Question about Acer Computers & Internet
No low battery warning..
My computer just shuts down when the battery dies. How do i get a low battery warning to come up again because it doesn't.
    Sergeant:
  • 252 Answers
  1. Open Power Options by clicking the Start button, clicking Control Panel, clicking System and Security, and then clicking Power Options.
  2. On the Select a power plan page, next to the plan you want to change, click Change plan settings.
  3. On the Change settings for the plan page, click Change advanced power settings.
  4. On the Advanced settings tab, expand Battery, expand Low battery level, Reserve battery level, and Critical battery level. Change the percentage of battery remaining that you want for each level, and then click OK.
Posted on Oct 14, 2013
Testimonial: "I have it on already, but it still doesn't show up."
  • Jason Ng Oct 14, 2013
    thanks for ur help tho
4 Suggested Answers
  • 97 Answers
SOURCE: DELL D520 LAPTOP
Problem cause:
Do diagnose your Laptop try to change your battery or adapter if you have some backup device
Posted on Sep 22, 2008
  • 3940 Answers
SOURCE: while using my power cord, low battery warning
If the system is charging the battery while connected to the adapter and not running but runs off the battery when powers on, then you likely have an issue with the motherboard charging circuit.
See if you can flash the BIOS to the most current version. If no go, then replace the motherboard
Posted on Jan 29, 2010
  • 16 Answers
SOURCE: Purchased a new Dell Inspiron 6000 (9 cell) battery
Have a look in your power properties and see the settings.They may be set at when battery reaches 30% The computer shutsdown. You can change the settings to your own preferance.
Posted on Mar 15, 2010
I have a 2004 honda shadow aero. When I was riding lasst weekend the bike shut off like it ran out of gas. It would turn back on, but when I gave it throtle it would die. I let it sit for a few hours and...
Sounds like the battery is dying. A low battery and/or bad stator or bad regulator will cause the battery to get low on voltage. Although enough to start the bike and idle, it will loose power to the coils under heavy throttle.
Apr 16, 2013 | Motorcycles
Idle fluctuates on 1995 f250, sometimes dies, sometimes revs, no apparent vaccum issues, IAC with scan tool reads low voltage issue. Could this be vaccum, charging system, faulty computer? Problem is...
Engine stalls cold or RPM fluctuates at idle up and down or dies near idle.
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve but always run a OBD2 fault code as well as the cleaning procedure. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control. If the above cleaning doesn't cure your issues you need to have the computer controlled automatic idle speed control system diagnosed and repaired by a dealer or electronic engine control repair shop.
Nov 08, 2012 | 1995 Ford F250
Acer Aspire 5742, Completely Shuts off, error free, randomly.
If your computer is shutting off randomly, there could be a multitude of issues. Most of the issues are hardware related.
1. If you're able to use your computer for a little while, and it randomly shuts off, it could be one of a few things.
a. Overheating processor: You may need to replace your processor, or clean out the inside of the computer.
b. Fans not working: Your fans could be disabled, and keeping the computer from receiving cooling which can overheat the processor as well as other vital components.
c. Dying battery: The battery in your laptop may be going bad, and could need replacement. Does it charge completely, or does it only fill up partially after a long period of charging? If it's the latter, you will need to replace it.
d. Dying hard drive: While this one isn't as likely, and usually doesn't cause the computer to shut off instantly, it's still something to consider.
2: If your computer shuts off before the desktop even loads, it's most likely a hardware problem.
a. Dying battery: Again, your battery may be dying, try removing it and keeping the laptop plugged in when you turn it on.
b. Broken hard drive: Your hard drive may be broken, try finding an external hard drive with Linux or another operating system installed on it, and go into the BIOS when your computer first starts up. Find the "Boot devices" option, and tell it to make the primary boot device the external device with the operating system installed on it. If the computer starts up fine after that, you may need to re-install your old operating system, or replace your hard drive.
May 04, 2011 | Computers & Internet
LAPTOP JUST SHUTS OFF AFTER VARIOUS PERIODS OF TIME. NO WARNING AT ALL. DOESN'T SEE LIKE A BATTERY BEING LOW AS THERE IS NO WARNING AND UNIT PLUGGED IN TO AC
It probably is overheating, and is shutting itself down, to avoid PERMANENT damage.
Turn the computer off.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed-air, and give the computer a "blow-job" -- shooting compressed air everywhere into the vents, to remove a layer of dust, that has been acting as insulation, causing your computer to overheat.
Dec 11, 2010 | Computers & Internet
I shut down the computer while charging my mp3
Try plugging in the USB connection again. If that doesn't work, unplug it and then press and hold the on button for ten seconds.
May 06, 2010 | SanDisk Sansa e250 MP3 Player
You just want to refresh battery from the BIOS. There problem will be solve
Mar 15, 2010 | Dell Inspiron 6000 Notebook
I have a 97 mercury tracer that quit on me going down the highway, there were no warning signs it just died. It would crank but not turn over even when we tried to jump it off. We towed it in and the...
BATTERY MUST READ 12 VOLTS AND 11 VOLTS ON A DRAW OR WITH A LOAD ON IT
IF YOUR ALTERNATOR STOPS WORKING THEN THE BATTERY WILL GO DEAD AS THE ENGINE HAS TO HAVE ELECTRIC TO RUN ( WHEN YOU CAR REACHES 8 VOLTS THE COMPUTER WILL SHUT OFF EVERYTHING TO SAVE IT'S SELF FROM BURNING UP SO CHECK YOUR ALTERNATOR AND RECHARGE THE BATTERY
Mar 02, 2010 | 1997 Mercury Tracer
DELL D520 LAPTOP
Problem cause:
Sep 22, 2008 | Dell Computers & Internet
I got a signal the battery was low, and now after charging my phone doesn´t start again??
Do a search on the site http://wiki.xda-developers.com/ Try the Keywords "Bricked"
Feb 02, 2007 | O2 Xda II Smartphone
Computers & Internet Logo
175 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
