Changed remotes,now can't use list button - Televison & Video
  • Darlene Fleming
    Darlene Fleming Oct 14, 2013
    Yes exact same shaw remotes,the list button is for list of recorded shows on my pvr
  • FatalBert Oct 14, 2013
    Try removing the batteries and holding the list button for 20 seconds then reinserting the batteries. Also try replacing the batteries if that does not work. If it still doesn't work then you will have to manually go to Menu>DVR>Recordings or something of the sort to get to your recordings.
    Master:
  • 359 Answers
Is the remote you switched to identical to the one you were originally using? What exactly is the list button you are attempting to use. The list of channels?
Posted on Oct 14, 2013
My haier le32f2220 has A channel list box that pops up and I can't change channels. All remote buttons do nothing. Changed batteries twice. Anyone have this issue?
·Pull the batteries out from the remote control, and leave it out until step-4
·Press and release each and every button, one at a time on the remote control, until every button has been pressed and released at least once.
If the remote control have slide switches; move the switch to each position, then repeat the button pushing as in step-2. {When you've done, be sure to put the slide switch in the correct position to operate the unit the remote came with.}
·Put the batteries back.
·Try the remote.
http://remotesearch.blogspot.com/
Apr 24, 2015 | Haier Televison & Video
How can i register add Sony TDG-BR250 3d glasses to SONY KDL-70W850B 3d tv
Hi Mate
Press the Power Button of your 3D glass for 2 Seconds The Power Goes to Green LED ON now your 3D glass is ready for used. Play your 3D movie from Bluray player and Press the 3D Button on the remote. If there is no 3D button on the remote then press Option Button on the TV remote and choose the 3D option from the list. the video will changed to 3D video Now Enjoy your 3D experience. If you any difficultes then PM me.
Dec 11, 2014 | Sony Bravia XBR KDL-70XBR7 70 in. LCD HDTV
Remote not working as i moved tv into another room
If the remote control you've bought is a universal remote control, you have to set it with your TV, by TVs setup codes. The setup code list will be attached to the new remote controls' packing. If you wish to get more details, check the sites linked here. Set-up code list, and Set-up procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide, can be selected by the drop-down list, by the top left of the display window, will make surf easy
Nov 06, 2013 | Grundig GU22DVDPX 22 in. LCD TV
Froze
To see if the problem is with your remote control, go to the receiver and use the channel up/down buttons on the receiver itself. If you can change your channels with the buttons on the receiver, the batteries in your remote control probably need to be changed.
If you can't change channels from the receiver, turn off the receiver. Then unplug it for at least 15 seconds. Plug the receiver back it and turn it on. Again, try changing channels from the receiver itself.
Tune to a channel, and while programming is playing, try tuning to the missing channel by entering the channel number on the remote control keypad to see if channels change. Do not try to select the channel from a channel list, program guide, or favorites list.
If this approach takes you to the correct channel, you need to adjust your favorites list function. Press the "guide" button on your remote. Look for a button on your remote called "fav" or "list." Press it several times and watch for an indication at the top of the guide that you are moving from "all channels" to a particular favorites list.
If you are locked on one channel only, your Channel Lock feature is likely active. Consult your owner's manual to unlock the rest of your channels. See your owner's manual for information on managing favorite channel lists and locking out channels. Enter your password, if necessary.
Jul 30, 2012 | Coby TFTV1925 19 in. LCD TV
Channel lock is stuck on
May 28, 2011 | Televison & Video
MY dish remote is installed with the dish receiver. My dish remote though is not changing the channels. I already changed the batteries and it turned out to not be that. So what do I do?
Tierra_bush,
It's possible the remote may just need to be readdressed to the receiver. I've listed the steps below:
Addressing remote
1.) Go to System Info screen.
2.) Hold down the SAT button until all mode lights light up.
3.) Enter a number between 1 and 15 using the numeric keypad on the remote.
4.) Press the pound (#) button.
5.) Once the SAT button blinks three times, press record.
6.) Try the remote and see if it is working.
Let me know if you have any other questions!
Tommy Faust
DISH Network
Apr 12, 2011 | DISH Network ViP722 DTV Receiver /...
Pressed the System wizard button on remote the Sat button lit up for a minute or so then the remote stopped working ! Changed batteries still not working ! reset the box still not working What do I do ??
Hey there, Cheri Torres with DISH Network Customer Service here. It sounds like your remote may need to be readdressed to your DISH receiver. I will list here for you the instructions for addressing your remote to your receiver box. If you are using the TV2 remote make sure you take it to the TV1 location to perform the trouble shooting steps. If you are using TV1 remote stay at the receiver box location. I hope you find these instructions useful and if you have any further questions or concerns feel free to post back here or email me directly at Cheri.Torres@Dishnetwork.com.
Instructions for addressing remote to DISH receiver
  1. Go to System Info screen. You can do this by pressing the system info button on the front of the receiver box or by pressing the power button once then the channel up button once on the front of the receiver box.
  2. Once you are in the system info screen you will see primary remote address (TV1) and secondary remote address (TV2).
  3. Hold down the SAT button until all mode lights light up.
  4. Enter a number between 1 and 15 using the numeric keypad on the remote.Change the number to something different then what is already listed in the white square.
  5. Press the pound (#) button
  6. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 3 will appear in the System Info screen under Remote Address.
Mar 07, 2011 | DISH Network IR Remote Control
I bought a 2007 Camry with a remote start. The seller doesn't know how to start the car with the remote. The remote is a 4 button Viper 474V.
First, be sure that the remote is programmed for the vehicle by using it to operate the door locks(pressing the lock and unlock buttons). The parking lights should flash if nothing else works.The usual way to operate the remote starter with this remote is by pressing the * button once but, the option could have changed if the remote has been reprogrammed differently. So, try pressing the * button once. If this doesn't work press it twice within two seconds.If this doesn't work try pressing the lock and unlock buttons at the same time. If these steps fail to initiate the remote starter try the steps listed for the * button with the aux button. If either of the remote starter inhibits (hood pin, neutral safety) are active you should receive flashing parking lights for a failed attempt to remote start.
Jan 16, 2011 | Remote Start System
I have a 19" Genesis LCD TV and I need the Remote Control Code
I have a 22" genesis LCD and can not get my Direct tv remote to work?
Jul 08, 2009 | RCA Universal Remote Control
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
