?
The fan / motor is not designed to be taken apart.
Jun 29, 2014 | Dyson DC08 Cylinder Bagless Canister...
Cyclone 3520 by Lasko
first of all unplug while cleaning on .on the sides it should snap together r have clips on it pull apart r lift the snap hindges on hold the blade with 1 hand turn the knob with other clockwise i think wash r take a dust broom to it put back 2 gether
May 15, 2013 | Dryers
Hi loss of suction on Dyson DC07 and I have changed the belt on the brushbar and cleaned all filters/removeable parts but still suction not very good, any other suggestions?
Check for a clog where the power nozzle connects to the hose. Clogs or leaks in the hose will both cause loss of suction/air flow. Another possibility is broken or worn out fan blades.
Nov 13, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do I take the front cover off so that I can clean the blades etc of dust?
You can blow the whole fan clean with compressed air or a compressor. It does not require removing the cover. The cover comes off with a twist and a pull, but does not stay on well afterwards, so I don't recommend removal. Farmerbear at FixYa.com
Sep 29, 2010 | Lasko 3520 20-Inch Cyclone Fan
How to clean my fan
u can clean ur fan by using a scrubber making ita little wet with sopy water then cleaning it with cloth.please be careful nt to make ur fans motor or electric circuit wet
Mar 30, 2010 | Lasko 3520 20-Inch Cyclone Fan
I have a Model #3510 Lasko Cyclone Fan and the blades are dirty
Steam works great, otherwise you can use a degreaser and hose it off. Make sure you let it dry completey and then some before plugging back in.
Aug 26, 2009 | Dryers
Lasko 3520 20-Inch Cyclone fan - disassemble fan for cleaning?
How do I clean my Cyclone or Air Companion™?
Lay the fan face up on a flat surface. The front grill should be facing you. Remove the screws from the rear grill. Place a flat-head screwdriver into the gap between the front and rear grills. Pull the front grill towards you, exposing the fan blade. Do not remove the knobs on either side. Then, wipe the blade with a soft, damp cloth. Use a mild detergent if necessary. Be sure not to touch the motor. Click here to download product instruction sheet.
Jun 08, 2009 | Dryers
Lasko 3520 20-Inch Cyclone Fan Logo
61 people viewed this question
Top Lasko Dryers Experts
Shehu Pro
Shehu Pro
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
