My Onkyo (NR727) AV Receiver has ATT&T U_Verse cable box. The sound on some Channels Cuts out inermitingly?
  • 14 Answers
SOURCE: Can't connect subwoofer to onkyo av receiver
you would need a y jack to connect those to the receiver
Posted on Mar 05, 2009
SOURCE: Onkyo AV Receiver TX-SR 805 no display on the receiver
Finally one of us found the solution - thanks to cambrian
Please follow the link
http://www.avsforum.com/avs-vb/showthread.php?t=857502&page=579
BTW: My knowledge of electronics is very limited, but nevertheless I could fix the problem. I hope you can do it too.
Posted on Mar 12, 2009
  • 4 Answers
SOURCE: Onkyo TX-SR705 - No Audio - Flashing HDMI
The posabilities is power amplifier on your reciever is bad,
replays reciever or repair it.More likely this is IC amplifier located on the main board of the reciever
Posted on Apr 17, 2009
SOURCE: Picture sound blackout (blink) when cable box/receiver HDMI used
Onkyo service told me, the second timethat I called them, that there is a known HDMI handshake issue with Motorola and Atlanta Scientific cable boxes. The only solution, and it was a solution, is to connect the box through the HDMI 1 port ONLY. All the other (2,3,4) result in blinking/dropping of signal. I did this, changed the cable/satelilte setting to HDMI 1 and all is well.
Posted on Apr 19, 2009
  • 137 Answers
SOURCE: Onkyo TX-SR606 HDMI Input
The problem is the hdmi board in the receiver .they are having trouble with the smd regulator and smd capactors that they are using on the board,they have updated the new boards as i have not got any back when replacing with the new boards. I have replaced at least 35 hdmi boards on this model. If you call Onkyo they will tell you that you have a hdmi board bad and take it to an onkyo dealer.
Posted on Apr 17, 2010
Loosing sound TX-NR727 watching TV
Hi George, does this happen on all of your sources? What type of connections are you using and what is the distance between the source and the receiver, please advise. Note that you can email me directly at askOnkyo@us.onkyo.com, thanks, JT
Sep 15, 2015 | Onkyo TX-NR727
How do I program an AT&T u-verse remote to an ONKYO RC-866M remote
The RC-866M is the remote. What you need to do is add the codes for your Onkyo receiver into the ATT remote. There are 4 or 5 different Uverse remotes, but most can be reprogrammed by pressing the 'Menu' and 'OK' button together. First add your Onkyo codes to the ATT remote as an 'aux' device. After that is working, you can control the power and volume by adding the 'aux' device (Onkyo) to the power and volume buttons on the uverse remote.
These are all the different Onkyo Receiver codes:
Onkyo: 5002, 5018, 5073, 5074, 5075, 5076, 5077, 5078, 5079, 5080, 5081, 5082, 5084, 5085, 5086, 5087, 5130, 5131, 5140
This is how to reprogram the S10 style of Uverse remote:
http://www.att.com/support_media/images/pdf/uverse/standard_black_remote_control_uverse.pdf
Dec 22, 2014 | Onkyo Audio Players & Recorders
Need Onkyo tx-nr616 remote code so ATT U-verse remote can control Onkyo
I used 5002 and it works for on/off only. This is better than nothing. You can try codes from other Onyko devices to see if you can get one that provides more functional control.
Dec 31, 2012 | Onkyo TX-SR705 Receiver
THE CABLE CONNECTIONS ON THE TV IS BROKEN IS THERE ANYTHING I CAN BUY THAT WILL CONNECT TO THE TV SO I AM ABLE TO VIEW CABLE?
No.Tried telephone cable services like ATT U verse or Verizon Fios.Their boxes can used RCA AV component cable YRW cable connections to YRW component cable connection holes with both of these companies boxes to watches tv.
Jan 09, 2011 | JVC LT42E478 42 in. HDTV
Just got att u-verse and the digital audio output is distorted.
I'd run this by ATT.
If the audio output digital feed is strong enough for the receiver to accept it then the actual audio on the digital carrier is probably the problem. If there is a coaxial output on the cable box, I'd try that, too, to isolate the optical and HDMI as the problem or not.
Or shoot the cable audio into the place your Blu-Ray is connected to prove if it works the same or different.
Apr 26, 2010 | Pioneer VSX-1019AHK A/V receiver
Onkyo tx-sr702 sound cuts out when pausing, then starting a recording on DVR or changing HDTV channel
That would be a function of your Cable/DVR dropping its digital bitstream output, wouldn't it?
My Pioneer does the same thing when I switch channels on my cable box or ANY sources. The receiver has to resync with the new bitstream, buffer it, figure it out and sort out the audio channels. Sounds like normal operation to me.
Apr 01, 2010 | Onkyo TX-SR702 Receiver
While wathching TV, the typical volume level
Cleared all AV settings and reprogrammed.
Jan 30, 2010 | Onkyo TX-SR703 Receiver
Need remote code for AT&T box!
Have you tried this AT&T code 00858. Motorola set-top box codes include 00476, 01376, & 01562.
You can download Onkyo universal remote codes with instructions here.
I hope that helps.
Jan 11, 2010 | Onkyo TX-SR605 Receiver
Hook up patio speakers and use my cd/dvd/cable/ipod outside only
i'm not sure if this will work, but you could try connecting the rca stereo cables from you cable box to the cd input on the receiver those would be analog. then you could use the music channels at least. as for an ipod maybe sort of the same thing using an av cable instead of the dock;like i said i don't know if it will work but just a thought.
luke
lukeshkin@hotmail.com
Mar 25, 2009 | Onkyo TX-SR504 Receiver
How to connect 6.1 speakers to 7.1 receiver
Using the Onkyo display setup, you can turn off one surround speaker, and your receiver should realize it's using the 6.1 channels instead of the 7.1
If you don't want to go that route, use the mic setup that came in the box and your Onkyo will determine by itself the 6.1 channel layout.
It should work fine.
Nov 14, 2008 | Onkyo TX-SR605 Receiver
15 people viewed this question
 Grubhead
Grubhead
