Question about Euro-Pro Toaster Ovens
Bravetti 1200w to283b - Euro-Pro Toaster Ovens
Can I get parts for a Bravetti convection toaster oven, specifically upper elements?
Fixya does not sell replacement heating elements. Try checking with a local appliance parts supplier.
Aug 22, 2016 | Euro-Pro EP278 Bravetti Platinum 1500...
Euro-Pro Bravetti Model To283B
You may have to start all over again with a replacement oven. Never, never, never use oven cleaner in this type of appliance!
Oct 13, 2013 | Euro-Pro Toaster Ovens
3 yr old Bravetti Plat. Pro microwave/convection does not heat food. Lights, turntable work. Is there a fuse somewhere that is blown???
in 90 % of my microwave is damaged the magnetron, on the electronic plate you have 2 fuses and dawn under the rear fan you have another fuse(glass fuse) in a plastic cover.
Feb 21, 2010 | Euro-Pro EP278 Bravetti Platinum 1500...
Bravetti Toaster Oven
If you just purchased the toaster oven, contact the store that you purchased it from, and they should be able to get a manual for you. If you've had the toaster oven for awhile (usually 3 months or more), you'd have to contact the manufacturer (Bravetti) for the manual--a lot of times, their phone number is printed right on the back (or bottom) of your oven!
Good luck! :)
Aug 26, 2009 | Toaster Ovens
Lost instruction manual for Bravetti Model#TO285 toast/conv.oven
The same unit was marketed under the Euro-Pro name, with the same TO285 model number. The manual, as a PDF, as well some replacement parts are available at this link:
http://www.euro-pro.com/europro/default.aspx
Hope that helps.
Nov 30, 2008 | Euro-Pro EP278 Bravetti Platinum 1500...
Toaster Ovens Logo
Top Euro-Pro Toaster Ovens Experts
Dave
Dave
eyecam
Are you an Euro-Pro Toaster Oven Expert? Answer questions, earn points and help others
