Question about Reebok Vista Treadmill - RBTL13305
What will happen when the drive belt of the treadmill is over tension?
    Top Expert:
  • Reebok Master
  • 12,223 Answers
The machine can be stop and trigger the c.breaker or fuse+ and the motor can be overheating and eventually burn.
adjust the tension by 1/4" of deflection.
God bless you
Posted on Oct 14, 2013
2 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: right side belt tension adjuster is broke. how do
Call Icon Fitness @ 1-800-999-3756
Part# 223406 Cost $7.30
Posted on May 20, 2010
Belt keeps slipping on treadmill
Adjusting Tension on a Treadmill Running Belt It is necessary to properly tension a treadmill belt when it is replaced. After time, a belt can stretch and may begin to slip. When this happens, it is necessary to adjust the tension of the running belt to stop it from slipping. Manufacturers of treadmills generally agree on one of three procedures for how to tension a treadmill running belt.
  1. Adjust for no slippage of the treadmill walking belt on the front roller (Often referred to as the "Stomp Test")
    1. This procedure works well for a previously installed belt that is now slipping.
    2. Underside of belt should be free of any glazing/wax buildup.
    3. Rollers must also be free of wax buildup.
    4. Be sure belt tracking/centering is correct before proceeding.
    5. The most popular speed for this adjustment is 2mph to 3mph.
    6. Try to slow the belt by applying pressure with your foot against the belt movement while grasping the handrails. If the running belt slow, slips or stops (and the front roller does not) adjust BOTH adjustment bolts 1/4 turn clockwise. Test again and repeat adjustment if necessary.
  2. This procedure requires two belt gauges or calipers
    1. This procedure works well when installing a new belt.
    2. This procedure requires you to stretch the belt. Depending on the manufacturer*, this varies between .4 and .6 percent. A dial on the gauge or caliper will indicate the amount of stretch. *Consult the owner/service manual for proper tension.
    3. If you are working on a previously tensioned belt you will need to release the tension before attaching the gauges or calipers.
  3. Gauges or Calipers unavailable
    1. Release the tension on the belt.
    2. Using a yard stick or tape measure, place two marks on the left and right edges of the belt and deck 36 inches apart (or 50 inches if you prefer).
    3. Adjust the left and right tensioning bolts until both sides measure 36 3/16 inches (or 50 1/4). This is equal to .5% of stretch.
    4. Test for proper tracking and tension, adjust if necessary.
How to Tension Treadmill Walking Belt that Slips
Apr 01, 2014 | Life Fitness 91Ti Treadmill
New running belt tracks to thr left
Feb 04, 2014 | Precor C962i Treadmill 220V
Walking belt alignment how to
Jan 07, 2014 | Precor Treadmill Belt 9.10, 9.2 Treadbelt...
How do I tighten drive belt on precor 956i
Jan 04, 2014 | Precor 956i Experience Series Treadmill...
Walking belt slipping
Dec 22, 2013 | Precor Exercise & Fitness
Adjust belt side
Dec 19, 2013 | Precor 9.21 Treadmill
How do you adjusting the running belt on precor 9.1 treadmill
Mar 13, 2013 | Precor Exercise & Fitness
Precor c944 treadmill belt slipping
Feb 05, 2013 | Precor C944 120 Vac Version 1 Treadmill...
The belt is stuttering on treadmill when walking on it
1) LUBE the deck belt, this happen to due the lack of maintenance according with your instru.manual follow the step donwloa your instruction manual. go www.fitness.manualsonline.com or www.iconservice.com
2) LUBE the rollers bearing very well.
3) Tight with NOT much tension the drive belt.
4) Adjust the tension deck belt see the diagrams attached.
Sep 02, 2012 | Exercise & Fitness
My Proform 650v treadmill stop when running after couple of miles
Most likely a bad drive belt. Take the cover off the motor area. If you see black dust near the left side of the motor, replace the drive belt.
Oct 29, 2009 | Proform CrossTrainer Treadmill
Reebok Vista Treadmill - RBTL13305 Logo
48 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
