My abc player loads up to the finally commercial & stops. I can not see the click button on bottom left. And I also now see a small blank spot on top right. How can I fix??
  • dave
    dave Apr 24, 2009
    abc has so many issues
    i just use other means
    like ov guide or ninja video
    or pirate bay fuk abc i try to watch pushing daisies and
    it nevers works right just a suggestion
It sounds like you have an adblocker of some sort turned on. On ABC's video website it has the annoying effect of playing the comercial and blocking the actual video. Try turning the adblock software off.
Option 2, reinstall adobe flash with the latest version. Also try using Firefox. It handeles streaming video better than other browsers for some reason.
Posted on May 01, 2009
Why does my top load whirpool washer restart on its own after it finishes the last rinse and spin cycle. It does this on all settings, delicate, normal or heavy.
  1. Turn the washer off.
  2. Set the mode selector dial to NORMAL.
  3. Turn the dial counter clockwise ONE click (LEFT), clockwise THREE clicks (RIGHT), counter clockwise ONE click (LEFT) then clockwise ONE click (RIGHT).
  4. Now press the start button.
  5. All the cycle indicating lights should be illuminated.
  6. Press the Start Stop button once.
  7. Rotate the dial until Rinse, Wash, and Stop light illuminate.
  8. Turn the washer off and unplug it for 10 seconds.
  9. Finally, turn on the washer and it should now be reset.
  10. Run a test load empty to be sure the reset worked. If not perform the reset procedure one more time.
Oct 07, 2016 | Whirlpool Whirpool 3.5cu ft Top Load...
Tip
How to Play TS Video Files on Computer? There are many worldwide TV channels...
There are many worldwide TV channels like ABC, NBC, CBS, TNT, ESPN so that we can enjoy movies as we like. Is it possible to record TV shows? Of course, yes. You may find DVRs, TiVo Premiere to record your favorite TV series. You can also use TV tuner to record videos. PCTV nanoStick is one of the USB DVB-T TV tuners, which you may use to record ABC/TNT/ESPN videos.
If you record TNT video files on PC with PCTV nanoStick, you may find the output videos in .ts format. The TiVo Premiere can also produce .ts videos. To play the recorded videos on computer via home network, you may find the .ts file format is not a good choice. The general However, you can convert .ts to .mp4 for easy playback on computer players like Windows Media Player, VLC media player, QuickTime Player.
Here are the simple steps to convert recorded TV shows to computer for easy playback.
Step 1. Load recorded ABC/TNT/ESPN videos to Aunsoft Video Converter.
Run Aunsoft Video Converter as the TS Video Converter on your PC, and click the "Add" button to load the recorded videos for conversion.
Step 2. Choose H.264 MP4 output.
Click the "Format" option and choose Common Video > H.264 Video(*.mp4) to convert recorded videos from .ts to .mp4 for playing on any computer. The file format .mp4 is compatible to almost all computers, and the video compression with H.264 will keep video in high quality with small file size.
Step 3. Convert TS videos to MP4 for PC playback.
Click the convert button under the preview window and the TS video converter starts converting recorded ABC/TNT/ESPN videos to MP4.
After the videos are transcoded to MP4, you can put the videos to NAS to archive the videos, and watch the videos on computer via home network. No matter your videos are from TiVo Premiere, PCTV nanoStick or DVR for TNT videos, ABC videos, you can then freely enjoy movies at home. Aunsoft Video Converter is the partner for your recorded videos for playing .ts files on computer. If you are using iMac/MacBook Pro, you can use the Mac TS video converter to facilitate HD video playback.
on Jul 15, 2010 | Cell Phones
How do i change the time on the three small dials
Hello Garrett,
"Three small dials"... My guess is that we are talking
a chronometer... (stopwatch)... "ZERO Process".
Not only are the three sub-dials usually settable... but also the sweep second hand.
Trouble: After resetting the watch... the hands go back to the same position...
Solution: You want to "ZERO" your dials... one by one.
These watches typically need to have the stem out to the third position... then press the top "start" timer button... observe ONE of your dials is moving. As it approaches the desired number release the button and step it into position with single button pushes.
Go to the bottom "stop" button... Repeat the process!
Push the stem in to the middle "set" position...
Repeat the process!
Again... press the top "start" timer button... zero
and finally press the top "stop" timer button... and zero.
Set the time and date... push that stem back into the home position... and record 35 seconds on your watch... stop and reset...
If everything does not come back exactly to ZERO...
Then that is called an iterative process (do it again).
Fine tune it!
Good Job.
(comment me back if I didn't hit the spot)
Horology Wikipedia the free encyclopedia
Feb 10, 2016 | Watches
Region hack for samsung bd-e5300
  1. With no disk loaded: Press the 'D" / Blue button on the remote.
  2. Next hit the third button from the left on the bottom row of buttons (a blank button).
  3. Press 57358 then the third button from the left on the bottom row of buttons on remote (blank button).
  4. The currently selected region will be indicated on the onscreen display.
  5. Press 9 button for multi-region playback.
  6. When you see '9' appear at top of screen, press the power button. To power off, then when powered back on, the unit will be multi region (DVD).
Jun 07, 2012 | Samsung Televison & Video
Need the manuel original lost or misplaced and can not find. want to record cassettes to cd's
Insert a blank CD-R or CD-RW into the unit. Press the Function button on the remote (key above Vol+ on the bottom right of the remote) or the turntable itself (top left of the control panel) until the unit is in Phono mode. Then insert the pre-recorded cassette and press Play to advance the tape to where you wish to start recording. With the cassette playing, press the CD Record button (recording will flash on the display). The CD Record button is to the left of the fast reverse button on the unit; it is labeled Record on the remote and is below the Stop button. When one side of the cassette finishes playing, press Stop. Wait for the display to return to Phono. Then eject and turn over the cassette to play side 2 (if you want to record both sides of the tape). Press Play again to advance the tape and then press Record. When this side finishes, press Stop and then Finalize. Finalize is at the bottom left of the remote buttons and to the left of the stand by indicator on the turntable.
The manual is available at Crosley: http://www.crosleyradio.com/Product.aspx?pid=1790 . The direct link to the manual is http://www.crosleyradio.com/Manuals/CR248_Manual.pdf . Recording a cassette to CD is on page 11 (page 12 of the pdf).
I hope this helps.
Jun 10, 2011 | Crosley CR248 Turntable
Black Bars each side of my new monitor wide screen
Right Click on an open spot on your desktop.
If your Operating System is Windows XP, choose Properties from the menu box that pops up when you right click.
A new window will open up. Click the Settings tab at the top right.
On this menu you should see a slider bar near the bottom left under "Screen Resolution". Left Click and hold the mouse button on the grey button and move it on the slider bar over to the right one spot. Then click the Apply button on the bottom right of the box. The screen may flicker for a second and your desktop will change size. If the screen covers the whole monitor and the black bars are gone, that may be the correct resolution. Click OK on the box that has a timer and is asking if you want to keep the screen that size. If the screen does not look correct, click No and you may need to slide the button one more spot over and try the next resolution and Apply until it looks correct.
Under the slider bar as you move it over a line at a time will be 2 numbers like this 1024 X 800, and when you move the bar over the numbers will change. I believe the optimal resolution setting numbers for the 20" monitor you have should be 1680 X 1050 for the widescreen. You may want to try that setting. If it looks too small, try sliding the bar to the left and try each resolution setting.
Here's a screetshot of what the Box with the slider bar looks like: http://technophobik.co.uk/vxp_control_panel/f007_settings.asp
If you have Windows Vista, (it is similiar to XP):
Click the Start Button and click Control Panel in the Start Menu
Click Appearance and Personalization in the new window that opens up.
Click Personalization, then click Display Settings at the bottom
A new box will pop up with the grey button on a slider bar near the bottom left under "Resolution" Slide the button to the right to the next line one spot over on the slider bar and then click the Apply button. The screen may flicker and change the size of your desktop. Click OK if the screen looks correct or click No if it doesn't look correct and try sliding the button over one more line.
Jan 21, 2009 | HP W2007 LCD Monitor
ABC Full Episode Player wont play
I found this on another site and it worked for me:
I have really been bothered by having to watch ABC shows online through a tunnel, which as of my most recent discovery was pointless. The problem isn’t with comcast filtering, there is some sort of problem with the ad system they have setup. Some of the ABC affiliates don’t work correctly and cause the shows to never start playing resulting in either a black screen or the waiting cursor circling round and round.
Assumming you have no other problems, open a new browser window or tab and enter the following URL.
http://fep.abc.go.com/fep/player?src=abccomjs&aff=kjif
That’s it, you should now be able to watch all the ABC.com online shows. The only difference is the &aff=kjif at the end. Enjoy.
Dec 08, 2008 | Computers & Internet
As I posted earlier, the problem isn't with any of our hardware or software. Here is some further detail than I posted earlier. Both ABC and FOX use a plugin developed by a company called Move Networks. You can go directly to their site and test the plugin, you can also test by going to Fox and viewing their videos. This tells you the problem isn't on your end, ABC has broken something on their site. This affects both macs and pcs, each of the browsers, again because it isn't related to us, it's their end that is broken. Hopefully this will save you all from wasting time trying to fix what isn't broken on your side.
Mar 27, 2008 | Sony Playstation 3 (PS3) Console
Recordes but dont play back
before you can watch a recorded DVD on another DVD player you must finalize the disc. to finalize the disc put the recorded disc into the DVD recorder, when the DVD loads it will show the titles that are recorded on the DVD on the screen
push the stop button it is the button with the square on it. the screen will go blank or it may let you watch whatever tv channel you are on if you have your tv ran through the recorder, push the setup buton a new screen will come up, with the arrow down button scroll down and highlight disc edit, press ok another screen will come up, with the arrow down button scroll down and highlight "finalize", press "ok" it is the button in the middle of the arrow keys
scroll up and highlight "yes" press "ok" the recorder will finalize the disc and it can be watched on any DVD player, just remember when you finalize a disc you cannot add anything else to the disc.
Mar 02, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Panasonic dmr-es15
Pan. DMR-ES15 I WILL NOT RECOGNIZE ANY DISC I PUT IN. WILL NOT PLAY A COMMERCIAL DVD MOVIE. SEEMS TO HAVE STARTED WHEN IT COULDN'T FINALIZE A RECORDED DISC. HOW TO RESET?
Oct 28, 2007 | Panasonic DMR-ES10 DVD Recorder
Computers & Internet Logo
150 people viewed this question
David Payne
David Payne
