Question about Stanley Bostitch BT200K
I have a nearly new Bostitch SB-125BN nailer and it won't shoot the brads. It worked fine at first, then I didn't use it for a year or so and even though I use the same pressure on my other Bostitch and it works fine, the SB-125 sounds as though it doesn't have much pressure and it won't shoot the brads?? Help.
  • 1388 Answers
SOURCE: air allways and continually leaks forcably from the top. Bostitch
This nailgun has several parts to the headvalve that must fit together properly to seal. Go to WWW.toolpartsdirect.com for a diagram of this tool. The part called the diaphragm is source of problem. It has thin vinyl walls that will fold over when you assemble. The piston will not cause the gun to leak, just make sure that piston fits snug into the cylinder. Loose oring on piston will only cause low power or the poston may not retract all the way back up. Some piston/drivers had a plastic ring instead of an oring. The plastic ring had a secondary oring under, however not necessary. You can use rubber or plastic, just make sure that the piston is not too tight or too loose. The piston oring is the only oring in the gun that can be cut to fit. It is like a piston in a car engine. The piston rings have a gap.
Posted on Nov 25, 2008
  • 10865 Answers
SOURCE: Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
Posted on May 20, 2009
  • 36 Answers
SOURCE: 18 ga. Bostitch nailer that has a small brad jammed in it.
check your hex wrenches they could be standard when they need to be metric.
Posted on Sep 23, 2009
rowdy45176
  • 2176 Answers
SOURCE: brand new brad nailer shoots 2 nails and then it
first make sure that you are using the right guage nails and if so I would return it to the place of purchase for replacement., the blowing of air could indicate a jammed nail in the track, look for that first and make sure the driver is retracting fully.
Posted on Dec 19, 2009
  • 1388 Answers
SOURCE: My Stanley Bostitch SB-1850BN brad nailer will not
You may have a broken tip or bent driver. Remove tha nails from gun and dry fire into a piece of wood. You should see a nice little indention. If you continue to hold the trigger and the nailer against wood after firing, the driver will stay in the lower position for examination. Just fire into wood and keep gun against wood while holding trigger and lean gun to side untill you see the tip. If you see broken tip or no tip order repair kit that includes driver, or driver alone from www.bostitch.com or ebay. Good luck
Posted on Sep 09, 2010
Firing pin won't return SB 1842bn
Lubricate it and crank up air pressure and return spring.
Feb 14, 2012 | Stanley Bostitch Sb1842bn 18 Gauge Brad...
New model sb-1850bn will not operate at all. Oiled it lightly before trying to use. Air comes out around trigger.
If the air is coming out of the trigger when you try to drive a nail, most likely the driver is broken.
Bostitch nailer have a 7 year warranty on them so, take it to a Bostitch service center and have it repaired there.
Dec 16, 2010 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
When I pull trigger air is escaping around the trigger and nailer will not engage
you need a new trigger valve assembly, there is an o ring that has split. Contact Bostitch for a replacement part.
Oct 08, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Nail jammed in Stanley Bostitch SB-125BN Air nailer
Please see the link below and enter the model number. That will get you to a complete parts breakdown diagram from which you can dis-assemble the unit and remove the jammed nails.
Dan
Link: http://www.ereplacementparts.com/bostitch-parts-c-29443.html?gclid=COqqlsL3wqMCFZxo5Qod4gOiag
Aug 17, 2010 | Stanley Air Tools & Compressors
I have a Stanley Bostitch Sb 2IN1 2 In 1 Narrow Crown Stapler/18 Gauge Brad Nailer gun. How do I adjust the depth the nailer shoots the brad nails into base boards? I see that their is a dial on the back...
look on the front of the tool.there is a dial right where the plastic meets the yellow housing.also look closely and you should see a diagram on the plastic telling you whitch way to go.
Jun 12, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
My brad nailer shoots staples without any problem but it jams on the second brad after being freed up from the previous jam. How to I rectify this problem. It is a fairly new stapler/nailer and has done...
Shoots staples fine but brads jam or bend. Check that the part called "guide bar", #35 on the parts diagram isn't getting stuck in the channel of part #30.
The guide bar retracts into the channel when driving a staple and springs out of the channel to guide brads.
The guide bar can get stuck in the channel if it's bent or gummed up. (Bent is likely the result of driving a brad into an obstruction.)
Mar 26, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Not shooting
Trigger Valve needs replacing. Part Number is FA205BA1. The valve comes with instructions, its a pretty easy fix. Any BBostitch dealer should be able to get you one.
Mar 11, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
The gun will fire staples, nails do not set.
The business end should look like this:
Mar 07, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
My Bostitch SB 2in1 nailer will only on occation nail all the way into the wood. For the most part the nail will bend over before it goes in, which damages the wood. I spend more time tying to pull out...
I ran into this problem many times. Don`t use the Bostitch brand nails. Use the generic or other name brand. You`ll notice the generic one`s heads are just a little bigger and the driver blade won`t run down the side of the nail!
Thanks,
Jeff
Jan 05, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Stanley Bostitch BT200K Logo
238 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
