Question about Moyer Diebel 24 in. 501HT Built-in Dishwasher
Parts to fix a leak
I have discovered 2 places where my Moyer Diebel 501HT under counter dishwasher is leaking, 1st it is dripping at the centre of where the drain comes down and as well somewhere under the water heater (can't see where but have the water pooling)so I don't know if you can give any advice and also if you have the water heater part?
3 Suggested Answers
  • 86 Answers
SOURCE: Moyer Diebel Dishwasher arms are not spinning and doing lousy
Hello there
First to check is the water level is it just cover the round filter and no more, or is it much lower from the filter. It seem you have not enough water in the tank to do the washing that is why you have a lousy washing job, not enough water to spray upwards don;t talk about the top spray arm , the water doesn't reach there at all.
You can check it out by manually fill the machine with water up to the filter and start the machine up when the machine is running open the door and you can see the water spray up to the top be careful the water will spray out to your face too.
This is only to check to see the motor is running normally.
If the water level is good ( that is just touch the filter) and the problem still there, then the other cause the problem will be inside the pump motor the part call the impeller may need changing.
Do you have the manual book so I can show you which part we're talking about and let me know where your district so I can tell you where to get the parts from . My email address is dickson@lau.com God Bless Have a nice day, Dickson
Posted on Jul 02, 2009
  • 40 Answers
SOURCE: Moyer diebel 401 ht not reaching temperature ????
could be a number of problems. Checking with an ohm meter would determine the problem. Could be the booster high limit thermostat, a burnt wire, booster thermostat, or a heater element.
Posted on Jan 25, 2012
501 LT starts it's cycle then stops
Could be that the wash pump motor overheats and then shuts down.
Overheating of motor could be caused by too much water in tank (should be level with screen), or a broken part in wash pump, or needs a replacement wash pump assembly.
Sep 18, 2010 | Moyer Diebel 24 in. 501HT Built-in...
Moyer Diebel 501HT goes to temp 57 degree C, it should go atleast 71 degree C, What should i do ? thx.
First item to check would be the high limit switch attached to the outside of the booster. Should have 2 wires. Switch is the size of a dime. The switch has a reset button at the centre. Just push in slowly. You should hear or feel the slight click. Do not touch the wire or terminal at the switch when power to machine is on.
Sep 13, 2010 | Moyer Diebel 24 in. 501HT Built-in...
I have an older model 501ht. It is not getting to 82 degrees centigrade only about 75. Needs to get to 82 to sanitize properly.is there an adjustment I can tweak ?? thanks
Could be that the temperature guage is innaccurate or adjust booster thermostat higher with a screwdriver at centre shaft on thermostat. If you have 2 thermostats together, then its the thermostat on the right side looking to the front of the machine. If the thermostat is already at maximum then replace.
May 21, 2010 | Moyer Diebel 24 in. 501HT Built-in...
Hello there
Apr 27, 2009 | Moyer Diebel 24 in. 501HT Built-in...
My 501HT has stopped draining. It runs through a couple of cycles until the water inside builds up enough to leak out through the door. I have tested the cam switches #3 and #4 and they are opening and...
Hello Dabean
Have you sort out your problem yet if not please email me your problems and I try to sort them out for you my email address dickson@lau.com God Bless have a nice day Dickson
Mar 02, 2009 | Moyer Diebel 24 in. 501HT Built-in...
Where can I get a 10'' Neoprene Hose a-55-f-NSF-51
Let me know where are you located and I'll send you the address to get parts for Your MDM 501 HT my email address is -- dickson@lau.com
may be you have already solve the problem.
Best regards
Dickson
Nov 12, 2008 | Moyer Diebel 24 in. 501HT Built-in...
Moyer diebel 500ht manual
Hello there
Are you ok now , or still looking for the manual if you are then send me a message to my email address and I'll tell you how to get an manual for you machine. if not I'll send you one , God Bless have a nice day Dickson
Jul 16, 2008 | Moyer Diebel 24 in. 501HT Built-in...
Moyer Diebel 24 in. 501HT Built-in Dishwasher Logo
42 people viewed this question
Top Moyer Diebel Dishwashers Experts
Are you a Moyer Diebel Dishwasher Expert? Answer questions, earn points and help others
