SOURCE: humming noise/ feedback
your mixer should be grounded by the power cord, and the decks have a seperate ground wire which connects, usually on a screw terminal, to the mixer, which provides the ground for the decks. I would try the headshells to make sure they are tight and connected correctly also make sure the power socket on the wall is earthed properly.
SOURCE: Stanton STR8-100 Turntable ground wire?
i had the problem with stanton t92 solved it by plugging ac cord into receivers switched input
TIPDon't use a normal cable or satellite program for this; you're about to disconnect the cable that provides the audio and video for your cable/satellite feed.
WARNINGOddly enough, this solution (surge protection) can sometimes increase the humming.
WARNINGIt is unsafe to use a two-prong to three-prong "cheater" plug on the subwoofer power cord to solve the hum problem. Even if the subwoofer came with a cheater plug in the box, it's REALLY not safe to do. Don't do it.
Unplug your
receiver.. Split a wire and attach one of the splits to the receiver
where you will see the text, "ground" or something similar. Attach the
other end to something metal such as a pipe that goes into the ground.
Secure with electrical tape. Plug in.
connect the ground wire to a screw on the electrical
outlet.
