Question about Medical
I need a plastic diffuser for an old monarch medicine cabinet
2 Suggested Answers
  • 4 Answers
SOURCE: I am replacing my sink, medicine cabinet and adding a small cabinet below the sink. I need to know how to remove the old and install the new.
The task you are embarking on is a great DYI project. But, be forewarned, it can get tricky. First, make sure the new sink will fit in the space of the old sink. If not do you have enough space for the new sink to fit securely against the wall? Next, remove the cabinet. There should be about four screws. You may also have to use a razor to cut calking from around the outside of the cabinet. Sometimes it's used to fill-in gaps between the tile and cabinet. Remove the cabinet. If the cabinet is setting in the wall, make sure you check and see where the support beams are located. If you are not putting in another wall cabinet, then you will have to know what kind of wall you have. Sheet rock, no problem. Plaster requires a bit more work. Measure the hole, and then you will need chicken wire, lime, plaster, paint, and matching tile. Fasten the wire to beams in the wall. The wire will hold the plaster in place. Let dry, sand smooth then paint. If you have sheet rock walls measure the hole cut the sheet rock to fit. Fasten it to the beams, use plaster or Spackle to cover the holes from the screws. You will need sheet rock tape to hide the space between the existing wall and the sheet rock patch. Smooth on cover the tape with Spackle, smooth by sanding.
To remove the sink: first, turn off the main water supply. Get a pipe wrench and remove any connections. If you're not familiar with plumbing you may want to get a plumber to attach the connections.
Putting a cabinet under the sink is the easy part. Make sure you have the right size cabinet. Get a leveler; make sure the sink and cabinet are level. Depending on your walls, you can just screw the cabinet to the wall. If they are plaster walls you will need wall anchors. That should do it. Enjoy
Posted on Feb 23, 2013
The back of dryer drum rubs on the gas diffuser lip
You did get the right replacement bearing assembly; did you also replace the bearing retainer and ground strap to the gas diffuser?
I'm sure you followed the repair procedures as described in this video http://youtu.be/MPXu-Ya8CBY
And if you did double check everything I suggested- then the next thing I would have to ask, is the noise you are hearing only happening when the dryer is full of clothes or does it also occur when the drum is empty?
If the noise occurs only when the dryer has clothes in it, you may be overloading the dryer.
If the dryer is making the noise whether the drum is loaded or unloaded, then the next logical step is to check for level.
Place a carpenter's level on top of the dryer; check it side to side; and front to back; adjust the leveling legs if necessary.
From my experience, a scraping sound could be caused by metal or hard plastic objects getting caught between the cabinet and front seal of the drum. And you already had it apart to replace the front bearing and slides; and I'm sure you inspected the diffuser for any damage or being out of round when you installed the rear bearing...at this point, predicated you did replace the bearing retainer and ground strap- the only 3 things you didn't replace is the gas diffuser, the drum, and diffuser- not to suggest that you do :) Please keep me posted. Best regards.
Mar 11, 2014 | Dryers
Feb 23, 2013 | Plumbing
Where can i buy a medical cabinet so I can keep our drugs in a safe place.
You can actually buy medicine cabinets in most DIY/ home store places but there are also websites that specialize in medical cabinets if you are looking for something in particular.
Take a look at this website as an example;
http://www.quickmedical.com/clinton/medical_tables_cabinets/index.html
Jan 14, 2013 | Medical
I am sorry but i didn't understand if i need to mix de medicine with water or put in medicine cup. I lost the instructions....thanks
the vapour oil medicine is put in the little reservoir right at the front top on the blue unit that sits on the plastic base... about a tablespoon. It will still be there after use, but it's only oil residue, after the medicine has evaporated with steam. clean it out with paper towel and refill for each use when needed. Only salt is added to the water, not the oil...
Mar 09, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
The light diffuser cover is broken. The model number of the range hood is HO60488. The range hood dates back to possibly the late 1950's when the house was built.
When faced with the total unavailability of replacement parts, its time to get creative, and make your own diffuser cover. Flat ones
can be easily made - find anything plastic that's semi-translucent (like a plastic milk bottle), and cut it with a utility knife.
I have also used a utility knife to cut a polystyrene diffuser cover
originally intended for a 2-ft x 4-ft suspended ceiling fluorescent light fixture.
In case the diffuser cover you make wants to burn when placed close to a light bulb, replace the bulb with a CFL (compact fluorescent) bulb, which run MUCH cooler than incandescent light bulbs.
Old lampshades can be cut and used, but may need to be ironed flat. The major advantage of lampshade material is that
it can be folded over at the edge once or twice, which will fill space - and possibly hold the cover where a plastic sheet might be too loose.
You'll know that your efforts have met with success when you can easily remove your ne diffuser cover to replace the light bulb.
Feb 20, 2011 | Venmar Kitchen Ranges
How do i replace the ink roller in a monarch 1131 price gun
To replace the ink cartridge, turn the latch on the right side of the gun to an upright position. Pull the door out. The ink roller is on the end of the door in a plastic holder. Push the holder apart slightly to remove the old ink roller and insert a new one. Replace the door and turn the latch to hold it in place.
Nov 15, 2010 | Monarch Pricemarker Kits
Where can I purchase a mirrored sliding door for my medicine cabinet made from Broan-nutone.
Simple, go to your local glass and mirror shop every town has one and have them cut a piece of mirror for you, all they might need to know is the thickness of the old piece. Good Luck make sure I get Kudos for this answer.
Jun 11, 2010 | Home
How to replace light globe in Chateau Grange rangehood
I have a 600mm Chateau range hood with the same problem. To access the globe chamber, you need to first remove the plastic diffuser from the underside of the rangehood. Located at one end of the diffuser will be a small slot approx 10 mm long. Insert a small flat blade screwdriver into this slot and carefully depress the plastic tongue of the diffuser by gently pushing the head of the screwdriver away from the diffuser. As the tongue disengages from the frame you should be able to grasp the edge of the diffuser and pull it away from the frame. Once the diffuser has been removed from the frame, you will be able to change the globe.
To reinstall the diffuser, insert the plain end of the diffuser into the frame of the the rangehood (above the globe) and gently push the clip end back to its flush position.
Nov 17, 2009 | Kitchen Ranges
Our machine sounded wierd last night and we found out that the water is no longer coming in. And we found a melted plastic medicine cup in the machine. Where do I look to see if plastic is blocking the...
Are you sure it is a medicine cup and not the float cup that controls the water level ? The float is a cup with a rod in the center that goes into a tube sticking up in the bottom of the machine. The rod reaches through the
tub and sits on a switch that controls the electic water valve. it its easy to replace.
Oct 27, 2009 | Maytag Dishwashers
How do Iget into the gear area of my Monarch 9400 Printer
The Ink reals and printhead assembly are all mounted on the single
black plastic mold which is held down by three mounting screws.Two
of the mounting screws are up front ; one within a long thin well, the
third is in back. Any long thin Philips Screw Driver will do.
Jul 30, 2009 | Monarch 9403 Thermal Label Printer
Medical Logo
299 people viewed this question
Top Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
Are you a Medical Expert? Answer questions, earn points and help others
