Question about All Years Kawasaki Kaf300 Mule 500 520 550 Atv Deep Cycle Trugel
My Kawasaki mule 550 clicks and the starter wont turn over. it has a new battery and selonoid.
  • Anonymous Mar 23, 2014
    I have a 2011 Kawasaki mule 4010 4x4. When I go up hills, white smoke billows out of the exhaust.
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
It could be a relay clicking. Check with the parts department to find out if it `has one.
Posted on Oct 14, 2013
  • romie young
    romie young Jan 06, 2014
    no it doesnt drain if i keep lights off and dont use my plow could it be a drive belt or the magneto to keep battery charged
Decompressor problem 1993 Kawasaki klf400 engine won't turn over.when engine gets to compression stroke the one way starter bearing squeals.
Hi, Frank and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://www.kawasakimotorcycle.org/forum/kawasaki-atv-mule/118754-klf400-b1-wont-start-please-help.html
Kawasaki Bayou not starting
Kawasaki Bayou 400 service manual repair 1993 1999 KLF400 Download Manuals...
OEM Parts for Kawasaki
Owner Manuals Service Manuals Kawasaki Vehicles
Jan 15, 2017 | kawasaki Motorcycles
Kawasaki problems
it can be a few things it can be a bad solonid, bad connection, bad battery, or your starter needs new brushes
Jul 23, 2014 | kawasaki 2010 Mule 600
Where is spark plug located on 550 kawasaki mule
on engine head it will looks like cermic...you want to pull the socket first...
Feb 08, 2014 | All Years Kawasaki Kaf300 Mule 500 520 550...
Kawasaki mule 3010
Check the starter or solenoid.
Apr 27, 2013 | kawasaki 2008 Mule 3010 Trans 4x4
Kawasaki Mule 500 KAF 300 starter will not work below 60 degrees.
Using a lighter viscosity engine oil can make all the difference. Try something on the order of a 5W-30 for ambient temperatures of 60F or below. Of course, it could also be that your starter solenoid is in the early stages of failure. You can easily check it by using a large screwdriver to bridge the two large cable connections on the top of the solenoid. If the starter spins when you do this, then the solenoid is bad.
Dec 07, 2009 | 1998 kawasaki KLX 300
DO YTOU HAVE TO PULL THE STARTER ON A KAWASAKI MULE 550 TO REPLACE THE SELINOID?
i do believe that its easier to replace the silynoid with the starter out of the machine that is if it isattached to the start other wise no if its like most kawasaki four wheelers you need to disconect the abttery and then trace the main power to the silynoid and disconect it there also and then remove and install new silynoid
Nov 02, 2009 | 2000 kawasaki KLX 300
All Years Kawasaki Kaf300 Mule 500 520 550 Atv Deep Cycle Trugel Logo
477 people viewed this question
Top Bikemaster Vehicle Parts & Accessories Experts
 Russ Hill
Russ Hill
R.Karthikeyan
R.Karthikeyan
Willie Keisser
Are you a Bikemaster Vehicle Part and Accessory Expert? Answer questions, earn points and help others
