Question about HP Pavilion Computers & Internet
Maximum hard disk size for hp a1610n
What is the max size i can put in my computer
    New Friend:
  • 156 Answers
Based on The Spec's of your System you have a 250gb Hard Drive however the Maximum size will be less then that due to formatting the drive so you can expect that to be like 10% less then 250gb (just a guess) plus a lot of computers come with a restore partition which is usually around 12gb assuming you leave it factory stock.... Your computer by default will set your Hard Drive to the Maximum size... now as far as how big you can install the sky is the Limit your computer is new enough it should except any size Hard Drive available at the store.
Posted on Oct 14, 2013
2 Suggested Answers
  • 1623 Answers
SOURCE: what is the maximum size
you can put any size hard disk you want in there as long as its sata
Posted on Apr 01, 2011
Hardrive is unknown device in bios
The BIOS determines the maximum size hard disk the computer can support.
The max hard disk size for this model Dell is 80Gb.
To use your 250Gb hard drive, install this Hard drive into an USB hard drive case and use it as an external USB hard drive.
Mar 09, 2013 | Computers & Internet
Tip
Virtual memory settings
Windows XP
1. Click Start, right-click My Computer, and then click Properties.
2. Click the Advanced tab. In the Performance section, click Settings.
3. Click the Advanced tab. In the Virtual memory section, click Change.
4. The hard disk drive that is used for virtual memory will usually be the
5. same disk drive that Windows is installed on. Both the Initial and Maximum settings should be less than the reported Space available on the hard disk drive. The Initial size setting for the virtual memory settings should be approximately 200 MB in size but should be higher than or equal to the recommended paging file size as indicated in the lower section of the screen.
Once the initial size is set, Windows will reserve this amount of space on the hard disk drive for virtual memory and it will not be available to save information on.
The maximum amount allowable can be anything above the Initial size setting, but it is recommended that it be at least twice the Initial size setting
on Apr 27, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
How do I make 4 partition on a 40GB hard disc. What are the proceedings.
Boot up with the Windows XP installation CD
Follow the screen instructions -
Delete the existing Partition.
Create a new Partition (1st) but do not make it the maximum partition size - enter 1/4 of the maximum size.
Create another Partition (2nd) make this the same size as the 1st Create another Partition.(3rd) make this the same size as the 1st
Create another Partition (4th) make this the remaining max. size.
Format the Ist Partition Full NTSF (not quick format)
You can now proceed to install Windows on the 1st Partition.
After Windows XP has been installed and the computer's device drivers, go to Control Panel - Administrative Tools - Disk Management then allocate a drive letter to each of the Partitions then NTFS Format each of the Partitions.
Now each of the Partitions should indicated as Healthy.
Create
Dec 09, 2011 | Samsung (SP0411N) 40 GB Hard Drive
How do I choose a hard drive?
It depends upon where the hard disk is to be installed, ie. in a desktop computer, in a laptop or in an USB hard drive case.
A 3 1/2 inch hard drives can be a IDE/PATA or a SATA type. Older computers use IDE/PATA hard drives and the maximum size you can install in a desktop depends upon the computer's BIOS.
SATA hard drives are generally used in later model computers and the size of the hard drive is not limited by the BIOS.
A 2 1/2 inch hard drives are used in laptops and are available in IDE/PATA and SATA types. The size and limitations of IDE/PATA hard drives also apply to laptops. The same applies to SATA hard drives.
The choice and size of hard drive depends upon your requirements and how much you want pay.
Don't forget to check BIOS for the maximum IDE/PATA hard drive size you can install in your computer.
Aug 22, 2011 | HP Computers & Internet
Hello, s I have a HP pavilion a1230n my old hard disk which was a 200 gigabyte hard disk gave out so i got a 750 gigabyte hard disk then pluged it in then put in my boot disk then when it asked me if i...
Hi, Please check the maximum Hard Disk size the computer supports in the manual specifications of the computer.
Possible solutions:
However, check with the Quick format.
Please try to replace the RAM Modules in the computer and try again.
May 28, 2011 | Computers & Internet
What is the maximum size of hard drive my hp pavilion a1320n can use
Apr 01, 2011 | HP Pavilion a1320n (882780261747) PC...
What's the maximum hard drive I can install in a Compaq SR1420NX I have a 80 hard drive right now I want to install a larger one. Will this computer handle a larger Hard Drive
The BIOS has a max. hard drive size limitation. Check the manual for the maximum size the motherboard can support.
If the maximum size hard disk it can support then you can add a second hard drive in the computer as a SLAVE hard drive to double your disk space capacity.
Mar 15, 2011 | HP Compaq Presario SR1420nx...
Max Size for Intel 865g
hi,
500GB is the maximum hard disk size for 865G motherboard.
Sep 20, 2009 | Intel 865G Motherboard
SCSI Disk capacity Limitation in HP-UX 10.0
your hard is only 2 gb?so its means that disk full?when you are installing windows xp the minimum capacty of the hardrive should be 3 gb try to look another hardrive!!just try
Jul 14, 2009 | Computers & Internet
Copy memory on HP L7580
sounds like you need to change your virtual memory settings or buy more RAM.
Here is how to change the settings:
I am assuming you use WINXP
  1. Click Start , right-click My Computer , and then click Properties .
  3. In the Performance section, click Settings .
  4. Click the Advanced tab.
  5. In the Virtual memory section, click Change . Both the Initial and Maximum settings should be less than the reported Space available on the hard disk drive. The Initial size setting for the virtual memory settings should be about 200 MB, and should be higher than or equal to the recommended paging file size shown in the lower section of the dialog box. When you set the initial size, Windows reserves on the hard disk drive the amount of space you designated for virtual memory. The maximum amount allowable can be anything above the Initial size setting, but it should be at least twice the Initial size setting, as shown in Figure 2. Figure 2: The Windows XP Virtual Memory settings c00174885.gif
  6. Based on the information above, make any necessary changes to the Initial size and Maximum size settings.
  7. Click Set , and then click OK .
Sep 05, 2007 | HP OfficeJet Pro L7580 Color All-in-One...
Computers & Internet Logo
32 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
