Question about Refrigerators
Maytag GT1626BAS doors need lifting - Refrigerators
    Champion:
  • 210 Answers
Remove doors and use plastic washers to shim up doors.
Posted on Oct 15, 2013
  • barny63 Oct 15, 2013
    Thanks David, will try that - much appreciated
How do I put in my oven door?
The door on k.a. / whirlpool - hinge has a tab that locks rhe hinge and prevents the hinge spring from pulling door closed all the wayslightly lifting and continuing to close thw door lifts it off the hinge rest. Some models have set screws that need to be removed some require door disasembly some ge maytag frigidaire dcs wolf viking etc the door simply lifts off. The hinges stay attached to the app.and some have holes at the pivot of the hinge wherea 1/8 inch metal tabs or nails are inserted and door is ifted up and out....
(That is 1/3 of the job 2/3 is puting it back) lol
Mar 09, 2015 | Kenmore 75012 / 75014 Gas Kitchen Range
My handle on my oven door came off. maytag model# mgr8674aw0
seperate the 2 halves(screwed together ) and rescrew it . door should just lift off when door is part way open
Feb 24, 2015 | Maytag Kitchen Ranges
Hi, how can i fix maytag refrigerator gt1626bas and it doesn't defrost, ice was all over, I melt it, and I checked the heater,but it's cold, few days ago it stoped working completely but in the back
IS THE TIMER MOVING TO ACTIVATE A DEFROST CYCLE? IF SO THE HEATER MAYBE OPEN CIRCUIT; OR DEFROST SENSOR IS OPEN CIRCUIT EITHER WILL STOP A DEFROST CYCLE HENCE LOADS OF ICE!!!!!
May 11, 2014 | Maytag Refrigerators
How do you remove the oven door from a Maytag MGR 5780 range. I cannot see any latches on the hinges
There aren't any latches on the Maytag MGR5780 oven door hinges. You should be able to open the door to the first stop (about 4" from the closed position). Then grab the sides of the door and lift the door up at that same angle until the door clears both hinge arms. Manage My Life has the manual for the MGR5780 here: http://www.managemylife.com/mmh/owner_manuals/25316/MAYTAG-Free-Standing,-Gas-L0303326 . See page 15 (16 of the PDF) for a picture of the door open to the first stop position. You will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Oct 23, 2013 | Maytag Heating & Cooling
Remove front panel and door on maytag electric dryer atlantis
Simple, 4 screws total. open door, remove one screw from each of the door hinge plates that are against the front panel, remove two screws directly across the door opening (other side of dryer), door can be lifted slightly and pulled out of slots, and front panel can be unhooked from retaining clips by a little wiggling at the top sides, swing it down toward the floor and lift it from bottom retaining hooks.
Apr 14, 2013 | Maytag Atlantis MDG8400AW Gas Dryer
How to remove a Maytag gas stove oven door (Maytag Model # MGR5755Qwd)
Hi.
Before removing the door you need to release the lock on the oven door hinges. Door hinge locks are slide mechanisms or pins located on top of the hinges Once lock is released you will be able to pull out the door by opening it a bit, then lifting it up and pulling out.
Here parts and diagrams for your oven: MGR5755QDW.
Regards.
Ginko
Sep 09, 2011 | Maytag MGR5755QD CleanDesign Gas Kitchen...
We need to know what wires to hook together to bypass the door switch on our maytag electric dryer to test it
lift the top up on your dryer.this will require a wide,flat tool @ front corners.a flat screw driver will work but a stiff putty knife is ideal.lift & pull.the door switch is in the upper right hand corner.when you raise the top & lean it carefully out of the way you will see the obvious door switch wires.pull them off of the switch & put them together w/ a clothes pin.you can bump the start button w/ the lid still up.if it starts up,its the switch.
Feb 12, 2010 | Maytag PYE2300AY Electric Dryer
Need to replace the screws that holds the drum baffle in place
remove the scresw holding the door on, remove the door, the remove the 2 screws oppisite th edoor inge and the front panel will lift off. there will be 2 5/16 screws holding the top down to the frame of unit, the top will then lift up[ giving you acces to the outside of the drum to resecure the drum baffle
Nov 21, 2008 | Maytag Dryers
How to take apart oven door
you need to remove the door. On your model just grab the door and lift and it should lift right off. Then remove the screws that run along the bottom of the door. Remove the bottom trim and the glass should slide down and off. Reverse to assemble
Jun 18, 2007 | Maytag MER5775Q Electric Kitchen Range
Lifting the top of the Maytag MER5770AAW
eliasan, to remove the glass top you need to open the oven door, on the body frame where the top of the door fits under, there will be 2 quarter inch screws on each corner securing the top to the body. Remove these 2 screws. Grab the top with both hands and pull forward. Disconnect the quick connect fittings in the back for the burners and the top will lift off now. Make sure to kill the power before attempting this. Catriver..post back
Apr 22, 2007 | Maytag MER5770 Electric Kitchen Range
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
