Question about HP Officejet 5610 All-In-One InkJet Printer
Paper prints out in small increments, pausing every 15 seconds.
    Scholar:
  • HP Expert
  • 199 Answers
REMOVE AND CLEAN THE CARTRIDGE CONTACTS(GOLDEN DOTS) WITH SOFT CLOTH AND TRY IT BACK. IF THE CARTRIDGE IS NOT DETECTING PROPERLY IT MAY TAKE MORE TIME.
Posted on Oct 16, 2013
Printer won't work says it is paused
Check your settings , & unpause it !
Mar 17, 2015 | Office Equipment & Supplies
How do I take Canon imageCLASS D320 All-In-One Laser Printer off from "paused" status?
On the printer properties on the computer there will be a paused option (Normally marked as "Pause Printing") in the printer drop down menu on the Printer Queue screen. Click this to remove the tick next to it and it should start printing again.
Feb 20, 2015 | Canon imageCLASS D320 All-In-One Laser...
Epson lq-2180 printer paper out & pause Indicator continously on
I have epson lq-2180 printer with the following problem: Paper out & pause indicator is continously on when I try to print. The paper is rolling when I push pause button.
Jan 22, 2013 | Epson LQ-2180 Dot Matrix Printer
Ltf2140
WAKE THE WASHER BY PRESSING ANY BUTTON.
WAIT 5 SECONDS.
PRESS AND HOLD THE START AND PAUSE/CANCEL BUTTONS SIMULTANEOUSLY.
ALL LED'S WILL GO BLANK AND AFTER A FEW SECONDS THE CONTROL WILL SIGNAL THE STORED CODE USING AUDIBLE BEEPS AND BLINKING LED'S. THE CONTROL WILL REPEATEDLY SIGNAL THE CODE, AS LONG AS THE START AND PAUSE/CANCEL BUTTONS ARE PRESSED. A TWO-SECOND PAUSE BETWEEN REPEATS AFFORDS YOU THE ABILITY TO MAKE ACCURATE COUNTS TO IDENTIFY THE CORRECT ERROR CODES.
PLEASE NOTE THE FOLLOWING: ON A SMALL NUMBER OF WASHERS WITH SERIAL
NUMBER PREFIX XC4, IF THE PREVIOUS PROCEDURE DOES NOT PREFORM AS
SPECIFIED, FOLLOW THE OPTION BELOW:
* FOLLOW ALL PREVIOUS STEPS BUT INSTEAD OF PRESSING START AND PAUSE/CANCEL BUTTONS, PRESS AND HOLD OPTIONS AND PAUSE/CANCEL BUTTONS."
*THE CONTROL WILL PAUSE FOR 2 SECONDS, THEN REPEAT THE CODE AS LONG AS THE TWO BUTTONS ARE PRESSED AND HELD."
NOTE: A LETTER APPEARING IN THE CODE STANDS FOR A NUMBER HIGHER THAN NINE: A=10 B=11 C=12 D=13 E=14 F=15 "
"EXAMPLE CODE F1: THE FIRST DIGIT WOULD BE 15 AND THE SECOND WOULD BE 1. IF THIS CODE WOULD APPEAR ON A WASHER IN THE GOOD MODEL LINE, THE FIVE INDICATOR LIGHTS WOULD BLINK FIFTEEN TIMES AND THE START INDICATOR LIGHT WOULD
Jul 29, 2012 | Frigidaire GLTF2940ES Front Load Washer
Power went off when I tried to print
Would be helpful to know which operating system you are using and whether there where any warning light flashing. For starters review the following solutions.
Printer Does Not Start or Stops During Print Jobs
Inner Cover was open when you started printing.
Close the Inner Cover and press the RESUME/CANCEL button on the printer. The printer resumes printing.
Inner Cover was opened while printing is in progress.
A page of print data being sent at the time of the error will be erased, so print that page again.
The printer has been printing continuously over a long period.
If the printer has been printing continuously for a long time, the Print Head may overheat. To protect the Print Head, the printer may stop printing at a line break for a period of time and then resume printing.
In this case, interrupt your print session at a convenient time and turn the printer off for at least 15 minutes.
Additionally, if the printer has been printing graphics or photos with intense colors continuously over a period of time, the printer may stop printing to protect the Print Head. In this case, printing will not resume automatically. Turn the printer off for at least 15 minutes.
i_expl.gif Caution
The Print Head and the surrounding area can become extremely hot inside the printer. Never touch the Print Head or nearby components.
Out of paper.
Make sure that paper is loaded in the selected paper source.
Reload paper if no paper is found in the selected paper source (Auto Sheet Feeder or the Cassette).
If the same paper is loaded in the other paper source, you can switch the paper source with the Paper Feed Switch or the printer driver to continue printing.
If both paper sources have run out of paper, confirm the selected paper source and load paper there.
Printing documents with plenty of photographs or illustrations.
When the POWER lamp is flashing green, the printer or the computer is processing data. Printing large data such as photos or graphics takes time for the printer and the computer to process, during which the printer may appear to have stopped operating.
In addition, when printing data that uses a large amount of ink continuously on plain paper, the printer may pause temporarily. In either case, wait until the process is complete.
i_note.gif Note
If you are printing a document with a large printing area or printing multiple copies of a document, printing may pause to allow the ink to dry.
Dec 08, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Changed black cartridge now paper goes through printer but is blank. cartridge instaled properly.
Print a demo sheet.
1. Verify that inkjet paper is loaded in the paper tray.
2. Press and hold Scan + Copy/Resume simultaneously until the On/Off light flashes green.
Does a blank print appear? If so:
How did the paper exit your printer?
Quickly and smoothly
Slowly and in increments
If quickly and smoothly, contact Kodak at 1-800-421-6699.
To expedite the call, provide the agent with the one of the following reference IDs - PH02 for image quality problems or BP01 for problems with blank prints.
If slowly and in increments, reference BP02
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 06, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have an HP PSC 1510. I got a new computer with vista and it no longer does 2 sided printing. It used to have a pop up that caused the printing to pause allowing me to flip the paper and would print the...
Wow! I have this same printer and I didn't even know it could do that. I don't know what's wrong with the machine, but to make 2-sided copies you can still just flip the paper, as long as you take the stack of blank paper out of the feed so it doesn't print your second side on a clean sheet.
Mar 24, 2009 | HP PSC 1510 All-In-One InkJet Printer
Smudgy Photo orints
Make sure you are printing on the correct side of the paper. Most photo paper is single-sided. If you print on the wrong side, the ink sits on the surface, pulls up into very small drops, and remains wet for quite a while. If you print on the correct side, the image should be dry to the touch within 15-30 seconds.
Jul 29, 2008 | Canon PIXMA MX300 All-in-One Printer
HP 7310
Both these issues could be caused by a dirty media sensor. If this is the issue you may be able to improve things by selecting "plain paper" rather than "Automatic".
You can also try cleaning the sensor. The sensor is on the bottom of a black plastic piece mounted to the side of the carriage. Open the printer lid as if you were going to change the cartridges, then gently move the carriage about an inch to the left. There is a small black part mounted toward the bottom rear of the carriage. The sensor is on the underside of this. You could try cleaning the sensor with a damp Q-tip. Be careful not to get in the service station area where there is waste ink. This can be messy, be especially careful not to get ink on the sensor.
If the sensor was the issue normal printing could take several hundred passes of the carriage, with the paper moving just a bit after each swath. There is another possibility for slow printing, where the printhead pauses for 8-15 seconds at the end of each swath. This may be caused by a cartridge issue. In this case try removing the cartridges and cleaning the contact pads as shown here (for a different printer series, but similar....). If the carriage still pauses for 8-15 seconds after each swath then one of the cartrdgies will need to be replaced.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Regards,
Jun 18, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Paperend
You can set the sensor to either reflective or transmissive.
For the printer to maintain a constant print position it uses the transmissive sensor to detect the gap
between labels by measuring the amount of light passing through the media. When the media is preprinted,
the darker (or more dense) inks can interfere with this process causing paper jam errors. To get
around this problem a minimum threshold can be set for the sensor in the following way.
(1) The printer is in stand-by.
(2) Load a media roll in the usual way.
(3) Press the [PAUSE] key.
(4) The printer enters the pause mode.
(5) Press and hold the [PAUSE] key for at least 3
seconds in the pause state.
(6) The sensor type is displayed.
(7) Press the [FEED] key.
(8) The reflective sensor (black mark sensor) is selected.
(9) Press the [FEED] key again.
(10) The transmissive sensor (feed gap sensor) is selected.
(11) Press and hold the [PAUSE] key.
(12) The media is advanced until the [PAUSE] key is
released.
(13) Release the [PAUSE] key when more than 1.5 labels
(tags) are advanced.
(Threshold setting is completed by this operation.)
(14) Press the [RESTART] key.
(15) The printer is in stand-by.
Jun 09, 2008 | Toshiba TEC B-472 Thermal Label Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
23 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
