Visco TV over heating Seems to be ok for a long period of time after cooling off but seems to go ot sooner when used as a "Gaming"TV
    Master:
  • 359 Answers
Is this TV still new and under warranty? You should not be having heating issues with your TV as that can be dangerous and cause a house fire. If you have any other devices or material near the TV that would be insulating it you should get it away from it. I would contact the manufacturer if you are using the TV properly, this is a safety hazard and should be addressed.
Posted on Oct 14, 2013
Heat will only work periodically
Definitely check your antifreeze/coolant level ASAP.
Feb 12, 2014 | Chevrolet Traverse Cars & Trucks
Hitachi TV Model 43FDX10B
open it up get dust all out clean it well ok then ya use fans around it vented area to keep it cool its getting to hot dust build up
Jan 28, 2008 | Hitachi 43FDX01B TV
Runs to hot in the summer
its probable the viscos fan not working properly does it over heat only when its standing still but is ok when its moving if this is the case its the rad cooling fan
Aug 22, 2013 | 1993 Mercedes-Benz 190
Whats does P1 mean on my portable ac unit everstar model # mpn1095cr-bb6
What if you don't have the drain hose that came with it can you use any hose?
Jul 30, 2012 | Heating & Cooling
Why does my new iPad get so hot when I play games on it?
Hi Jessica,
Much to your chagrin I bet, there's not too many options besides "play it less" if you want to cool your new iPad down. If the heat is an issue for you now it is probably going to continue to be an issue for you later.
Having said that, there are a couple ways I have used that seems to cool down the iPad by a few degrees:
  • Turn down your screen brightness. This is the best way for you to avoid heating issues. Your new iPad probably came out of the box with brightness turned all the way up. If you turn that down you will notice a decrease in heat immediately.
  • Use Wi-Fi instead of 4G LTE whenever possible. Now obviously you can't do this everywhere, but whenever possible you should access the internet via Wi-Fi and avoid riding your 4G LTE chip. That baby is power hungry and will heat up quick.
  • Give your A5X chip a break. In less technical terms, try not to play graphics heavy games (like Infinity Blade) for an extended period of time. Like you said in your question, that's when you experience the most heat discomfort. If it is at all possible for you to take even a short break (like 10 minutes every hour) from gaming, it should do a lot to keep the heat down.
I hope that helps you out!
Mar 27, 2012 | Apple iPad HD
My TV after being ON for about 10 minutes will shut off by it self. You can turn it back ON but it turns off rught away?
Hello
From your brief explanation I thinks that there is some loose solderings inside your TV. To make sure about it, you just give a small hit with your palm on the top or side or your TV, when it shuts down. Never use any hard material. Use ony your palm. If it comes on atleast for a short period of time, you can determine that there is some loose soldering inside it. As it is a 13" TV, and a small one, you can do it by yourself. Open the back cover, and pull out the printed circuit board inside, anc check for any component for loose contact. If it seems to be, resolder the point by applying a little more solder. Usually, some components of all TVs will heat up while working. Repeated heating and cooling can cause loose soldering contacts.
Do this first, and wants any more explanations, ask me through Fixya. Ok.
Nov 04, 2010 | RCA E13309 13-Inch Diagonal XL-100¿...
Kenmore Microwave Oven model #401.80082700
Sounds like a bearing is tightening up when it get heated up with use. Then after a cool down period it works normally until using it heats it up again. Eric
Sep 15, 2009 | Kenmore 62622 Microwave Oven
2006 ford f-250 diesel with no heat
it takes quite a while for a diesel to warm up by just idling in order to produce any heat.you have to put them under a load (drive it), before you will get any noticeable heat.if you have a block heater, plug it in 4-5 hours before you plan on driving it and that will definitely help produce interior heat quicker.
Feb 22, 2009 | 2006 Ford F-250 Super Duty
Goodman PHJK048 Heat Pump Package
ok...where to start.lol ....the thermostat is just a switch.It will tell the unit to run or not run.if you measure the temp with the heatpump running,the air is warmer than 68 but it feels cool to you because your body is 98.6.The unit will run more often and for longer periods when the temperature drops outside for a few reasons.First,your house has more of a load to heat,meaning you have more heat loss because of the difference in temperatures outside and inside.Second,your heat pump pulls heat from the outside air.The colder the air outside,the less btu's for it to pull.If you have anymore questions hillbuck29@aol.com Hope this helps,Dave
Nov 10, 2008 | Goodman PHKJ048-1 Air Conditioner
Refrigerator temp disply shows off /off
Read manual. Indicated need 24 hous to stabilize. Minimized use and it reset OK. Thanks
Nov 04, 2008 | GE Monogram ZISS480DRSS Stainless Steel
Televison & Video Logo
Top Televison & Video Experts
