Question about Garden
Everything is working fine, but the thread from the niddle does not create a stitch...the bobbing does not seem to function properly and the niddle doesnt seem to come down far enough to thread the bobbing so nothing happesn...can you help me solve this riddle...
    Problem Solver:
  • 41 Answers
Hi
please make sure you use the right needle and is mounted right
if all good, the graiffer has jam and need to be looked at by a qualified person
Posted on Oct 26, 2013
It won't pull thread up and sew
Try your bobbin to see if the thread can pulled using your fingers. 1. If it is too tight you may have to loosen it slightly. (let bobbin hang from finger and bob it up and down: It should move about one inch downward)
2. Try physically to pull the thread through the upper tension while the foot is down. Adjust the tension to many positions to see if it is making any difference to the tension of the thread.
3. When you feel it is functional begin the tension at four and the sewing should be noticeably better. (Many machines need to be adjusted just right to get that perfect stitch)
4. Remember to always start with good needle and installed properly.
Dec 04, 2016 | Sewing Machines
Intermittent sewing problems
You have two problems:
1) Sometime it sews fine, but other times it will sew like there is no tension on the thread and create a "birdsnest" in the bobbin compartment.
Cause : Threading the upper thread
- clean upper thread tensions discs
- do not forget "• raise the needle and presser foot" (see manual page 18)
2) Sometimes it just randomly changes ...
Please open new ticket. Give tu us more info. It seems like Short circuit on S-print, but your description is chaotic (not usable)
Apr 19, 2017 | Bernina Activa 130
Hello. I own a Singer 4423 Heavy Duty sewing machine. It has been working fine overall, but today it is giving me problems with jamming. At first it jammed underneath the plate and created a huge ball of...
Make sure thread is not laying across the bobbin when you look down into the plastic slider that covers the top loading bobbin case. The bobbin on mine I observed was loose in the case so that as the machine ran, eventually the bobbin thread would jump out of the stitch finger (the silver piece to the far left of the bobbin case, past the tension slots). I solved this problem and so can you! Take the extra felt spool pin felt in your accessories kit that came with the machine, remove bobbin from case and drop this small felt circle into the bobbin case. Replace bobbin. On the 4423, the bobbin thread goes counter-clockwise and drops into the tension discs, and goes all the back until it falls into the space left of the silver stitch finger. Make sure take up level raised all the way up! Then pull the needle thread toward you until bobbin thread comes all the way up. If you start sewing and you actually can SEE the bobbin thread laying across the bobbin, STOP and tethered because that would mean your thread did not slide all the back behind the silver stitch finger--however, I assure you, if you go one step at a time, you did it correctly! You will be smiling in no time! Why? The felt helps to make the bobbin rest in the correct position to keep it from jumping out of the groove. I hope this helps you.
Jimmy
Jul 29, 2011 | Singer 4423 Sewing Machine
Bunches of threads on the bottom
Try threading the machine with the presser foot up.
This opens the tension and allows the thread to seat into the tension control.
When the thread is not properly seated, there isn't any tension on the top thread the bobbin thread cannot make a proper stitch with a top thead that is loosey-goosey.
Mar 20, 2010 | Sewing Machines
Brother CS-6000i - the bobbin thread is not coming through in order to make a stitch. I have cleaned the bobbing case, changed needles, re-threaded machine, changed thread, and even changed bobbins. It was...
Check list:
1 - Flat side of the needle is facing the back of the machine.
2 - Threaded machine with the presser foot up - always.
3 - Bobbin thread is feeding from the spool in the correct direction and through the proper guides.
Lower and raise the threaded needle, holding onto the end of the thread.
If this does not pull the bobbin thread up, the timing may need adjusting.
There is a graphic for doing this as sewusa.com or take it into the dealer for service.
Mar 10, 2010 | Brother CS6000i Computerized Sewing...
Loose stitch
Welcome to FixYa. I am the sewing machine expert that chose your issue to solve.
When everything seems to be working fine and an occasional stitch is loose.....now get ready.......here it is.......the needle!
It seems impossible, but the needle is the most neglected part of the machine. The one you are using could be slightly bent or have a slight burr that you won't see with the naked eye. Also, needles, especially in an embroidery machine (which work their buns off), are only good for about 8 hours of cumulative use. I would say that an embroidery needle should be retired after 3 or 4. They get dull like a razor blade which can cause enough drag to create a timing issue that's barely perceptible.
Welcome to FixYa! I am the sewing machine expert that chose to help you with your issue.
There are really only two things that can cause bottom (note: remember that problems with the bottom thread, almost always comes from the top and not the bobbin. Bobbins rarely need tension adjustments). These two things are:
  1. An area was missed when the machine was threaded (most machines have an arrow at each area on the thread path where the thread MUST run or the stitch on the bottom will be sloppy. Threading can be tricky and even the most experienced miss once in a while.
  2. The tension adjustment mechanism in the thread path. If the thread is not properly through this area, the thread on the bottom will be sloppy or if, threaded properly, and the tension is set too loose, the stitch will be sloppy. If the tension is set too tight, the bottom thread will be tight and pucker the fabric.
It is counter-intuitive that problems with the top tension cause problems with the bottom stitch but it sure will.
So try it and see if that helps.
Thanks for using FixYa.com
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further.
Jan 31, 2009 | Bernina Bernette 75
Won't stitch properly
it sounds like you might need a new bobbin case to me try that and see if the issues you are having stop hope this helps
Sep 20, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Balance wheel is totally jammed
machine was working fine when suddenly it just jammed up. Everything seems to be fine, but the balance wheel is completely jammed rigid. I've looked at the shuttle and there are no thread jams at all. The needle moves fine from side to side with different stitch selections, but wont go up and down with the wheel.
I have tried looking in the machine, but I can't find any thread jammed.
Apr 26, 2008 | Brother NX-400
No stitches 925D.
Probably your looper timing is off. This is common, and just a necessary evil of sergers. Their tolerances are tight.
The operation of creating a serger stitch is a succession of thread grabing and delivering. One looper grabs a thread and delivers it to the needle and so on.
To check this, turn your handwheel slowly and check to see that the upper looper is meeting the lower looper by passing very close to the indented part at the back of the lower looper (indented part is called the scarf, this is where the looper threads form a lock) If not, it's the looper timing. If they seem to meet properly then check your needle. Is your needle up into the needle clamp all the way? Try a new needle. Even a slight bend to the needle will not allow the loopers to meet and grab or deliver thread. You might check the tensions. Thread has to have some resistance in order for the loopers to do their job,
If your looper timing is off, find a sewing repair person to retime the serger. Don't try it yourself or put this repair off. If the loopers go further out of timing, they might hit something and replacement can be costly.
Nov 18, 2007 | Brother 929D Mechanical Sewing Machine
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
