Question about Kenmore 12.8 cu. ft. / 362 liter Chest Freezer 13312
Kenmore chest freezer not working
Since yesterday my chest freezer is not working , I can hear it tries to kick in and in few seconds shutts down by itself. What do i check and how to fix it. I have tried adjusting the temperature. tried a different outlet and now i have switched it off completely to check in few hours.
  • tulanh Jun 27, 2008
    I have kenmore chest freezer model 2539163111. It frosted on the top but the bottom of it is not cold at all. I set it to the highest cold. When I open the side to check the compressor, it is really hot almost burn my hand. Is it suppose to be like this or it is bad? I did not see the fan to cool the compressor, where is it located at. Please help. My chest freezer about 5 years or more. Thanks for the input!!! my email is
  • Anonymous Feb 21, 2009
    I have the same problem. It seems that it is the compressor. Mine is 20 years old so I think it is time for a new one! :)
My chest freezer suddenly stopped when I checked power supply is tripped out
Switch it on clicking sound for 2-5 seconds then cut out
Red light at the front is always on please help me
Posted on Sep 18, 2008
  • 4 Answers
You can either get a fridge technician to help you replace your compressor its older than 5 years. Vejas
Posted on Oct 08, 2007
  • 290 Answers
Remove the panel covering the compressor. Remove the relay plugged on the side of the compressor and shake it. If it rattles or has any burned spots it is shorted out. Try replacing it first. Make sure you replace it with the correct replacement, not a fit-all. If this is not the problem you will need to replace the compressor. If it is less than 5 yrs old the compressor should still be in warranty. If so call Sears, it will be repaired free of charge. If it is out of warranty buy a new freezer.
Posted on Sep 25, 2007
  • Michael  Lindley
    Michael Lindley Oct 08, 2007
    Just wanted to follow up on your freezer problem, and see what you found wrong.
Chest freezer upside down
What's the problem? Turn it up the right way, wait a few hours, turn it on as normal
May 14, 2012 | Kenmore 12.8 cu. ft. / 362 liter Chest...
My power wen out and now my kenmore chest freezer high temp alarm is beeping and now it wont cool
I'd turn unit off...unplug it for a few minutes...plug it back in...and turn it back on setting the thermostat again.
Hopefully, you'll hear the compressor kick in and start cooling again.
Hope this helps...
Jul 23, 2011 | Freezers
Red light blinking with audible alarm. Compressor
That is the compressor starting relay trying to start the cooling cycle and the overload protector kicking off. You can try installing a new start device for about $50.00 but you are most likely looking at a compressor replacement which runs about $400.00
Sorry for the bad news
Apr 17, 2010 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Kenmore chest freezer wont cool
Here is a tip that will help you...
There are also more tips at the bottom of this one...
Feb 26, 2010 | Kenmore 8.8 cu. ft. / 249 liter Chest...
Picked up used chest freezer...plugged in and briefly clicks...I can hear it energized for about 5 seconds then then repeats this cycle. It was on its side when delivered
Try to replace the compressor relay (most of the times problem) ,but if still doing the same clicking noise , the problem is in the compressor.
Sep 29, 2009 | Kenmore 19.7 cu. ft. / 558 liter Chest...
GE chest freeze won't get cold
the noise your hearing indicates the possibility of a bad start relay on the comp or possibly it just came loose during the move. on the side of the compressor you will see 2-3 wires running into an electrical connection reseat this first. if still no operation replace teh relay. you can purchase thru any reputable appliance parts dealer. after replacing the relay if you have no operation then likely problem is seized comp.
domestic freezers do not have low pressure switches that indicate low freon charge.
Jan 28, 2009 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
Fridgidaire chest freezer problem
go to your local appliance store and buy a 3 in 1 starter kit,install, directions are with kit,this is your last hope as the compressor is getting weak,hope this help-mike
May 21, 2008 | Freezers
Kenmore chest freezer about three or four years old.not cooling
Probably a freon lean and not worth repairing. You can never find the leak in a chest freezer. Recharging will buy a little time but you can never reallly trust it again.
Apr 28, 2008 | Kenmore 8.8 cu. ft. / 249 liter Chest...
Kenmore 12.8 cu. ft. / 362 liter Chest Freezer 13312 Logo
2,189 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
