Question about Maytag Washing Machines
Maytag Washer Maxima Front Loader W10254495A after
Maytag Washer Maxima Front Loader W10254495A after you push the buttons to start, the door is supposed to click, then the washer will start. It does not always click, thus the washer won't start. I repeat it a few times, and eventually it will click and start. Has anyone else had this problem?
4 Suggested Answers
  • 1028 Answers
SOURCE: Whirlpool 9400 Front Loader Washer Control Button Locked
find button with lock emblem beside it hold 3-5 secs
Posted on Oct 09, 2008
SOURCE: Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
Posted on Apr 16, 2009
ginko
  • 19396 Answers
SOURCE: I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Posted on Jun 13, 2010
Getting E02 and F09 error codes on my Maytag Maxima MHW6000XW front load washer
Here is the manual. Hope it helps: http://www.applianceblog.com/mainforums/attachment.php?s=001fc13abc99c02a4aa812a23c01ac7e&attachmentid=13030&d=1381289434
Jan 05, 2014 | Maytag MHW6000XW - MaximaTM...
Maytag MTW5770 TQ model. 3 years old. You have to drop the lid hard or push on it to get the machine to recognize the lid is 'closed' and can then start the agitation and rest of cycles. It does...
Some of them have a mercury switch that has been bent so it doesn"t make good contact with the liquid mercury. If you can find it you can bend it back. It has to be on the door or an arm under the door or door hinge.
If you know how, you can raise the washer top using a flat knife type of tool to move springs thru the gap between the washer top & the lower front piece. (assuming it's a top loader)
In a front loader it's still near the door.
Jun 26, 2011 | Maytag MTW5770TQ Washer
I have a maytag front loader and the start button does on stay on, therefore door button will not stay on to lock door. I have to hold button in so that washer will start filling up with water but then...
This sounds like a motor control or a main control board problem. If this is a older washer, but less than 10 years old,that hasn't been updated with a new motor and control board assembly, the parts may be covered under the motor warranty. You need to call a qualified service tech to determine if this is the case.
Feb 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have the neptune front loader. The lock light wont come on and the door wont lock. During a wash cycle the water just started comming out of the door. If I hold the stop/start button manually the light...
hi there,
you have a door latch problem. the reason you can still push on the button is because this particular washer has a time delay function. i would recommend taking a look at the latch itself and possibly the wax motor that runs the latch.
Dec 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washer Door Locked
INSIDE THE SOAP LOADER THERE IS A LIME COLOR STRING PULL IT WILL UNLOCK LATCH
Apr 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore front loader
My front loader stops at every cycle. Is there a simple solution to this?
Jan 22, 2008 | Kenmore 44832 Front Load Washer
Washing Machines Logo
171 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
