Question about Microwave Ovens
Panasonic microwave oven nn h965wfx
My microwave suddenly stopped cooking...you can put in the cooking info, but nothing happens...timer counts down 2 seconds then clears the screen never actually turning on
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 113 Answers
Either your magnatron is bad or hopely it could be your high or low heat sensor
Posted on Oct 14, 2013
  • 96 Answers
SOURCE: Touch pad works but microwave doesn't turn on
NO the microwave doesn' t overheat or froze.
I couldn't answer to your question 100% because I don't know this model,
Some microwave don't heat if you don't set the heating temputer on, the power level. I've seen lot's of customer in the past couldn't get heat because all they press was time and didn't set the heat level.
second it is posible it doesn't heat because the magnetron power supply is burt out, this is the electronic board inside the unit below the magnetron, panasonic or know for burning this board to often, if it was I, they would have been design to inposible to blow them . Microwave have gone a long way and notice that the quality is not there no more. The old once or the same thing as the new once's but made more of plastic. The parts (main parts) or all the same design but mad to brake down after a shorter time. The older model lasted a minimum of 20 years, today they have the same magnetron but they don't last as long as before, made to brake. If they brake faster, the re sale or higher so more money to make.
To me it's just insulting to think that way, vehicule or the same , the repeat parts sales make profit go higher. It's all a tratege to make money faster and not respecting the consumer.
Third problem you may have is the magnetron is shut or the cap.
You would need a tech to tell you that part.
Regards
Bob
ps do what 99% think like trough it out, but make shure you understand you're creating polution everytime.
Posted on Jan 20, 2008
Coldcut
  • 1554 Answers
SOURCE: Emerson Microwave MW8115SS
there is a thermal fuse inside that is likely blown.
easy to replace just have to google bullet thermal fuse.
Posted on May 12, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: The touch pad works, the
http://www.microwavedisplay.com/doorsw.txt
Posted on Nov 26, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave Oven Does Not Start Cooking
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If yours is not shown at the parts site or manual site linked above, Please reply back with your brand and model number so we can help you.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Dec 25, 2008
EwingElect
  • 276 Answers
SOURCE: our microwave oven Panasonic NN-S252WF stops after
Our technician suggest that there may be a problem with the Inverter Board in this model, which is something that would need to be looked at by a Service Center.
In rare cases it could be the door switches.
Posted on Mar 27, 2009
Panisonic inverter microwave lights up but doesn't fully come on
How to fix microwave that counts down but does not heat or ...
? 4:51
https://www.youtube.com/watch?v=PIU1NRpeA_8
Oct 2, 2012 - Uploaded by G-Unit_YouTuber
How to fix frigidaire microwave door sensor relay switch. ... with a different part number (D3V-16G-2C25) but it doesn't look like it's stocked. ... Problem now is that when we open the door, themicrowave comes on by itself! ... I am not sure, when you hooked up the volt meter, did the lights turn on and off ...
All comments on Fixing Panasonic inverter microwaves ...
https://www.youtube.com/all_comments?v=hBJJU4ZRh7U
i have a nn-h965wfx the light comes on the countdown initiates but nothing comes .....I have a similar full size panasonic inverter microwave NN-L931BF built in ..... After putting it all back together the thing doesn't even power up the display.
Panasonic 1200W 1.2 Cu. Ft. Countertop Microwave Oven ...
www.amazon.com/Panasonic...Microwave.../B005BFZ...
Amazon.com, Inc.Ft. Countertop Microwave Oven with Inverter Technology NN-SN661S Stainless at Amazon.com. ... The microwave panini meals even end up with toasted crisp bread. ...But, right now, I find the interior light functionality just fine. .... (1) In this Panasonic, the light doesn't come on when the door is open; it only comes on when ...
Jan 05, 2016 | Microwave Ovens
This is actually a one-year-old Panasonic Inverter NN H965WFX 1250 watt microwave. The light inside flickers and staggers a bit, and the microwave does not heat or cook properly. The first time this...
Inside is a screen which sometimes arc. These are normally available from the dealers and is not very expensive. Microwaves are dangerous and repairs are better left to trained people.
Jan 03, 2018 | Panasonic NN-H965 Microwave Oven
1200 watt panasonic, power on but will not perform
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
best regards .
please don't forget to rate !
Apr 04, 2010 | Panasonic NN-S262SF Microwave Oven
I have the same problem with Panasonic NN-8501V Microwave Oven
I took the touch pad control unit apart, clean the connector for the ribbon wire connection between the key pad and the control unit, reseated the ribbon wire in the connection. Everything worked like new.
Oct 16, 2009 | Panasonic Microwave Ovens
Microwave wont start but timer counts 3 secs and shuts off
Check the door latch mechanism the black nylon door catch may be broken.
Jun 19, 2009 | Panasonic NN-T993SF Microwave Oven
Setting time on Panasonic NN-CD748B microwave
Panasonic's UK site is here and you can choose Support, then search for spares, servicers, downloads and contact info.
Jan 05, 2009 | Panasonic NN-S753 Microwave Oven
Oven won't heat and shuts down after approx. 20 seconds
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Dec 18, 2008 | Panasonic NN-S763BF Microwave Oven
Panasonic NN-2501 Microwave Oven range hood
It is possible that the magnatron is bad but hard to say on a no heat problem without checking all components. A lot of model give 5-7 yr warranty on that part.
Oct 05, 2007 | Panasonic NN-S251 Microwave Oven
Microwave Ovens Logo
204 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
