Question about Dishwashers
Location of the circulating pump for miele G1020 dishwasher
  • 89 Answers
Underneath the wash tank, you need to completly drain the machine by hand then lay it on to its side then remove the base
Posted on Nov 25, 2013
4 Suggested Answers
SOURCE: Dishwasher does not circulate water
I had a similar issue and it was the Motor Circulation Pump. Part #239144 @ Marcone Appliance Parts Center (860) 548-0080
Posted on Mar 03, 2009
gwshaw71
  • 83 Answers
SOURCE: Circulation pump on my Miele dishwasher
Miele makes a special tool that you use to free up circulation pump.The price for that pump is about 800-900 dollars.Call miele and ask for that tool.
Posted on May 09, 2009
reverendrave
  • 24 Answers
SOURCE: circulation pump is stuck
Hello Stonegroup,
The impeller is located below the bottom filter trap. Remove the tray and at the twelve 'O' Clock position you will see a small opening. Inside there are the pump impellers. take the Hackenschlussel (Hook spanner/Miele tool) and insert it in the opening and turn. You should turn it a few times and be able to feel the impellers free up. Also, Make sure you run the dishwasher atleast once a monch to avoid the circulation pump getting stuck like this
Posted on Sep 17, 2009
Miele dishwasher model G858 water will not circulate and the intake / drain code flashing? Does anyone know what needs to be replaced?
when you start a cycle, your machine should drain for 30 sec, fill with water, and then the circulation pump should come on. your water level should be up to the handle on the filter in the bottom. if you drain, and fill to the handle and then the intake drain error comes on, your circulation pump is stuck. if it does not fill to the handle, you may have a problem with the inlet valve.
Jun 02, 2012 | Miele 24 in. G858SCVi Plus Built-In...
F14 fault on Miele dishwasher
Hi
F14 means a fault on the heater pressure switch or the water intake.
It could be that either the switch is faulty or circulation pump is blocked, you can check if the pump filter is blocked
Dec 18, 2010 | Miele Dishwashers
My dishwasher stops and flashes up F85 can you tell me what this means please?
Fault code F85: Slide shutter signal change fault.
Defective shutter system, inside circulation pump. Circulation pump needs to be replaced.
Oct 05, 2010 | Miele Premier-Plus Built-in Dishwasher
F14 problem with miele
this fault means low pump pressure in the circulation pump due to foreign particles jamming up the pump. you would need to remove the unit and tip it on it's side and remove the base plate and the pump and clear the blockage.
Aug 26, 2010 | Miele Premier-Plus Built-in Dishwasher
F14 problem with miele dishwasher model G2270SCVI WOULD be grateful for your assistance asap as nothing in manual explains what to do. many thanks
Hi F14 is when the pump pressure switch does not operate. This can be caused by several things. Circulation motor blocked or defective. Insufficient quantity of water in appliance.Most commonly it is debris in circulation pump.This will require motor to be removed and cleaned.appliance will have to be un-installed
Jun 17, 2010 | Miele Premier-Plus Built-in Dishwasher
What is the error F14 in a Miele dishwasher ?
The error F14 in your dishwasher is due to water intake fault with heater or circulation pump, or something like that. The circulation pump would have been clogged. Try to clear it and your problem will get fixed
Apr 04, 2010 | Miele Premier-Plus Built-in Dishwasher
Circulation pump is stuck
Hello Stonegroup,
Sep 17, 2009 | Miele 23 in. Novotronic G841 Built-In...
May 08, 2009 | Dishwashers
Miele intake/drain flashes, no drain
this can happen after inactivity. the circulation pump seal sticks and wont turn . when the dishwasher starts to fill the circulation pump is pulsed on to see if the preasure switch switches over (to see if water is getting into the dishwasher) if the pump does not turn there is no preasure and the machine stops thinking no water has entered. turn pump by hand to cure.
Jul 18, 2008 | Miele 24 in. Touchtronic Platinum Built-in...
Error code. F14.
Check the motor circulation impeller, if you not maintain the unit is gonna be clog by impeller. it need to be clean.
Jan 11, 2008 | Miele Premier-Plus Built-in Dishwasher
Dishwashers Logo
62 people viewed this question
Top Dishwashers Experts
Owen Barnes
