Question about Vizio VO37LHDTV10A 37 in. LCD TV
Vizio xvt3d580cm has red contour lines in dark regions of picture. What causes this?
    Novelist:
  • 153 Answers
Does it do this using more than one input? Have you tried using a different source such as DVD? IF using HDMI inputs does it do it on all of them? I have seen this trouble because of configuration issues with some satellite boxes also have seen similar issues because of a bad HDMI input.
Posted on Oct 15, 2013
  • 4 more comments
  • Rick Tompane
    Rick Tompane Oct 18, 2013
    Yes, it has the problem no matter the input. In fact the logo at start-up does the same thing so I know it is not the input source or cable. I also know it is the internal programable system because I can get rid of the worst of it by turning the backlight control to the lowest setting and then increasing the brightness to compensate. The downside it that now bright areas now have cyan lines. So it is trading dark+red for light+cyan artifacts. Thanks for your help
  • Rick Tompane
    I also did the Restore Factory Default reset menu item, but that did not change it. Any thoughts why this would happen?
  • Terry Dovre
    Terry Dovre Oct 21, 2013
    Hello, Rocky is wrong do not replace the back lite board, it's either the t-con or a bad display panel and my money is on the panel. the way to tell is you have to unplug the lvds cable from the t-con and see if the lines are still there, the screen should be a very bright blank screen.....tks
  • Terry Dovre
    If the red lines are still there , it's the display panel...tks
  • Rick Tompane
    Rick Tompane Mar 06, 2014
    Just in case anyone else has this problem, it is now gone! I temporarily got rid of it by using the custom display parameter screen to turn the backlight down to zero (still plenty bright) and turned brightness up to about 65. That made it watchable and after a few months, it just slowly disappeared and I can turn up the backlight if needed. It is known that some analog (like the DAC converters) do age (like a fine wine) and so probably some units were over driven at factory setup or did not get enough burn-in time before shipment.
  • Rick Tompane
    Hope that helps someone else.
2 Suggested Answers
  • 302 Answers
SOURCE: Vizio LCD dark screen and picture is flickering flashing
Your back light inverter is provably bad.
You can get get parts for this tv at www.interliquidparts.com
Posted on Nov 26, 2011
VIZIO Tv E422VA picture showing red or green color on dark areas of screen.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 29, 2015 | Vizio E422VA 42-inch Widescreen LCD TV -...
My Vizio TV has dark spot top left corner
Hi Brandon,
I am afraid that the dark spot in the screen is not repairable. Manage as long as you can or go for a new tv.
Apr 08, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
Vizio vertical line
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Apr 03, 2017 | Televison & Video
Vizio display issues
Picture has red static or lines
this symptom is mostly caused by a failure of a device called a degauss posistor, this is mostly a 3 legged device found in the switch mode power supply region. it looks like a relay, replace this device and it will cure this problem
Oct 01, 2011 | Vizio L32 32 in. LCD HDTV
Samsung big screen tv model pcl542r has a green or red tint to picture
This is for the 50" Vizio TV,
It sound like the control board has a problem. There is two way to fix this.
- Upgrade the firmware of the control board, If you can find the firmware upgrade device.
- Replace the control board (I think this the best solution)
Feb 08, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Wavy red lines or red pixelation, not sure what it is
Go to Vizio website and buy the extending warranty, you need to have your TV replaced since the problem is with the screen itself.
Dec 15, 2008 | Vizio L32 32 in. LCD HDTV
Vizio VO37LHDTV10A 37 in. LCD TV Logo
123 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
